Rogier Posted yesterday at 09:48 AM Posted yesterday at 09:48 AM Hi there 👋, I'm attempting to update Armbian (apt update), but I get the follow error message: Err:9 https://netcup-02.armbian.com/apt bookworm Release 404 Not Found [IP: 2a0a:4cc0:c0:7deb::1 443] Reading package lists... Done E: The repository 'http://apt.armbian.com bookworm Release' no longer has a Release file. It appears that the bookworm repo no longer contains any files: https://netcup-02.armbian.com/apt/dists/bookworm/ Is the hostname I have configured still correct? It's an issue on both of my servers running Armbian. Thanks! 0 Quote
Solution Werner Posted yesterday at 06:05 PM Solution Posted yesterday at 06:05 PM known issue. fix is underway 0 Quote
Stefal Posted 8 hours ago Posted 8 hours ago These directory are still empty: https://netcup-02.armbian.com/apt/dists/bookworm/ https://netcup.armbian.com/apt/dists/noble/ 0 Quote
jpegxguy Posted 7 hours ago Posted 7 hours ago It happened to me yesterday, was ok, then happened again today. IS there some process wiping the directory and it stays wiped until the next sync or something? In sources I have it set to apt.armbian.com and currently it redirects to http://netcup.armbian.com/apt. Indeed there the bookworm folder is empty. 0 Quote
