Rdlop Posted February 27 Posted February 27 (edited) I'm using Orange Pi 5 Plus, I've updated to latest by apt upgrade but seems to be stuck on old version as you can see 25.2.2 but kernel is still 6.1.75 : # uname -a Linux abeure 6.1.75-vendor-rk35xx #1 SMP Wed Aug 21 11:45:59 UTC 2024 aarch64 GNU/Linux # cat /var/log/apt/history.log Start-Date: 2025-02-25 01:00:39 Commandline: /usr/bin/unattended-upgrade Upgrade: armbian-firmware:arm64 (25.2.1, 25.2.2) End-Date: 2025-02-25 01:00:42 Start-Date: 2025-02-25 01:01:10 Commandline: /usr/bin/unattended-upgrade Upgrade: linux-u-boot-orangepi5-plus-vendor:arm64 (24.11.1, 25.2.2) End-Date: 2025-02-25 01:01:11 Latest version https://www.armbian.com/orange-pi-5-plus/ does not seems to be fetched. Armbian 25.2.1 Bookworm Minimal / IOT Kernel: 6.1.99, Size: 295.5 MB, Release date: Feb 15, 2025 Can you explain what i've missed ? Edited February 27 by Rdlop 0 Quote
Werner Posted February 28 Posted February 28 Maybe firmware packages are frozen? Check with apt-mark showhold 0 Quote
Werner Posted February 28 Posted February 28 Hi Providing logs with PASTE_SERVER_HOST=paste.armbian.de armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
Rdlop Posted February 28 Author Posted February 28 apt-mark showhold N: Ignoring file '02-armbian-periodic.distrib' in directory '/etc/apt/apt.conf.d/' as it has an invalid filename extension 0 Quote
Rdlop Posted February 28 Author Posted February 28 Do you have `man armbianmonitor` i'd like to see output before send it to paste.armbian.de ? 0 Quote
Werner Posted February 28 Posted February 28 armbianmonitor -U sends output to stdout instead of paste service 0 Quote
Rdlop Posted March 2 Author Posted March 2 # armbianmonitor -U 1 2 ### lsusb: 3 4 Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc. GL3523 Hub 5 Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub 6 Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub 7 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 8 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 9 Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 10 Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 11 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 12 13 /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M 14 /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M 15 /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M 16 /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M 17 /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M 18 |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M 19 /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M 20 |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M 21 22 ### Userland generated with Armbian Build Framework: 23 24 PRETTY_NAME="Armbian 25.2.2 bookworm" 25 ARMBIAN_PRETTY_NAME="Armbian 25.2.2 bookworm" 26 27 ### Installed packages: 28 29 ii armbian-bsp-cli-orangepi5-plus-vendor 25.2.2 arm64 Armbian CLI BSP for board 'orangepi5-plus' branch 'vendor' 30 ii armbian-firmware 25.2.2 all Armbian - Linux firmware 31 ii linux-base 4.9 all Linux image base package 32 ii linux-dtb-vendor-rk35xx 24.8.1 arm64 Armbian Linux vendor DTBs in /boot/dtb-6.1.75-vendor-rk35xx 33 ii linux-image-vendor-rk35xx 24.8.1 arm64 Armbian Linux vendor kernel image 6.1.75-vendor-rk35xx 34 ii linux-u-boot-orangepi5-plus-vendor 25.2.2 arm64 Das U-Boot for orangepi5-plus 0 Quote
Rdlop Posted March 4 Author Posted March 4 dpkg-divert --no-rename --add /etc/apt/apt.conf.d/02-armbian-periodic I've modified that file not to be erased during update which contains // Enable the update/upgrade script (0=disable) APT::Periodic::Enable 1; // Do apt-get update automatically every n-days (0=disable) APT::Periodic::Update-Package-Lists 1; // Do apt-get upgrade --download-only every n-days (0=disable) APT::Periodic::Download-Upgradeable-Packages 1; // Run the unattended-upgrade security upgrade script // every n-days (0=disabled) // Requires the package unattended-upgrades and will write // a log in /var/log/unattended-upgrades APT::Periodic::Unattended-Upgrade 1; // Do apt-get autoclean every n-days (0=disable) APT::Periodic::AutocleanInterval 20; // Define basic patterns //Unattended-Upgrade::Origins-Pattern { // origin=,codename=; // origin=Armbian; //}; APT::Periodic::Update-Package-Lists 1; APT::Periodic::Verbose 1; Unattended-Upgrade::Remove-New-Unused-Dependencies true; Unattended-Upgrade::Remove-Unused-Dependencies true; Unattended-Upgrade::Automatic-Reboot true; Unattended-Upgrade::Automatic-Reboot-Time 02:30; Unattended-Upgrade::Origins-Pattern { origin=*; }; Do you think that file might be the problem ? Also package are updated : cat /var/log/apt/history.log Start-Date: 2025-03-04 01:00:37 Commandline: /usr/bin/unattended-upgrade Upgrade: armbian-firmware:arm64 (25.2.2, 25.2.2) End-Date: 2025-03-04 01:00:40 0 Quote
Igor Posted March 4 Posted March 4 1 hour ago, Rdlop said: Do you think that file might be the problem ? Try armbian-config way - drop your configs before. 0 Quote
Rdlop Posted March 4 Author Posted March 4 @Igor armbian-config was not installed, after installation the kernel upgrade were not frozen. 0 Quote
Rdlop Posted March 6 Author Posted March 6 how can I update by using unattended-upgrades the whole system kernel too ? (I mean like in Debian distribution) ? 0 Quote
Solution Igor Posted March 6 Solution Posted March 6 44 minutes ago, Rdlop said: how can I update by using unattended-upgrades the whole system kernel too ? With enabled everything in automatic upgrades. If kernel is not frozen, it will update too. If it's frozen (check with apt-mark showhold) find in the armbian-config to unfreeze it. 0 Quote
Rdlop Posted March 6 Author Posted March 6 (edited) I've seen the latest kernel in armbian-config, installed it with armbian-config. I'll see if next release will be fetch automatically. Thanks for answer ! armbianmonitor -U 5484 PRETTY_NAME="Armbian 25.2.2 bookworm" 5485 ARMBIAN_PRETTY_NAME="Armbian 25.2.2 bookworm" 5486 5487 ### Installed packages: 5488 5489 ii armbian-bsp-cli-orangepi5-plus-vendor 25.2.2 arm64 Armbian CLI BSP for board 'orangepi5-plus' branch 'vendor' 5490 ii armbian-config 25.5.0-trunk.157.0305.102925 all Armbian config: The Next Generation 5491 ii armbian-firmware 25.2.2 all Armbian - Linux firmware 5492 ii linux-base 4.9 all Linux image base package 5493 ii linux-dtb-vendor-rk35xx 25.2.2 arm64 Armbian Linux vendor DTBs in /boot/dtb-6.1.99-vendor-rk35xx 5494 ii linux-image-vendor-rk35xx 25.2.2 arm64 Armbian Linux vendor kernel image 6.1.99-vendor-rk35xx 5495 ii linux-u-boot-orangepi5-plus-vendor 25.2.2 arm64 Das U-Boot for orangepi5-plus Edited March 6 by Rdlop 0 Quote
