Bookworm no longer has a Release file
Go to solution Solved by Werner,
Hi there 👋, I'm attempting to update Armbian (apt update), but I get the follow error message:
Err:9 https://netcup-02.armbian.com/apt bookworm Release
  404  Not Found [IP: 2a0a:4cc0:c0:7deb::1 443]
Reading package lists... Done
E: The repository 'http://apt.armbian.com bookworm Release' no longer has a Release file.
It appears that the bookworm repo no longer contains any files:
https://netcup-02.armbian.com/apt/dists/bookworm/
Is the hostname I have configured still correct?
It's an issue on both of my servers running Armbian.
Thanks!
It happened to me yesterday, was ok, then happened again today. IS there some process wiping the directory and it stays wiped until the next sync or something?
In sources I have it set to apt.armbian.com and currently it redirects to http://netcup.armbian.com/apt. Indeed there the bookworm folder is empty.
Struggling with repo management for past few days. It would be nice to write it from scratch, but time is an issue :(
