jgauthier Posted April 18, 2025 Posted April 18, 2025 1) What is the correct way to make kernel configuration changes? I have attempted to: ./compile.sh BOARD=bananapim4zero BRANCH=edge kernel-config saved config,. and then ./compile.sh BOARD=bananapim4zero BRANCH=edge kernel However,after installing the kernel I found the config changes were not applied. I then reran: ./compile.sh BOARD=bananapim4zero BRANCH=edge kernel-config and I see that the config changes I made have been reverted. 2) How to clean the kernel and force a rebuild? I tried ./compile.sh BOARD=bananapim4zero BRANCH=edge CLEAN_LEVEL="make-kernel" kernel But the kernel was not cleaned, nor rebuilt. Thank you! 0 Quote
Werner Posted April 19, 2025 Posted April 19, 2025 There is a write-up about this: https://zuckerbude.org/armbian-using-kernel-config/ Check the tl;dr: part. 0 Quote
jgauthier Posted April 19, 2025 Author Posted April 19, 2025 (edited) Understood. Thank you. When I follow that procedure, config settings are set to "Y" after I've explicitly set them to "N". After doing a kernel-config [🐳|🌱] Exporting new kernel defconfig [ /armbian/output/config/linux-sunxi64-edge.config ] [🐳|🔨] 'defconfig' -> '/armbian/output/config/linux-sunxi64-edge.config' [🐳|🌱] Exporting new kernel config - git commit pending [ /armbian/userpatches/linux-sunxi64-edge.config ] [🐳|🔨] 'defconfig' -> '/armbian/userpatches/linux-sunxi64-edge.config' $ cat output/config/linux-sunxi64-edge.config | grep CGROUP [no output] $ diff output/config/linux-sunxi64-edge.config userpatches/linux-sunxi64-edge.config [no output] Then I build the kernel, install it, and on the board: zcat /proc/config.gz |grep CGROUP_SC CONFIG_CGROUP_SCHED=y After reviewing the kernel build output: less -RS output/logs/log-kernel-7c3cd346-d31c-4166-9dc2-4f5c9c641554.log.ans --> (13) COMMAND: ./scripts/config --enable CGROUP_BPF --> (13) COMMAND: ./scripts/config --enable CGROUP_CPUACCT --> (13) COMMAND: ./scripts/config --enable CGROUP_DEVICE --> (13) COMMAND: ./scripts/config --enable CGROUP_FREEZER --> (14) COMMAND: ./scripts/config --enable CGROUP_HUGETLB --> (14) COMMAND: ./scripts/config --enable CGROUP_NET_CLASSID --> (14) COMMAND: ./scripts/config --enable CGROUP_NET_PRIO --> (14) COMMAND: ./scripts/config --enable CGROUP_PERF --> (14) COMMAND: ./scripts/config --enable CGROUP_PIDS --> (14) COMMAND: ./scripts/config --enable CGROUP_SCHED --> (14) COMMAND: ./scripts/config --enable CGROUPS Something has enabled everything I said I wanted disabled. When configuring the kernel subsequent times, these items are enabled again as well. Edited April 19, 2025 by jgauthier 0 Quote
Igor Posted April 19, 2025 Posted April 19, 2025 39 minutes ago, jgauthier said: these items are enabled again as well. There is another feature of framework, "armbian-kernel", sections that applies on top of (basic) configs: https://github.com/armbian/build/blob/main/lib/functions/compilation/armbian-kernel.sh#L205-L336 (Docker as example) 0 Quote
jgauthier Posted April 19, 2025 Author Posted April 19, 2025 I did see that script. I disabled CGROUP_SCHED by commenting it out. I don't think that is the "right way", but it worked for now. 0 Quote
