Sagman33 Posted June 3, 2025 Posted June 3, 2025 OdroidHC4 Petitboot Flushed, system rebooted to SD card (good quality). No keyboard function to input root password to continue. I verified IP using AngryIP. Tried to connect via Putty, but errors in selecting key. I'm new to SMB and SOC. Intended system to use with OMV as a NAS (image used is Bookworm minimal for OMV). Need help to proceed. Thanks 0 Quote
Igor Posted June 4, 2025 Posted June 4, 2025 Thank you for reporting. 9 hours ago, Sagman33 said: Need help to proceed. If current images have troubles, you can try to use previous ones. There is a link on the download pages or you can find them this way. https://forum.armbian.com/topic/52406-helios-64-fails-to-boot-since-upgrading-to-bookworm/#comment-219614 Which works best for your case, you will need to find on your own. We don't store this information / forum search might help. Similar goes with 3rd party images - most are Armbian based and none is in perfect state, things break apart all the time. By providing logs (if possible) someone might give you hints to workaround the problem, without hardly. As I understand from your report - image boots, but USB port doesn't work to enter password? And also network is down, so you can't login remote. I haven't tested HC4 on last builds, but C4 works just fine. In any case, fixing the problem can take some time - Hardkernel never supported our work, so we don't have active maintainer at stand by. It depends on volunteers that read this forum. When they notice and found time to look into this. 0 Quote
