salas Posted Monday at 11:35 PM Posted Monday at 11:35 PM Is there any working image for orangepi5-pro? I am having trouble to understand a few things in the https://www.armbian.com/orange-pi-5-pro/ It says: Quote PCI support is broken on vendor kernel (6.1.xx) on versions higher then 24.8.1. Use this version and freeze kernel (armbian-config -> system) prior to updating OS. PCI works on other Rockchip 3588 devices, while fixing this on all represent expensive technical challenge which we will be able to proceed once your donations for entire project reaches at least 1000 USD per month. With Orangepi devices we have extremely high negative support budget. Alternative operating systems that relies on our work face the same problem. We appreciate for your understanding. But downloding the image on that page brings Armbian_community_25.8.0-trunk.38_Orangepi5pro_bookworm_vendor_6.1.115_minimal.img.xz which is version 25.8.0 and that image wont boot. 0 Quote
Michael Robinson Posted Tuesday at 03:41 AM Posted Tuesday at 03:41 AM https://github.com/armbian/build/ 0 Quote
Werner Posted Tuesday at 03:43 AM Posted Tuesday at 03:43 AM Check assets at community releases as csc hw is ususally not on mirrors but on GH: https://github.com/armbian/community/releases 0 Quote
salas Posted Tuesday at 09:29 AM Author Posted Tuesday at 09:29 AM Hi @Michael Robinson, thanks for the help, but one of the first things i did was check the build process. Unfortunately there is no orangepi5-pro board in the v24.8.1 branch which makes that warning about 24.8.1 version even hard to understand. I tried to compile new versions, but none of those new versions boot. Hi @Wernerthanks for the tip, but unfortunately the oldest version on github is 24.11 and they do not boot 0 Quote
Werner Posted Tuesday at 11:53 AM Posted Tuesday at 11:53 AM https://debug.armbian.de for obtaining low level logs to debug further. 0 Quote
CNCJIM Posted Friday at 06:21 PM Posted Friday at 06:21 PM I have an Orange Pi 5 pro - with a 256GB M.2 SSD drive - I have kernel 6.115 running . Booting from SD - root is mounted on nvme0n1p1 (the SSD). Armbian 25.8.0-trunk53.-bookworm. I have three issues with this - 1:- no audio out of the 3.5 inch jack. 2: No internal Bluetooth 3. Have to use the SD card for initial boot. PCI is working on that version. I would like to use the RT-Pre-emptive kernel. It doesn't seem to be available. And the 6.1.2 kernel images do not find the SSD drive at all on orange pi 5 pro. 0 Quote
Werner Posted yesterday at 04:13 AM Posted yesterday at 04:13 AM 9 hours ago, CNCJIM said: 1:- no audio out of the 3.5 inch jack. I assume should work with vendor. Maybe missing node in device tree. 9 hours ago, CNCJIM said: 2: No internal Bluetooth Maybe missing firmware blobs or same as above. 9 hours ago, CNCJIM said: 3. Have to use the SD card for initial boot. Expected since neither SPI nor eMMC are present by default. Direct boot from NVMe isn't support by any Rockchip soc. 0 Quote
