Abdullah Seba Posted September 23, 2017 Posted September 23, 2017 Hi I'm a newbie to Armbian and just got the Orange Pi Zero. I want it to behave as a keyboard on the OTG port. Right now it works as a serial console. I cant find any docs on this anywhere and I'm not clued up on Linux to mess around too much Can any one help? Thanks in advance.
MitchD Posted September 24, 2017 Posted September 24, 2017 Which kernel are you using? If you are using mainline, I understand than the OTG options aren't there yet. If on legacy, you can try: modprobe -r g_serial followed by: modprobe g_hid From there, see if any new devices are created. Full documentation is here: https://www.kernel.org/doc/Documentation/usb/gadget_hid.txt 1
Abdullah Seba Posted September 24, 2017 Author Posted September 24, 2017 Just now, MitchD said: Which kernel are you using? If you are using mainline, I understand than the OTG options aren't there yet. If on legacy, you can try: modprobe -r g_serial followed by: modprobe g_hid From there, see if any new devices are created. Full documentation is here: https://www.kernel.org/doc/Documentation/usb/gadget_hid.txt Thanks for replying. I'm using the latest from here https://www.armbian.com/orange-pi-zero/ marked as legacy stable. Not sure what kernel it's using. I tried `modprobe -r g_serial` and got: `modprobe: FATAL: Module g_serial is in use.` I tried with the otg port plugged in and unplugged. `modprobe g_hid` returned `modprobe: ERROR: could not insert 'g_hid': No such device`
MitchD Posted September 24, 2017 Posted September 24, 2017 Sorry, put sudo before those commands and run them again. It must be run as root. I'll try with a legacy stable image tonight and see if I can get it operational.
Abdullah Seba Posted September 24, 2017 Author Posted September 24, 2017 10 minutes ago, MitchD said: Sorry, put sudo before those commands and run them again. It must be run as root. I'll try with a legacy stable image tonight and see if I can get it operational. Same thing happened. Thanks
MitchD Posted September 25, 2017 Posted September 25, 2017 Looks like g_hid is broken on this build of armbian. Not sure why this hasn't been patched yet.
Igor Posted September 25, 2017 Posted September 25, 2017 Try toggling: https://github.com/armbian/build/blob/master/config/fex/orangepizero.fex#L504 3 hours ago, MitchD said: Not sure why this hasn't been patched yet. Afaik it should work. Perhaps unloading is not working as it should. This kernel is from some other times ... removal from /etc/modules and reboot might be needed. Nobody is working on H3 legacy kernels anymore Modern kernel will be here soon. @Abdullah Seba Technical support is our free will. Our expense and we tend to rest on Sundays. 2
zador.blood.stained Posted September 25, 2017 Posted September 25, 2017 7 hours ago, MitchD said: Looks like g_hid is broken on this build of armbian. Not sure why this hasn't been patched yet. https://github.com/armbian/build/issues/593 1
Abdullah Seba Posted September 25, 2017 Author Posted September 25, 2017 Hmm thanks for everyone's help I'll have to wait I guess.
Abdullah Seba Posted September 25, 2017 Author Posted September 25, 2017 modprobe -r g_serial seems to work on the beta version but the serial concoction get lost and ssh doesn't work...
Selda_bagcan Posted September 26, 2017 Posted September 26, 2017 Hello, i have been looking into this subject lately but couldn't find something useful. I want to be able to act as a mouse and keyboard with opi zero. I have some experience with programming and a bit of linux ecosystem so i i think i can look into/follow some stuff if you guide me. Also i know its off-topic but does gpio pins have any latency on them? I want to share data in real time between opi zero and rpi zero. Thank you for your attention. Sincerly
Selda_bagcan Posted October 10, 2017 Posted October 10, 2017 Any news on this subject? Legacy kernel doesnt work either. I thought that 4.13 would bring hid-gatget mode too.
