Char11e Posted 10 hours ago Posted 10 hours ago (edited) The eth0 device does not work when using 6.1.47-current-sunxi64 and 6.12.20-current-sunxi64 kernels. There will be the following errors in the kernel log. pi@orangepi3:~$ dmesg | grep eth0 [ 16.997431] dwmac-sun8i 5020000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 16.998219] dwmac-sun8i 5020000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19) [ 19.284111] dwmac-sun8i 5020000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 19.284754] dwmac-sun8i 5020000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19) [ 19.308140] dwmac-sun8i 5020000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 19.308738] dwmac-sun8i 5020000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19) [ 19.334063] dwmac-sun8i 5020000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 19.334754] dwmac-sun8i 5020000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19) [ 19.358727] dwmac-sun8i 5020000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 19.359417] dwmac-sun8i 5020000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19) [ 151.380407] dwmac-sun8i 5020000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 151.381105] dwmac-sun8i 5020000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19) [ 157.928629] dwmac-sun8i 5020000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 157.929360] dwmac-sun8i 5020000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19) [ 320.009515] dwmac-sun8i 5020000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 320.010271] dwmac-sun8i 5020000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19) [ 320.037458] dwmac-sun8i 5020000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 320.038169] dwmac-sun8i 5020000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19) [ 320.062716] dwmac-sun8i 5020000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 320.063428] dwmac-sun8i 5020000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19) [ 320.082662] dwmac-sun8i 5020000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 320.083389] dwmac-sun8i 5020000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19) Edited 10 hours ago by Char11e 0 Quote
Werner Posted 10 hours ago Posted 10 hours ago Hi Providing logs with PASTE_SERVER_HOST=paste.armbian.de armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
Char11e Posted 10 hours ago Author Posted 10 hours ago @Werner Got it! Thank you for your help. https://paste.armbian.com/idomububex Provided the link. 0 Quote
Char11e Posted 10 hours ago Author Posted 10 hours ago (edited) Now I am trying to downgrade Kernel back to 5.51.X and figure out it. Edited 10 hours ago by Char11e 0 Quote
Solution Werner Posted 10 hours ago Solution Posted 10 hours ago Great. Just to avoid cross-contamination. You are sure you have the Orange Pi 3 and not the Orange Pi 3 LTS model? Background: OrangePi naming scheme is kind a ridiculous, makes no sense often enough and introduces confusion. In this particular case they switch to a different PHY chip which I think was migitated by Armbian but not sure if they still have separate images. Seems like a similar topic already exists: https://forum.armbian.com/topic/34024-cannot-attach-to-phy-after-upgrade-to-202381/ 0 Quote
Char11e Posted 10 hours ago Author Posted 10 hours ago @Werner Yes, My SBC model is "OrangePi3", not LTS. 0 Quote
Char11e Posted 9 hours ago Author Posted 9 hours ago @Werner I will close this Topic and discuss the issue in the old one. 0 Quote
