psygnosis Posted July 14, 2025 Posted July 14, 2025 Hi, I have 2 OPi1 that I want to use for some test projects. One project consist just on PiHole, the other one on Tailscale. Since with newer kernel I have high temperature on idle (like 70°C) can you advice me an old version that maybe has a "better" thermal management? Thank you so much, if I'm saying something stupid please tell me, maybe I just need to tune something like disable hdmi, gpu etc... 0 Quote
Stephen Graf Posted July 14, 2025 Posted July 14, 2025 @psygnosis Which version of Armbian and os are you running? Yesterday I loaded current noble on a test system and I just noticed that it is running hot (45) even with a significant heat sink. Another operational system that is running current bookworm runs much cooler (32). If you are running noble, could I ask you to try bookworm to see if there is a difference. I will load up my test system with bookworm to check also. 0 Quote
Stephen Graf Posted July 15, 2025 Posted July 15, 2025 It looks like my test system just runs a little hotter, probably because it is in a case. I took the SD card out of the test (hot) system and put it in the operational system and the operational system still ran cool. So it is not the os. Changing to noble from bookworm made no difference in the running temperature. 0 Quote
Stephen Graf Posted July 15, 2025 Posted July 15, 2025 On 7/14/2025 at 12:07 PM, psygnosis said: can you advice me an old version that maybe has a "better" thermal management @psygnosis Can you run "armbianmonitor -m" (as root) to see what the processor speed and system load is when you are experiencing the high temperature. I found an old distro and loaded it on my test system and the temperature did not change: Welcome to Armbian 22.11.1 Bullseye with Linux 5.15.80-sunxi System load: 10% Up time: 5 min Memory usage: 14% of 491M IP: 192.168.1.69 CPU temp: 49°C Usage of /: 1% of 109G sysadmin@orangepione:~$ sudo armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 16:09:02: 816MHz 0.18 15% 3% 7% 0% 3% 0% 49.9 °C 0/4 16:09:07: 816MHz 0.16 1% 1% 0% 0% 0% 0% 45.6 °C 0/4 16:09:12: 648MHz 0.15 1% 0% 0% 0% 0% 0% 46.0 °C 0/4 16:09:17: 648MHz 0.14 1% 0% 0% 0% 0% 0% 45.6 °C 0/4 16:09:22: 648MHz 0.12 1% 0% 0% 0% 0% 0% 45.6 °C 0/4 16:09:27: 816MHz 0.11 1% 0% 0% 0% 0% 0% 45.8 °C 0/4 0 Quote
psygnosis Posted July 18, 2025 Author Posted July 18, 2025 (edited) Sorry for the late reply. I had some spare time and I've installed bookworm 25.5.1 Time CPU load %cpu %sys %usr %nice %io %irq Tcpu C.St. 20:38:51 1296 MHz 0.41 7% 0% 2% 0% 3% 0% 58.1 °C 0/7 20:38:56 480 MHz 0.38 0% 0% 0% 0% 0% 0% 54.4 °C 0/7 20:39:01 480 MHz 0.35 1% 0% 0% 0% 0% 0% 59.8 °C 0/7 20:39:06 480 MHz 0.32 0% 0% 0% 0% 0% 0% 54.8 °C 0/7 20:39:11 480 MHz 0.29 0% 0% 0% 0% 0% 0% 56.4 °C 0/7 20:39:16 480 MHz 0.27 0% 0% 0% 0% 0% 0% 55.5 °C 0/7 20:39:21 480 MHz 0.25 0% 0% 0% 0% 0% 0% 57.6 °C 0/7 20:39:27 480 MHz 0.23 0% 0% 0% 0% 0% 0% 56.2 °C 0/7 20:39:32 480 MHz 0.21 0% 0% 0% 0% 0% 0% 54.2 °C 0/7 20:39:37 480 MHz 0.19 0% 0% 0% 0% 0% 0% 56.1 °C 0/7 20:39:42 480 MHz 0.18 0% 0% 0% 0% 0% 0% 54.1 °C 0/7 20:39:47 480 MHz 0.16 0% 0% 0% 0% 0% 0% 58.0 °C 0/7 20:39:52 480 MHz 0.15 0% 0% 0% 0% 0% 0% 57.0 °C 0/7^C Actually you had some difference in temp between bookworm and bullseye Edited July 18, 2025 by psygnosis 0 Quote
laibsch Posted July 18, 2025 Posted July 18, 2025 I would not expect an older release to run cooler. 0 Quote
Werner Posted July 19, 2025 Posted July 19, 2025 8 hours ago, laibsch said: I would not expect an older release to run cooler. I would. Happened in the past but no clue which hw. Probably also something aw related. 0 Quote
laibsch Posted July 20, 2025 Posted July 20, 2025 OK That would be called regression and should be analysed for a fix moving forward. Specifically looking for an older release as a "solution" still seems misguided and should only be done to bisect not as a kind of permanent solution. 0 Quote
Stephen Graf Posted July 20, 2025 Posted July 20, 2025 @psygnosis Do you have any heat sink or other cooling on your orangepione? Is your environment hot? At idle (480MHz) your machine is running quite hot, over 55 deg. The idle cpu speed is the minimum that the os can manage and so the os it doing the best it can. 0 Quote
laibsch Posted July 21, 2025 Posted July 21, 2025 I am not entirely sure if those sensors are always accurate. In the case of my BPi M2+, I have some serious doubts. 0 Quote
psygnosis Posted July 22, 2025 Author Posted July 22, 2025 Yes I have the heat sink and a thermal pad: Time CPU load %cpu %sys %usr %nice %io %irq Tcpu C.St. 19:42:28 816 MHz 0.00 0% 0% 0% 0% 0% 0% 51,6 °C 0/4 19:42:33 816 MHz 0.00 0% 0% 0% 0% 0% 0% 50,5 °C 0/4 19:42:38 816 MHz 0.00 0% 0% 0% 0% 0% 0% 52,8 °C 0/4 Armbian 23.02.2 Bullseye with Linux 5.15.93-sunxi Ambient temp is quite hot these days it's like maybe 32°C maybe more 0 Quote
