geotravel Posted October 3, 2017 Posted October 3, 2017 Hi, I have today on ma Orange Pi Zero switch kernel from dev 4.11.12 to NEXT kernel 4.13.4 and notice that defined modules in /etc/modules file are not loaded during start system I must manually load and in log system: 0.002070] CPU: Testing write buffer coherency: ok [ 0.002628] /cpus/cpu@0 missing clock-frequency property [ 0.002662] /cpus/cpu@1 missing clock-frequency property [ 0.002692] /cpus/cpu@2 missing clock-frequency property [ 0.002725] /cpus/cpu@3 missing clock-frequency property and armbianmonitor don't show CPU frequency but on kernel 4.11.12 was OK I know that NEXT kernel for tests, for this reason, I sen only my feedback Regards
raschid Posted October 8, 2017 Posted October 8, 2017 Compiling a NEXT kernel now will give you CPU frequency scaling for the Opi Zero - up to 1200 MHz. I upgraded an existing 4.11.12 install via freshly compiled kernel-debs (dtb,header,image). Tested overlays: spi, analog-codec, ubhost2, usbhost3. Issues: the already poor WLAN performance seems to have suffered some more => RX: 3mbit/s, TX: 9mbit/s (down from 10/13 mbit/s)
Igor Posted October 9, 2017 Posted October 9, 2017 Thanks for a checkup. 12 hours ago, raschid said: Issues: the already poor WLAN performance seems to have suffered some more => RX: 3mbit/s, TX: 9mbit/s (down from 10/13 mbit/s) 1 There will be no further Opi Zero wifi driver development.
geotravel Posted October 9, 2017 Author Posted October 9, 2017 Today I have updated my OPiZero to ARMBIAN 5.33.171010 nightly Debian GNU/Linux 8 (jessie) 4.13.5-sunxi and cpufreq is visible in armbianmonitor but in messages from dmesg still: [ 0.002072] CPU: Testing write buffer coherency: ok [ 0.002630] /cpus/cpu@0 missing clock-frequency property [ 0.002665] /cpus/cpu@1 missing clock-frequency property [ 0.002698] /cpus/cpu@2 missing clock-frequency property [ 0.002733] /cpus/cpu@3 missing clock-frequency property Thank you
raschid Posted October 9, 2017 Posted October 9, 2017 @IgorThe for the performance drop seems to be a missing interrupt definition in the device tree. @geotravelI am getting the same dmesg warnings, but frequency scaling (and thermals!) work.
Igor Posted October 9, 2017 Posted October 9, 2017 4 minutes ago, raschid said: @IgorThe for the performance drop seems to be a missing interrupt definition in the device tree. Thank you for the tip. If anyone wants to have this problem fixed in less than one year: https://docs.armbian.com/Process_Contribute
raschid Posted October 9, 2017 Posted October 9, 2017 @Igor quick fix (fix-xradio-interrupt.patch): diff --git a/arch/arm/boot/dts/sun8i-h2-plus-orangepi-zero.dts b/arch/arm/boot/dts/sun8i-h2-plus-orangepi-zero.dts index 454408b..df356b5 100644 --- a/arch/arm/boot/dts/sun8i-h2-plus-orangepi-zero.dts +++ b/arch/arm/boot/dts/sun8i-h2-plus-orangepi-zero.dts @@ -49,6 +49,7 @@ #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/input/input.h> +#include <dt-bindings/pinctrl/sun4i-a10.h> / { model = "Xunlong Orange Pi Zero"; @@ -157,6 +158,10 @@ */ xr819: sdio_wifi@1 { reg = <1>; + compatible = "xradio,xr819"; + interrupt-parent = <&pio>; + interrupts = <6 10 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "host-wake"; }; }; performance is back up to around 10 mbit/s ... (PCB rev 1.1). 1
martinayotte Posted October 9, 2017 Posted October 9, 2017 Good catch ! Those lines were there when we were on 4.11.x ... That means nobody seen that those were missing in NEXT 4.13 ! 1
geotravel Posted October 12, 2017 Author Posted October 12, 2017 I have use kernel 4.13.5 from 10 October update with WIF setup and I have seen a lot of the messages after command "dmesg": ..... [63639.603942] xradio_wlan mmc1:0001:1: missed interrupt [63983.021823] xradio_wlan mmc1:0001:1: missed interrupt [65262.383433] xradio_wlan mmc1:0001:1: missed interrupt [66343.960082] xradio_wlan mmc1:0001:1: missed interrupt ........
geotravel Posted October 16, 2017 Author Posted October 16, 2017 Today I made updates (apt update; apt upgrade) from 4.13.5 to kernel 4.13.7 and after restarting my Orange Pi Zero did not start up I have an SD card archive before updating so I can restore system
geotravel Posted October 16, 2017 Author Posted October 16, 2017 I don't have connected serial console.
