Helios4 doesn't boot after upgrading to linux-6.6.71 (linux-image-current-mvebu_25.2.0-trunk.343)
Go to solution Solved by Josua-SR,
Hi @wolf7250,
That does not look like the new bootscript. Did you update already?
To get it working again, you can try the quick workaround as you pointed to earlier, which should allow more room for U-Boot loading kernel, initrd and the rest.
Gr,
Hi @wolf7250,
The correct U-Boot and bootscript is for sure in the newest release. I built recently and all is there and working without issue on my helios4.
Let's unravel what is happening for you and get that sorted out.
Gr,
Ok. This might have been caused by a partial update. Running OMV there is a script to run to update to the latest in that version - in my case v6. Once that completes successfully then I need to run a release update script which will increment the major version to 7. But I never got that far.
So maybe if I do the quick workaround to get me onto the latest and then the correct U-Boot and bootscript will then be included as you said in the latest?
Hope that all made sense 😁
