The "Edit Device" wordpress template ("https://www.armbian.com/wp-admin/...") has some input fields that I would like to understand.
I am trying to complete it for the MKS-Klipad50 (https://www.armbian.com/mks-klipad50).
(It's a CSC board, not standard support - if that matters.)
Following fields are unclear to me:
  • "Compatible"
    • What is the meaning and expected syntax?
    • Is that something like devices using the same kernel, but different setup/devicetree files?
  • "Expose kernels" / "How many kernels to expose?"
    • Is this related to the "Kernels" table (see below), like how many rows to use?
  • "Kernels"
    • Is it required adding rows to have images automatically generated and appear as download links on the device page?
      Or are these options just required for additional non-standard images?
      Is it better to leave it empty?
Could someone please shed some light on the meaning of these fields?
Compatible field is reserved for almost identical boards or when image supports more devices, like Raspberry Pi 3 and 4. Base image is for Rpi4 but Rpi3 is also compatible.
Other two fields are deprecated as content is generated automatically. For customization of build targets, check this https://github.com/armbian/os/wiki
