FrenzyBiscuit Posted April 25, 2025 Posted April 25, 2025 Can AVIF support be added to LibVIPS? It works fine on the amd64 version of Ubuntu 24.04, so I'm assuming Armbian needs to update the package. Current bug: Failed to process avif file version: unable to call heifsave_target heifsave: Unsupported compression It's not a HEIC image, this is how LibVIPS encodes AVIF files. 0 Quote
Igor Posted April 25, 2025 Posted April 25, 2025 7 hours ago, FrenzyBiscuit said: amd64 version of Ubuntu 24.04, so I'm assuming Armbian needs to update the package Armbian is assembled from Ubuntu or Debian packages. If problems is there, problem is here too and there is little we can do about. https://docs.armbian.com/#what-is-armbian We have a mechanism which you can use to insert patched package to our repository, which is in use in some corner cases: https://github.com/armbian/os/wiki Perhaps this is a solution, perhaps not depending on possible dependency nightmare. 0 Quote
ag123 Posted April 26, 2025 Posted April 26, 2025 apparently it needs libheif https://github.com/libvips/libvips try apt-cache search heif apt install libheif1 alternatively, there is libavif https://github.com/AOMediaCodec/libavif I'm using libavif, built that from source, but you can nevertheless try sudo apt install libavif15 libavif-bin libavif-dev 0 Quote
laibsch Posted April 27, 2025 Posted April 27, 2025 @OP: you need to give more info - what board? - what user space (Ubuntu or Debian, what release)? You said this works on Ubuntu. That was not an SBC? Edit: This issue is known upstream. Ubuntu does not have a delta to Debian and hence should be affected as well. In any case, there is not much Armbian can or is likely going to do. 0 Quote
