Skip to content
View in the app
Armbian Community Forums
Is Docker available?
Featured Replies
Hello there,
I recently gained remote access to a Banana Pi F3 to test it, and everything went smoothly.
The board was running Bianbu Linux, and I was able to install and use Docker without issues.
Now, I'm considering purchasing the board and was wondering if the Armbian image would also support running Docker.
Do you have any insights on this?
Thanks!
Latest image:
patrick@bananapif3:~$ sudo docker run hello-world
[sudo] password for patrick:
Unable to find image 'hello-world:latest' locally
latest: Pulling from library/hello-world
2382d725750e: Pull complete
Digest: sha256:dd01f97f252193ae3210da231b1dca0cffab4aadb3566692d6730bf93f123a48
Status: Downloaded newer image for hello-world:latest
Hello from Docker!
This message shows that your installation appears to be working correctly.
3 hours ago, gounthar said:
on Trixie
Here some troubles are expected ... Can you try manual steps to install docker by follow:
https://github.com/armbian/configng/blob/main/tools/modules/software/module_docker.sh#L26-L56
installing packages, adding to group, adding docker bridge.
This might reveal more.
BTW. My F3 died - waiting for replacement.
  • Author
Thanks a lot for your help, Igor.
That did not make the trick, as the available packages are still in the old form (docker.io instead of docker-ce for example.
Nonetheless, I now have a working (but old) docker binary, which is enough for my use case.
Now, I will try to build a more recent docker binary.
The next problem to solve will be to get the NVMe to work.
I'm sorry your F3 died.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
