alex_laco Posted April 2, 2025 Posted April 2, 2025 Hi everyone, I'm experiencing a severe boot delay on my Banana Pi M5 running Server Armbian Image (v25.2.2 - Banana Pi M5 - Armbian Linux 6.12.21-current-meson64) when no HDMI monitor is connected. The board itself is working fine, but without an HDMI connection, the system takes several long minutes to complete the boot process. Details The system boots normally and quickly when an HDMI monitor is attached. However, without a monitor, in headless mode , the boot process is significantly delayed several minutes (approx. 4 minutes). Blue led blinking normaly. I've Tried modified /boot/armbianEnv.txt by setting: display_autodetect=false disablehpd=true hdmi_force_hotplug=1 Unfortunately, these changes did not resolve the boot delay issue. Do you please have any suggestions or insights on how to modify the boot process to fix this problem? Thank you in advance. 0 Quote
alex_laco Posted April 2, 2025 Author Posted April 2, 2025 This dmesg log is when HDMI is connected and it's working properly https://paste.next.armbian.com/urucidibas.yaml And this dmesg log is when HDMI is Disconnected and boot delayed for aprox. 4 minutes. https://paste.next.armbian.com/idivonoyol.yaml Im getting this error 8 times with significant delay: [ 200.158193] meson-drm ff900000.vpu: [drm] *ERROR* flip_done timed out [ 200.158211] meson-drm ff900000.vpu: [drm] *ERROR* [CRTC:43:meson_crtc] commit wait timed out [ 210.398133] meson-drm ff900000.vpu: [drm] *ERROR* flip_done timed out [ 210.398147] meson-drm ff900000.vpu: [drm] *ERROR* [CONNECTOR:33:Composite-1] commit wait timed out [ 220.638124] meson-drm ff900000.vpu: [drm] *ERROR* flip_done timed out [ 220.638139] meson-drm ff900000.vpu: [drm] *ERROR* [PLANE:37:meson_primary_plane] commit wait timed out [ 220.742126] ------------[ cut here ]------------ [ 220.742135] [CRTC:43:meson_crtc] vblank wait timed out [ 220.742189] WARNING: CPU: 2 PID: 1334 at drivers/gpu/drm/drm_atomic_helper.c:1682 drm_atomic_helper_wait_for_vblanks.part.0+0x278/0x29c [ 220.742216] Modules linked in: snd_soc_hdmi_codec snd_soc_meson_g12a_toacodec snd_soc_meson_axg_tdmout snd_soc_meson_g12a_tohdmitx polyval_ce snd_soc_meson_codec_glue polyval_generic snd_soc_meson_axg_sound_card panfrost gpu_sched snd_soc_meson_card_utils drm_shmem_helper meson_vdec(C) snd_soc_meson_axg_toddr meson_gxbb_wdt snd_soc_meson_axg_frddr snd_soc_meson_axg_fifo videobuf2_dma_contig snd_soc_meson_axg_tdmin meson_ir rc_core v4l2_mem2mem videobuf2_memops videobuf2_v4l2 dw_hdmi_i2s_audio meson_ddr_pmu_g12 snd_soc_meson_t9015 videodev snd_soc_meson_axg_tdm_interface videobuf2_common snd_soc_meson_axg_tdm_formatter mc snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_pcm snd_timer snd soundcore zram zsmalloc binfmt_misc sch_fq_codel efi_pstore dm_mod autofs4 meson_gxl smsc meson_saradc rtc_meson_vrtc axg_audio sclk_div reset_meson_audio_arb realtek clk_phase meson_rng dwmac_generic dwmac_meson8b nvmem_meson_efuse adc_keys [ 220.742412] CPU: 2 UID: 0 PID: 1334 Comm: setfont Tainted: G WC 6.12.21-current-meson64 #1 [ 220.742426] Tainted: [W]=WARN, [C]=CRAP [ 220.742430] Hardware name: Banana Pi BPI-M5 (DT) [ 220.742435] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 220.742444] pc : drm_atomic_helper_wait_for_vblanks.part.0+0x278/0x29c [ 220.742457] lr : drm_atomic_helper_wait_for_vblanks.part.0+0x278/0x29c [ 220.742467] sp : ffff80008321b5e0 [ 220.742471] x29: ffff80008321b5e0 x28: 0000000000000007 x27: 0000000000000000 [ 220.742484] x26: 0000000000000001 x25: 0000000000000038 x24: ffff000009203000 [ 220.742497] x23: 0000000000000001 x22: 0000000000000000 x21: ffff000004e5af80 [ 220.742509] x20: ffff000009205880 x19: 0000000000000000 x18: ffffffffffffffff [ 220.742522] x17: 0000000000000000 x16: 00000000000007ff x15: ffff80008220dbf4 [ 220.742534] x14: 0000000000000000 x13: 000000000000036a x12: 00000000ffffffea [ 220.742546] x11: 0000000000000001 x10: 0000000000000001 x9 : ffff8000820c4838 [ 220.742559] x8 : 0000000000017fe8 x7 : c0000000ffffefff x6 : 0000000000057fa8 [ 220.742571] x5 : ffff0000e07d1488 x4 : 0000000000000000 x3 : ffff80005eab6000 [ 220.742583] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0000026e8000 [ 220.742595] Call trace: [ 220.742599] drm_atomic_helper_wait_for_vblanks.part.0+0x278/0x29c [ 220.742611] drm_atomic_helper_commit_tail_rpm+0x84/0xa0 [ 220.742623] commit_tail+0xa0/0x188 [ 220.742632] drm_atomic_helper_commit+0x16c/0x180 [ 220.742642] drm_atomic_commit+0xb4/0xec [ 220.742653] drm_client_modeset_commit_atomic+0x204/0x264 [ 