I burned the image to microsd via BalenaEtcher, popped it into the sbc and applied power. I have tried this two different days with two downloads of the HA image, and having burned the images to two different microsd cards with different results. Day One attempt booted but did not permit home assistant to start. Attempt two yielded the screencap and error previously mentioned.
I'd say try flashing again with a different image, possibly one that worked in one of your other boards.  Verify the download and the flash process with checksums.
On 7/20/2025 at 4:11 PM, Robert Pace said:
The only difference I detect is #1 The Image, and #2 the Kernel (6.1.115 vs 6.12).
tl;dr; This "only" difference is huge - modern kernel hw specific code is pretty much written from scratch, feature by feature. Not to mention differences in general areas between kernel 6.1 and 6.12, low level boot loader is also usually different. Further reading: https://docs.armbian.com/User-Guide_FAQ/#why-things-stop-working
