abcd567 Posted April 22, 2025 Posted April 22, 2025 WiFi is missing in "Armbian_25.5.0-trunk.428_Rpi4b_trixie_current_6.12.22_minimal.img" Solved by following commands ``` sudo apt update sudo apt install firmware-brcm80211 --fix-broken sudo reboot ``` 0 Quote
Werner Posted April 22, 2025 Posted April 22, 2025 Maybe related https://github.com/armbian/build/pull/8087 0 Quote
Igor Posted April 23, 2025 Posted April 23, 2025 Trixie ... let me check and fix this. I only tested Bookworm. 0 Quote
abcd567 Posted April 23, 2025 Author Posted April 23, 2025 Upgrading: pi@pi-1-Armbian-trixie:~$ apt list --upgradable armbian-bsp-cli-rpi4b-current/trixie 25.5.0-trunk.438 arm64 [upgradable from: 2> linux-dtb-current-bcm2711/trixie 25.5.0-trunk.438 arm64 [upgradable from: 25.5.> linux-image-current-bcm2711/trixie 25.5.0-trunk.438 arm64 [upgradable from: 25.> When issued command "sudo apt upgrade", upgrade did take place, but when it reached finishing stage, got following errors: Armbian 'linux-image-current-bcm2711' for '6.12.22-current-bcm2711': 'postinst' starting. update-initramfs: Generating /boot/initrd.img-6.12.22-current-bcm2711 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8156b-2.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8156a-2.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153c-1.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153b-2.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-4.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-3.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-2.fw for built-in driver r8152 ERROR: Unsupported initramfs version (6.12.22-current-bcm2711) ERROR: Unsupported kernel version (6.12.22-current-bcm2711) update-initramfs: Generating /boot/initrd.img-6.12.22-current-bcm2711 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8156b-2.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8156a-2.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153c-1.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153b-2.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-4.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-3.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-2.fw for built-in driver r8152 ERROR: Unsupported initramfs version (6.12.22-current-bcm2711) 0 Quote
Igor Posted April 23, 2025 Posted April 23, 2025 Warnings are safe to ignore, happens on other platforms too, but it looks like also error. CONFIG_USB_RTL8152=y -> m should probably do. I will make a config change: https://github.com/armbian/build/pull/8116 I have noticed the initramfs error too, but it doesn't looks it breaks anything. Need to be investigated. 0 Quote
abcd567 Posted April 23, 2025 Author Posted April 23, 2025 Thanks @Igor for your prompt attention and help. Yes, you are right. The error messages I posted in my last post do NOT break anything, but these are very irritating. 0 Quote
abcd567 Posted April 23, 2025 Author Posted April 23, 2025 (edited) Off-topic, but related to "trixie / sid" on RPi4 On a freshly written 64-bit raspberrypi os bookworm (Lite) image, replaced word "bookworm" by "trixie" in following two files: "/etc/apt/sources.list" and "/etc/apt/sources.list.d/raspi.list" . After above modifications, ran following commands: sudo apt update sudo apt full-upgrade sudo apt autoremove sudo apt autoclean sudo reboot The upgrade command took about half an hour to complete, and upgraded 470 packages. No issues during & after upgrade. Everything is OK. Edited April 23, 2025 by abcd567 0 Quote
Igor Posted April 24, 2025 Posted April 24, 2025 First problem was fixed in predicted way. There is no more firmware warnings on upgrade / kernel install. New package is getting to the stable repository in a couple of hours, while it is already present in beta. 10 hours ago, abcd567 said: but these are very irritating. Agree. While testing kernel, I installed Ubuntu Noble based image and ERROR: Unsupported initramfs version does not manifest there! I suspect this problem is caused by some script that is coming from RaspberryPi OS - on Debian based Armbian, we use userspace and Rpi related firmware packages from RPi OS (which is Bookworm based, so we have great / full packages compatibility). I will try to get to the bottom of this when possible. Basic problem is that in open source and especially in packages assemblies, there are always (tens of) thousands of potentially irritating issues. You noticed this one, we already have a list of many others that needs attention and there is endless list that well always be somewhere ... 0 Quote
