Running Armbian build on x86-64
Go to solution Solved by Werner,
I'm now trying to run the armbian build framework on a x64 PC. I have a NUC14 running Ubuntu 25.04 and have installed docker.io.
But when I try to build, it seems like it thinks I'm on an arm64 PC?
[🐳|🌱] Starting main configuration
[🐳|🌱] Using REVISION from [ main VERSION file: '25.08.0-trunk' ]
[🐳|🌿] Enabling extension [ armbian-config ]
[🐳|🌱] Sourcing family configuration [ /armbian/config/sources/families/rockchip-rk3588.conf ]
[🐳|🌿] Enabling extension [ rkbin-tools ]
[🐳|🌱] Determined BOOT_SOC from BOOTCONFIG [ BOOT_SOC: 'rk3588'; BOOTCONFIG: 'rock-5c-rk3588s_defconfig' ]
[🐳|] change-tracking: after sourcing family config [ KERNEL_MAJOR_MINOR='6.14' ]
[🐳|] change-tracking: after sourcing family config [ LINUXFAMILY='rockchip64'  # (was: 'rockchip-rk3588') ]
[🐳|] change-tracking: after sourcing family config [ LINUXCONFIG='linux-rockchip64-edge' ]
[🐳|] change-tracking: after sourcing family config [ BOOTSOURCE='https://github.com/radxa/u-boot.git' ]
[🐳|] change-tracking: after sourcing family config [ BOOTBRANCH='branch:next-dev-v2024.10' ]
[🐳|] change-tracking: after sourcing family config [ BOOTPATCHDIR='legacy/u-boot-radxa-rk35xx' ]
[🐳|] change-tracking: after sourcing family config [ NETWORKING_STACK='network-manager' ]
[🐳|🌱] Sourcing arch configuration [ arm64.conf ]
[🐳|🌱] Using NETWORKING_STACK [ NETWORKING_STACK: network-manager ]
[🐳|🌱] Adding networking extensions [ net-network-manager, net-chrony ]
[🐳|🌿] Enabling extension [ net-network-manager ]
[🐳|🌿] Enabling extension [ net-chrony ]
[🐳|🌱] Extension manager [ processed 16 Extension Methods calls and 27 Extension Method implementations ]
[🐳|🌱] rockchip64_common: defaulting SERIALCON [ Setting SERIALCON to ttyS2 for BRANCH='edge' ]
[🐳|🌱] Extension: net-chrony: Adding extra package to image [ chrony ]
[🐳|🌱] Extension: net-network-manager: Adding extra packages to image [ network-manager network-manager-openvpn netplan.io ]
[🐳|🌱] Extension: net-network-manager: Adding extra packages for Ubuntu to image [ network-manager-config-connectivity-ubuntu ]
[🐳|🌱] KERNELPATCHDIR is unset; using 'archive/rockchip64-6.14' [ common_defaults_for_mainline ]
[🐳|🌱] mainline-kernel: default to branch / rolling stable version [ Using KERNELBRANCH='branch:linux-6.14.y' for KERNEL_MAJOR_MINOR='6.14' ]
[🐳|] change-tracking: after late_family_config hooks [ KERNELSOURCE='https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git' ]
[🐳|] change-tracking: after late_family_config hooks [ KERNELBRANCH='branch:linux-6.14.y' ]
[🐳|] change-tracking: after late_family_config hooks [ KERNELPATCHDIR='archive/rockchip64-6.14' ]
[🐳|] change-tracking: after late_family_config hooks [ KERNEL_PATCH_ARCHIVE_BASE='rockchip64' ]
[🐳|] change-tracking: after late_family_config hooks [ BOOTDIR='u-boot' ]
[🐳|] change-tracking: before handling KERNEL_MAJOR_MINOR in config_post_main [ BOOTSOURCEDIR='u-boot-worktree/u-boot/next-dev-v2024.10' ]
[🐳|] change-tracking: before calling extension_finish_config [ LINUXSOURCEDIR='linux-kernel-worktree/6.14__rockchip64__arm64' ]
[🐳|🌱] Configuration prepared for BOARD build [ rock-5c.conf ]
[🐳|] Repeat Build Options (early) [ ./compile.sh build BOARD=rock-5c BRANCH=edge BUILD_DESKTOP=no BUILD_MINIMAL=no KERNEL_CONFIGURE=no RELEASE=noble ]
[🐳|🌱] Checked directory OK for mount options [ /armbian/.tmp ('main temporary dir') ]
[🐳|🌱] Preparing [ host ]
