Erez Alster Posted February 10 Posted February 10 Hi I'm wondering if you are considering to support Orange Pi 5 support. I want to use the HDMI input to record 4k 60fps. At the moment I'm using the official orange pi image (kernel 6.1.43) and I've many issues in the kernel Quote [ 4866.179834] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2 [ 4866.260829] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:23! [ 4866.897145] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio [ 4870.556651] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x32315559, cur_fmt:0x3631564e! [ 4870.556667] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x32315559, cur_fmt:0x3631564e! [ 4870.556669] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x32315659, cur_fmt:0x3631564e! [ 4870.556672] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x50323234, cur_fmt:0x3631564e! [ 4870.556674] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x56595559, cur_fmt:0x3631564e! [ 4870.556676] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x59565955, cur_fmt:0x3631564e! [ 4870.556679] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x50313134, cur_fmt:0x3631564e! [ 4870.556681] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x39565559, cur_fmt:0x3631564e! [ 4870.556683] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x39555659, cur_fmt:0x3631564e! [ 4870.556684] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x4f424752, cur_fmt:0x3631564e! [ 4870.556686] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x51424752, cur_fmt:0x3631564e! [ 4870.556688] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x50424752, cur_fmt:0x3631564e! [ 4870.556690] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x52424752, cur_fmt:0x3631564e! [ 4870.556693] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x33524742, cur_fmt:0x3631564e! [ 4870.556695] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x33424752, cur_fmt:0x3631564e! [ 4870.556697] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x34325258, cur_fmt:0x3631564e! [ 4870.556699] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x34325842, cur_fmt:0x3631564e! [ 4870.556701] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x34325241, cur_fmt:0x3631564e! [ 4870.556703] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x34324142, cur_fmt:0x3631564e! [ 4870.556705] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x34524742, cur_fmt:0x3631564e! [ 4870.556707] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x34424752, cur_fmt:0x3631564e! [ 4870.556709] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x59455247, cur_fmt:0x3631564e! [ 4870.556711] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x20363159, cur_fmt:0x3631564e! [ 4870.556712] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x2036315a, cur_fmt:0x3631564e! [ 4870.556714] fdee0000.hdmirx-controller: hdmirx_s_fmt_vid_cap_mplane: err, set_fmt:0x3432564e, cur_fmt:0x3631564e! [ 4870.583506] fdee0000.hdmirx-controller: hdmirx_start_streaming: delay_line:720 [ 4871.779810] fdee0000.hdmirx-controller: rcv frames [ 4876.512192] fdee0000.hdmirx-controller: stream start stopping [ 4876.563926] fdee0000.hdmirx-controller: hdmirx_stop_streaming wait last irq timeout, return bufs! [ 4876.563972] fdee0000.hdmirx-controller: stream stopping finished [ 4877.580032] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2 [ 4877.679342] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:23! [ 4878.043928] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio [ 4878.273579] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1920x1080p30.00 (2200x1125) [ 4879.413396] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2 [ 4879.514266] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:23! 0 Quote
Igor Posted February 10 Posted February 10 35 minutes ago, Erez Alster said: I'm wondering if you are considering to support Here are variants how you can support our project Board support rules: https://docs.armbian.com/User-Guide_Board-Support-Rules/ (I think you will be able to get an answer by reading this) 0 Quote
Erez Alster Posted February 10 Author Posted February 10 thanks for the reply. I was able to build armbian from scretch with the new module based on orange pi max. Can you guide me how to add hdmirx to the kernel? at the moment I'm not able to use the HDMI input at all 0 Quote
Werner Posted February 10 Posted February 10 hdmirx is disabled by default since the code is poorly implemented and causes load for no reason. If you still want to play with this enable it via overlay. 0 Quote
Erez Alster Posted February 10 Author Posted February 10 Thank you. I see a lot of patches around this area in the build project. I will take a look. thank you! What is your recommendation about consuming video? using only CSI? 0 Quote
