Why does HDMI Audio work on Debian 12 Bookworm 6.1 version and not on Debian 12 Bookworm 6.12? I have updated to latest version and still no HDMI audio. Is there a patch or something i can do to fix this?
Perhaps same bits are missing in 5b device tree?
https://github.com/armbian/build/blob/main/patch/kernel/archive/rockchip64-6.12/rk3588-1020-Add-HDMI-and-VOP2-to-Rock-5A.patch
If you get it working, make a patch and push it here: https://github.com/armbian/build/tree/main/patch/kernel/archive/rockchip64-6.12
Thanks I saw that patch but have no idea how to apply it or what to do with it or if it even works in this version? If someone could help that would be great!
I have decompiled the dtb file but am unable to incorporate the patch. How do i incorporate the patch or change it? In terms for a newbie please! I should say it is for debian 12 Cinnamon 6.12.
hi, I have the hdmi issue in uefi-x86 on intel nuc10 minipc - now testing it from fast sandisk microsd in usb3 reader, thats quite fast (after few issues with overheating and slow verbatim and kingston flash keys)
this is armbianmonitor output
https://paste.armbian.com/jidekuvaza
here I tried to ask machine for possible issues and from some detection, it says that my TV is not reporting in EDID any audio?? in windows it works, so may be its something missing? first try to add some forcing to grub didnt helped ...
https://chatgpt.com/share/68836e5f-9e4c-8000-8874-46ea35a07331
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC256 Analog [ALC256 Analog]
  Subdevices: 0/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [Beyond TV]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
falken@uefi-x86:~$ xrandr --verbose | grep -A20 HDMI
    subconnector: HDMI
        supported: Unknown, VGA, DVI-D, HDMI, DP, Wireless, Native
    link-status: Good
        supported: Good, Bad
    CTM: 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0
        0 1
    CONNECTOR_ID: 99
        supported: 99
    non-desktop: 0
        range: (0, 1)
  1920x1200 (0x45) 154.000MHz +HSync -VSync *current +preferred
        h: width  1920 start 1968 end 2000 total 2080 skew    0 clock  74.04KHz
        v: height 1200 start 1203 end 1209 total 1235           clock  59.95Hz
  1920x1080 (0x46) 148.500MHz -HSync -VSync
        h: width  1920 start 2008 end 2052 total 2200 skew    0 clock  67.50KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  60.00Hz
  1920x1080 (0x47) 148.500MHz +HSync +VSync
        h: width  1920 start 2448 end 2492 total 2640 skew    0 clock  56.25KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  50.00Hz
  1680x1050 (0x48) 119.000MHz +HSync -VSync
        h: width  1680 start 1728 end 1760 total 1840 skew    0 clock  64.67KHz
        v: height 1050 start 1053 end 1059 total 1080           clock  59.88Hz
    Clones:     HDMI-1
    CRTC:       1
    CRTCs:      0 1 2
    Transform:  1.000000 0.000000 0.000000
                0.000000 1.000000 0.000000
                0.000000 0.000000 1.000000
               filter:
    EDID:
        00ffffffffffff006318512800000100
        141d0103807944780a0dc9a057479827
        12484c2108008140a940818081c0a9c0
        01010101010108e80030f2705a80b058
        8a00b9a84200001e023a801871382d40
        582c4500b9a84200001e000000fc0042
        65796f6e642054560a202020000000fd
        00324b1e503c000a202020202020017d
        020367f15261605f6665909f05140413
        1221225e625d20320907071517505517
        016704033d07c05f7e0183010000e200
        cb6e030c002000b84421008001020304
        68d85dc40178880702e305e301e20f1b
    subconnector: HDMI
    link-status: Good
        0 1
    CONNECTOR_ID: 112
        supported: 112
    non-desktop: 0
        range: (0, 1)
  3840x2160 (0x58) 594.000MHz +HSync +VSync +preferred
        h: width  3840 start 4016 end 4104 total 4400 skew    0 clock 135.00KHz
        v: height 2160 start 2168 end 2178 total 2250           clock  60.00Hz
  4096x2160 (0x59) 594.000MHz +HSync +VSync
        h: width  4096 start 4184 end 4272 total 4400 skew    0 clock 135.00KHz
  4096x2160 (0x5a) 594.000MHz +HSync +VSync
        h: width  4096 start 5064 end 5152 total 5280 skew    0 clock 112.50KHz
        v: height 2160 start 2168 end 2178 total 2250           clock  50.00Hz
  4096x2160 (0x5b) 593.407MHz +HSync +VSync
        h: width  4096 start 4184 end 4272 total 4400 skew    0 clock 134.87KHz
        v: height 2160 start 2168 end 2178 total 2250           clock  59.94Hz
HDMI-1 disconnected (normal left inverted right x axis y axis)
    Identifier: 0x43
    Timestamp:  5494311
    Subpixel:   unknown
    Clones:     DP-2
    CRTCs:      0 1 2
               filter:
    HDCP Content Type: HDCP Type0
        supported: HDCP Type0, HDCP Type1
    Content Protection: Undesired
        supported: Undesired, Desired, Enabled
    max bpc: 12
        range: (8, 12)
    content type: No Data
        supported: No Data, Graphics, Photo, Cinema, Game
    Colorspace: Default
        supported: Default, SMPTE_170M_YCC, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, opRGB, BT2020_CYCC, BT2020_RGB, BT2020_YCC, DCI-P3_RGB_D65, DCI-P3_RGB_Theater
    aspect ratio: Automatic
wow, the help from chatgpt is in fact quite good ... I now unmuted that SPDIF in alsamixer and tried also to change the pavucontrol configuration profile for something with digital hdmi (but this is NOT necessary ... its all really in the alsamixer unmuting that primary SPDIF - which is reverted to MM with some changes to pavucontrol profile !!) - pavucontroll still shows "headphones" but the audio goes to the hdmi out playing video ... that manual adding of sink to pa probably helped - internal PCI audio shows as "built in audio analog stereo" and the hdmi tv output shows in pa as "builtin audio" ... uff, that audio channels naming ...
excuse me, I am linux newbie in this area completelly, may be it was obvious for some, ... quite mess for me
but okay, loading module, unmuting spdif ... will see
Petr