220.742662] drm_client_modeset_commit_locked+0x5c/0x194 [ 220.742670] drm_fb_helper_pan_display+0xdc/0x214 [ 220.742682] fb_pan_display+0x98/0x110 [ 220.742692] bit_update_start+0x20/0x48 [ 220.742700] fbcon_switch+0x3e8/0x530 [ 220.742710] redraw_screen+0x148/0x244 [ 220.742720] fbcon_do_set_font+0x25c/0x344 [ 220.742730] fbcon_set_font+0x230/0x26c [ 220.742740] con_font_op+0x294/0x400 [ 220.742748] vt_ioctl+0xac8/0x1370 [ 220.742758] tty_ioctl+0x21c/0xa8c [ 220.742768] __arm64_sys_ioctl+0xa8/0xec [ 220.742780] invoke_syscall+0x48/0x110 [ 220.742792] el0_svc_common.constprop.0+0xc8/0xe8 [ 220.742802] do_el0_svc+0x20/0x2c [ 220.742810] el0_svc+0x30/0xd0 [ 220.742823] el0t_64_sync_handler+0x13c/0x158 [ 220.742829] el0t_64_sync+0x190/0x194 [ 220.742838] ---[ end trace 0000000000000000 ]--- 0 Quote
gene1934 Posted July 13, 2025 Posted July 13, 2025 I am one of your monthly contributors. I too seem to be subjected recently, noted after doing an apt upgrade. -y. I have a 5 volt 5 amp supply for the bpi-m5 psu plugged into the C port. booting is now both intermittent and several mintes to get started. I have a usb3 hub with 7 usb3 ports plugged into one of the usb3 ports on the bpi-m5. The last of many attempts to boot it worked after the long delay so I plugged the hubs src cable back in to see if something has failed in the 5, 4T drives currently plugged in for amanda's use. But that now gets me an error msg, something about config #1 is returning an error 110, which it did NOT do a couple months ago. And dmesg is only reporting 4 drives. All intended to be one logical volume. Any idea how to determine which of hose 5 drives has gone toes up? Thank you. Gene Heskett, CET. 0 Quote
gene1934 Posted July 13, 2025 Posted July 13, 2025 The drives are gigastones, made in Taiwan. Sata to usb3 Adaptor cables are latest StarTech's. I have had zero failures with that brand in over a decade of use here. 0 Quote
gene1934 Posted July 13, 2025 Posted July 13, 2025 just did another upgrade, 128 pkgs. no errors now but only 3 of the 5 drives show, but drives possibly too warm.drives are warm, need additional cooling. have 5" fan in front of enclosier but which pins do I connect it to? Or should I connect that big a fan direct to psu? 0 Quote
Igor Posted July 13, 2025 Posted July 13, 2025 6 hours ago, gene1934 said: Sata to usb3 Adaptor cables are latest StarTech's. I have had zero failures with that brand Some chips used in those usb2sata adaptors have issues combined with issues that are present on USB3 stack on some SoCs = troubles. Generally, USB3 storage solutions are to be avoided if possible. 0 Quote
c0rnelius Posted July 13, 2025 Posted July 13, 2025 I've seen this HDMI issue on some SM1 units, "TV Boxes". There is a REVERT floating around which resolves it, but was not accepted. https://lore.kernel.org/linux-arm-kernel/001401db8ed4$392ef030$ab8cd090$@martijnvandeventer.nl/T/ I've been currently using it on 6.12.y. I have no clue if the current STABLE kernel also has this problem. REVERT-clk-meson-g12a-Fix-kernel-warnings-when-no-display-attached.patch 0 Quote
gene1934 Posted July 14, 2025 Posted July 14, 2025 These are usb3 labeled adapters, I did have problems earlier on a pi3b using another brand of adapter, but these startech adapters have been bulletproof, for years. c0rnelius current kernel is .6.12.22-current-meson64, will this patch apply? I've also found data on these drives indicating a 20W peak power for write operations. My present drive psu is a pretty hot usb wall wort, so based on 5x20, I have a 100W rated supply from amazon should be here midweek, and which will also power a 5" fan in one end of the drive cage. Which should move enough air to cool the drives. The question is now about the 7 port usb3 hub, can it deliver the 4 amps per port these drives need during a wright operatoin. Probably can't be answered until I can get a scope on the line. And that won't be done till the far end of the week. ;o}... If & when i get the psu i'll likely be back with more pix. Thanks until then. . . Cheers Gene. 0 Quote
c0rnelius Posted July 14, 2025 Posted July 14, 2025 11 hours ago, gene1934 said: c0rnelius current kernel is .6.12.22-current-meson64, will this patch apply? Yeah it applies. [🔨] ├───────────────────────────┼─────────────────────┼───────────────── [🔨] │ REVERT-clk-meson-g12a-Fix │ (+6/-6)[1M] g12a.c │ Martijn van Deve [🔨] │ -kernel-warnings-when-no- │ │ clk: meson: g12a [🔨] │ display-attached │ │ kernel warnings [🔨] │ │ │ display attached [🔨] ├───────────────────────────┼─────────────────────┼───────────────── 0 Quote
