djurny Posted 3 hours ago Posted 3 hours ago Hi @wolf7250, That does not look like the new bootscript. Did you update already? To get it working again, you can try the quick workaround as you pointed to earlier, which should allow more room for U-Boot loading kernel, initrd and the rest. Gr, 1 Quote
wolf7250 Posted 3 hours ago Posted 3 hours ago Yes, I did update… not sure why it’s not picking it up. If I go with the quick workaround, will the correct U-Boot get applied in future updates? 0 Quote
djurny Posted 2 hours ago Posted 2 hours ago Hi @wolf7250, The correct U-Boot and bootscript is for sure in the newest release. I built recently and all is there and working without issue on my helios4. Let's unravel what is happening for you and get that sorted out. Gr, 1 Quote
wolf7250 Posted 2 hours ago Posted 2 hours ago Ok. This might have been caused by a partial update. Running OMV there is a script to run to update to the latest in that version - in my case v6. Once that completes successfully then I need to run a release update script which will increment the major version to 7. But I never got that far. So maybe if I do the quick workaround to get me onto the latest and then the correct U-Boot and bootscript will then be included as you said in the latest? Hope that all made sense 😁 0 Quote
djurny Posted 31 minutes ago Posted 31 minutes ago Hi @wolf7250, I'm not familiar with OMV, so not sure what that update/upgrade process looks like. If it will update/upgrade the armbian packages to the latest release 25.11, then the correct version of armbian-bsp-cli will be installed. The installation of that package should update /boot/boot.scr and make a new U-Boot image available that you would have to install with nand-sata-install. Gr, 0 Quote