Igor Posted February 10 Posted February 10 49 minutes ago, Erez Alster said: I see a lot of patches around this area in the build project. That is a hard work of people that spent their precious private time to fix broken software support of Orangepi. 0 Quote
Erez Alster Posted February 10 Author Posted February 10 I will try to join the effort too I'm not able to find the hdmirx binaries at all. I compiled armbian without any modifications. Am I missing something? 0 Quote
Erez Alster Posted February 11 Author Posted February 11 Can you suggest alternatives for using HDMI input? So what is the solution if i want to consume 4k 60fps video? 0 Quote
Werner Posted February 11 Posted February 11 Isn't the hdmirx on rk3588 able to do 4k60? https://www.rock-chips.com/uploads/pdf/2022.8.26/192/RK3588 Brief Datasheet.pdf 0 Quote
ag123 Posted February 11 Posted February 11 hdmirx aside, Would Armbian run on Orange Pi 5 ultra? a closer image I'd guess is this? https://www.armbian.com/orange-pi-5-plus/ there is also some 'rumors' about rk3588 mainlining efforts, I'd guess it could be 'lost in translation' / misintepreted I've weighed between a Rpi 5 vs rk3588, rk3588 seemed to be higher performing and has a built-in NPU. But that for sure Rpi 5 have more 'popular' support, at least from Rpi itself. A thing about Armbian and/'or mainline based linux running on these boards is, they tend to be 'beyond rpi', hacks like HDMI RX is feasible. Rpi is more for 'lazy' tinkerers who wants boards that 'just works', but that sometimes that helps. 0 Quote
Werner Posted February 11 Posted February 11 9 minutes ago, ag123 said: Would Armbian run on Orange Pi 5 ultra? If somebody adds support for it, why not? 13 minutes ago, ag123 said: there is also some 'rumors' about rk3588 mainlining efforts, I'd guess it could be 'lost in translation' / misintepreted https://www.cnx-software.com/2024/12/21/rockchip-rk3588-mainline-linux-support-current-status-and-future-work-for-2025/ tl;dr: even if rk abandons it seems like collabora will continue. 0 Quote
ag123 Posted February 11 Posted February 11 well, the SOC is the same, 'in theory', that image e.g. for pi5-plus should work. The trouble is the dram and all + on board emmc, and i'm not sure what else (ethernet/wifi ?) etc may be different. I think i'd go with a Rpi 5 firsthand as I've yet to get a board and maybe add a rk3588 (perhaps much) later. and well in mainline there seemed to be a dts already there for opi 5 plus https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/arch/arm64/boot/dts/rockchip/rk3588-orangepi-5-plus.dts?h=v6.13 but it'd seem there is no 'specifics' for opi 5 ultra https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/arch/arm64/boot/dts/rockchip?h=v6.13 if it is true, one'd need to go on the notion of 'may work' e.g. to use the opi 5+ image for a start. and of course the other 'hidden' (and very important) thing is uboot https://www.denx.de/project/u-boot/ 0 Quote
Erez Alster Posted February 12 Author Posted February 12 My main issue with RPI5 is the lack of hardware video encoder which is extremely disappointing! Radxa team is checking the HDMI issue on their board (they are using 3588 as well) - https://forum.radxa.com/t/hdmi-input-support/25740/8 3588 should support 4k 60fps in theory but there are many complaints about using WIFI, BTH & USB in parallel that leading the losing signals when working with HDMI input. 0 Quote
Gustavo M Posted February 22 Posted February 22 There is a "out of the box" support for Orange pi 5 boards... which is proprietary packages. Go here, find the .deb file for mali-g610 and install it with sudo dpkg -i file.name. 1 Quote
Sinclear Posted March 2 Posted March 2 Hi, I tried the build. Unfortunately, it doesn't start. I'll connect via uart tomorrow and see what he's writing. 0 Quote
Werner Posted March 2 Posted March 2 I did a last minute fix when you read through the pr. Please test https://fi.mirror.armbian.de/.testing/Armbian-unofficial_25.05.0-trunk_Orangepi5-ultra_bookworm_current_6.12.17_minimal.img.xz 0 Quote
Sinclear Posted March 2 Posted March 2 (edited) The HDMI-out does not work. But the LED is blinking. as I understand it, the hdmi0 interface is reserved by rx Maybe that's the problem... Edited March 2 by Sinclear 0 Quote
Werner Posted March 3 Posted March 3 This is expected for current. If it boots its good enough for server application. To make use of all the other hw features either wait a few years or try to make vendor kernel work. 0 Quote
Sinclear Posted March 4 Posted March 4 (edited) https://drive.google.com/drive/folders/1toMSBI5hTQ88DLRtX86yIwBBG5ipPXaN?usp=sharing armbian server (on Debian 12 & Ubuntu) Wi-fi is not working (AP6611) Edited March 5 by Sinclear 0 Quote
Sinclear Posted 9 hours ago Posted 9 hours ago Hi everyone, dietpi has appeared here with full support. https://github.com/MichaIng/DietPi 0 Quote
