devmichelcastilho Posted March 16 Posted March 16 (edited) Armbianmonitor: https://paste.armbian.com/xuzeyolapi So I'm trying to connect with a UART cable from my PC to the board (OPI3LTS). Here's what I did so far: In desperation, I double checked every connection, to no avail. My devices are powered separately, so only the RX and TX cable are connected, and they are crossed as they should. Set up permissions: sudo chmod 666 /dev/ttyUSB0 Add user to dialout: sudo adduser <user> dialout Install minicom: Set up minicom with the correct address: /dev/ttyUSB0 Set up the correct baud rate (115200 in this case) Turn off flow control Tried connecting via "screen", minicom and putty, all of them just show me a black CLI I can't write in. Help? 🥲 Edited March 16 by devmichelcastilho 0 Quote
devmichelcastilho Posted 3 hours ago Author Posted 3 hours ago Still no clue what's happening... 0 Quote
