1) What is the correct way to make kernel configuration changes?
I have attempted to:
./compile.sh BOARD=bananapim4zero BRANCH=edge kernel-config
saved config,. and then
However,after installing the kernel I found the config changes were not applied.
I then reran:
and I see that the config changes I made have been reverted.
2) How to clean the kernel and force a rebuild?
I tried
./compile.sh BOARD=bananapim4zero BRANCH=edge  CLEAN_LEVEL="make-kernel" kernel
But the kernel was not cleaned, nor rebuilt.
Thank you!
Posted (edited)
Understood. Thank you.  When I follow that procedure, config settings are set to "Y" after I've explicitly set them to "N".
After doing a kernel-config
[🐳|🌱] Exporting new kernel defconfig [ /armbian/output/config/linux-sunxi64-edge.config ]
[🐳|🔨]   'defconfig' -> '/armbian/output/config/linux-sunxi64-edge.config'
[🐳|🌱] Exporting new kernel config - git commit pending [ /armbian/userpatches/linux-sunxi64-edge.config ]
[🐳|🔨]   'defconfig' -> '/armbian/userpatches/linux-sunxi64-edge.config'
$ cat output/config/linux-sunxi64-edge.config | grep CGROUP
[no output]
$ diff output/config/linux-sunxi64-edge.config userpatches/linux-sunxi64-edge.config
[no output]
Then I build the kernel, install it, and on the board:
zcat /proc/config.gz |grep CGROUP_SC
CONFIG_CGROUP_SCHED=y
After reviewing the kernel build output:
less -RS output/logs/log-kernel-7c3cd346-d31c-4166-9dc2-4f5c9c641554.log.ans
--> (13) COMMAND: ./scripts/config --enable CGROUP_BPF
--> (13) COMMAND: ./scripts/config --enable CGROUP_CPUACCT
--> (13) COMMAND: ./scripts/config --enable CGROUP_DEVICE
--> (13) COMMAND: ./scripts/config --enable CGROUP_FREEZER
--> (14) COMMAND: ./scripts/config --enable CGROUP_HUGETLB
--> (14) COMMAND: ./scripts/config --enable CGROUP_NET_CLASSID
--> (14) COMMAND: ./scripts/config --enable CGROUP_NET_PRIO
--> (14) COMMAND: ./scripts/config --enable CGROUP_PERF
--> (14) COMMAND: ./scripts/config --enable CGROUP_PIDS
--> (14) COMMAND: ./scripts/config --enable CGROUP_SCHED
--> (14) COMMAND: ./scripts/config --enable CGROUPS
Something has enabled everything I said I wanted disabled.
When configuring the kernel subsequent times, these items are enabled again as well.
Edited by jgauthier