[🐳|🌱] Running in container [ Adding provisions for container building ]
[🐳|🌱] Python2 not available on host release 'noble' [ ancient u-boot versions might/will fail to build ]
[🐳|🌱] Ignoring toolchains [ SKIP_EXTERNAL_TOOLCHAINS: yes ]
[🐳|🌱] Cross arch build [ target arm64 on host amd64 ]
[🐳|💥] Failed to update binfmts [ update-binfmts --enable qemu-arm ]
[🐳|💥] Failed to update binfmts [ update-binfmts --enable qemu-aarch64 ]
[🐳|💥] Failed to update binfmts [ update-binfmts --enable qemu-riscv64 ]
[🐳|🌱] checking [ arch-test for 'arm64' ]
[🐳|🔨]   arm64: not supported on this machine/kernel
[🐳|💥] Error 1 occurred in main shell [ at /armbian/lib/functions/logging/runners.sh:211
    run_host_command_logged_raw() --> lib/functions/logging/runners.sh:211
        run_host_command_logged() --> lib/functions/logging/runners.sh:193
       prepare_host_binfmt_qemu() --> lib/functions/rootfs/qemu-static.sh:94
    prepare_host_noninteractive() --> lib/functions/host/prepare-host.sh:120
                do_with_logging() --> lib/functions/logging/section-logging.sh:81
                   prepare_host() --> lib/functions/host/prepare-host.sh:17
              prepare_host_init() --> lib/functions/main/start-end.sh:64
       main_default_start_build() --> lib/functions/main/start-end.sh:17
          do_with_default_build() --> lib/functions/main/default-build.sh:41
         cli_standard_build_run() --> lib/functions/cli/cli-build.sh:25
        armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136
                 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176
                           main() --> compile.sh:50
[🐳|💥] Cleaning up [ please wait for cleanups to finish ]
Try running:
./compile.sh requirements
And then try again.
I think we generated a regression when switching to Ubuntu Noble Docker image.
It looks like the problem is Ubuntu 25.04. I thought it would work if I used Docker instead of native OS build support.
steven@nuc14e:~/build$ sudo ./compile.sh requirements
[🌱] Extension manager [ processed 4 Extension Methods calls and 12 Extension Method implementations ]
[🌱] Build host OS release [ plucky ]
[🌱] Build host architecture [ amd64 ]
[💥] error! [ Unsupported build system: 'plucky'  ]
[💥] Exiting with error 43 [ at /home/steven/build/lib/functions/logging/traps.sh:1
                exit_with_error() --> lib/functions/logging/traps.sh:1
   obtain_and_check_host_release_and_arch() --> lib/functions/host/host-release.sh:41
           cli_requirements_run() --> lib/functions/cli/cli-requirements.sh:30
                           main() --> ./compile.sh:50
[💥] Cleaning up [ please wait for cleanups to finish ]
  • Solution
Install qemu-user-static package and retry
Posted (edited)
Quote
Can you please explain what you mean by this ? Am I supposed to install it on the host ? If so, this solution is not working for me.
I am trying to compile armbian with docker from arch, it worked a few months ago (commit from February 2025) but now it doesn't (commit from August)
Same error as original poster.
Edited by dwarfman78
Yes. Installing this package on Debian-based build hosts fixed the issue.
I don't think we have any developers using Arch so there aren't much tests of any other distros to ensure compatibility. Main focus is on Noble.
If there is an equivalent package for arch try installing on the host machine and retry. Having it inside the docker container may not be enough.