geotravel Posted October 16, 2017 Author Posted October 16, 2017 I have review syslog and messages under linux mounted SD card from Orange Pi zero and I have found message logger: Can not find script.bin Ensure boot partition is mounted
Igor Posted October 16, 2017 Posted October 16, 2017 2 hours ago, geotravel said: I have review syslog and messages under linux mounted SD card from Orange Pi zero and I have found message This could mean you made some ugly upgrade from old 3.4.113 kernel to NEXT 4.13.x and further ? ... without actually removing the old one and when apt update is issued, kernel package that is updated last, takes the lead.
geotravel Posted October 16, 2017 Author Posted October 16, 2017 Ok I have found the problem with the update to 4.13.7 . Short history my test system on Orange Pi Zero I have installed Armbian Jessie dev with kenel v4.11.5 Next, I have switch in armbian-config to nightly build kernel After a few updates kernel 4.12. I have switch in armbina-config to NEXT kernels I have updated regularly kernel with version 4.13.x to 4.13.5 During use kernel 4.13.5 I have solved a problem with WIFI use when unplugging ethernet cable WIFI stopped working. I have found a solution that I need set metric higher for WIFI than ethernet. I have use package 'ifmetric' and put in /etc/network/interfaces in a definition of each interface for ethernet metric 20 and for WIFI metric 10 After this, all working perfectly without any problems Today after update to 4.13.7 it looks that 'metric' is a problem for setup interface and for this reason system startup but without any network interface. If I put # before metric for eth0 and wlan0 system with kernel 4.13.7 startup network interfaces. It looks like I can not use 'metric' in /etc/network/interfaces with kernel 4.13.7 and I must restore my backup system with kernel 4.13.5 where all working. Information about ifmetric: https://www.debian.org/doc/manuals/debian-reference/ch05.en.html#_the_ifmetric_package (Sorry for my English is not perfect )
geotravel Posted October 16, 2017 Author Posted October 16, 2017 I have try add in /etc/network/interfaces add line: up ifmetric eth0 20 My whole define eth0: auto lo iface lo inet loopback auto eth0 allow-hotplug eth0 iface eth0 inet static address 172.16.1.2 netmask 255.255.255.0 gateway 172.16.1.1 dns-nameservers 8.8.8.8 8.8.4.4 If I add on end this "metric 20" or "up ifmetric eth0 20" during start up system I don't have network But with kernel 4.13.5 working without problem ad set up metric value 20 for eth0
geotravel Posted October 17, 2017 Author Posted October 17, 2017 I found similar problem described in DietPi distribution https://github.com/Fourdee/DietPi/issues/515 with use ifmetric tools in /etc/network/interfaces . I can not understand why is problem with kernel 4.13.7 when we look in file /etc/network/if-up.d/ exist script ifmetric
Igor Posted October 17, 2017 Posted October 17, 2017 It's pretty pointless to compare RPi kernel 4.4 with a just-released modern kernel for H3. Perhaps and it's possible that something needed is missing. Then I am not sure you are using Ubuntu or Debian based base. This usually brings some difference. Is it hard to type armbianmonitor -u (which save a lot of our time) before asking questions? What exactly you are trying to achieve? Perhaps you are using wrong tools?
geotravel Posted October 17, 2017 Author Posted October 17, 2017 I have use Welcome to ARMBIAN 5.33.171017 nightly Debian GNU/Linux 8 (jessie) 4.13.7-sunxi I need set up metric value for eth0 20 and for wlan0 10 Typical tool is 'ifmetric' and I can put in /etc./network.interfaces in definition of interface like eth0 and wlan0 different value of metric . Quote The ifmetric package enables us to manipulate metrics of routes a posteriori even for DHCP. The following sets the eth0 interface to be preferred over the wlan0 interface. Install the ifmetric package. Add an option line with "metric 0" just below the "iface eth0 inet dhcp" line in "/etc/network/interfaces". Add an option line with "metric 1" just below the "iface wlan0 inet dhcp" line in "/etc/network/interfaces". The metric 0 means the highest priority route and is the default one. The larger metric value means lower priority routes. The IP address of the active interface with the lowest metric value becomes the originating one. See ifmetric(8). 9
Igor Posted October 17, 2017 Posted October 17, 2017 Read my post once again. 1. Provide logs with armbianmonitor -u Always. 2. Describe what do you want to achieve. The main purpose, with simple words. Almost like describing this problem to your mother. Perhaps a better / more simple way exists? In any case, this problem is looks off topic. It looks like a generic network related problem, unrelated to Armbian or Orangepi Zero. Add. And I would recommend you to start with Ubuntu based Armbian. It's less troublesome than Jessie.
geotravel Posted October 17, 2017 Author Posted October 17, 2017 Thank you for the advice ... Quote Read my post once again. 1. Provide logs with armbianmonitor -u Always. 2. Describe what do you want to achieve. The main purpose, with simple words. Almost like describing this problem to your mother. Perhaps a better / more simple way exists? In any case, this problem is looks off topic. It looks like a generic network related problem, unrelated to Armbian or Orangepi Zero. Add. And I would recommend you to start with Ubuntu based Armbian. It's less troublesome than Jessie. 5
