gene1934 Posted August 6, 2024 Posted August 6, 2024 I have booted it, generated root and user pw's, generated en-utf8 env, Powered off, copied my /etc/hosts file to it which has hostname and ipv4 address for this., edited /etc/hostname with nano to change it and chattr +i that hostname file so I don't have to redo it every boot. replaced card in bpi-m5. booted up to the new hostname, my pw worked but an ip a is still w/o an ipv4 address which it should get from the hosts file but didn't. . sudo network-manager is not found. Whats next, or what should /etc/network/interfaces look like? 0 Quote
gene1934 Posted August 6, 2024 Author Posted August 6, 2024 keyboard spastic, finally got rid of repeats so it looks like the man page, restart does not change error message. finally got rid of error message, but no change in ip a , no ipv4 addess for end0, ip a reports only MAC address. 0 Quote
gene1934 Posted August 6, 2024 Author Posted August 6, 2024 This is west Virginia, USA. no ipv6 service within at least 100 miles of me. 0 Quote
Igor Posted August 6, 2024 Posted August 6, 2024 If this is minimal image - we have changed networking config to NetPlan: https://docs.armbian.com/User-Guide_Networking/ 0 Quote
Solution gene1934 Posted August 6, 2024 Author Solution Posted August 6, 2024 solved: took an hour to get it right. yaml is a picky bitch about format but its working. apt upgrading now.Thank you Igor. 1 Quote
gene1934 Posted August 7, 2024 Author Posted August 7, 2024 new problem, logged in as gene@amanda, no passwd works for su or sudo. Any fix or do I start all over? Plus the netplan stuff cannot be found to save it. thanks 0 Quote
Werner Posted August 7, 2024 Posted August 7, 2024 Check your /etc/sudoers file to change sudo behavior. 57 minutes ago, gene1934 said: netplan stuff cannot be found to save it. ???? 0 Quote
gene1934 Posted August 7, 2024 Author Posted August 7, 2024 I looked at the man page, last time I played with it was 2 decades ago. Its grown 2500 lines since and at my present age approaching 90, is gibberish. So I saved the netplan stuff and rewrote the card to start fresh. thanks Werner 0 Quote
gene1934 Posted Friday at 07:11 AM Author Posted Friday at 07:11 AM Network setup in the latest bookworm+xfce's armbian config won't allow a network setup I've been using for 25 years. Its an all ipv4 static setup using hosts files. It apparetly asumes only valid ipv6 addresses but the nearest ipv6 enabled ISP is over 100 miles away from me in north central West Virginia USA.The idea is it will query the router for any name not found in the /etc/hosts file. Thhe switch trigger being a hardcopy /etc/resolv.conf. This is normally and instantly accomplished as dd-wrt caches previously looked up addresses. And if not found in dd-wrt's cache it relays the request to my ISP's dns server. BUT BUT BUT armbian-config refuses to accept valid ipv4 addresses by hashing them to apparently random errors, digits duplicated or left out When looking at the results no dhcp4 or 6 of is enabled as expected. So how do I fix this first boot problem? This is all on a banannapi-m5 I intend to make an amanda-3.5.4 based nas out of. Thanks for any help. The solved x tag is a lie as it won't post w/o it. 0 Quote
laibsch Posted Friday at 07:30 AM Posted Friday at 07:30 AM Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
gene1934 Posted Friday at 07:37 AM Author Posted Friday at 07:37 AM netplan is a joke. It looks like it might work IF ipv6 was totally disabled. everything I've entered has been applied to /dev/br0. but shown while entering it as end0 This is totally broken. Can I still put this crap in /etc/networking/interfaces.d? Help please. 0 Quote
laibsch Posted Friday at 07:39 AM Posted Friday at 07:39 AM You are already discussing this elsewhere. Please don't post several times about the same issue. 0 Quote
Igor Posted Friday at 07:41 AM Posted Friday at 07:41 AM 25 minutes ago, gene1934 said: Network setup in the latest bookworm+xfce's armbian config won't allow a network setup armbian-config way is limited in its use - it's intended for quick start when networking is simple. When you need something more complex, its always the manual way: https://docs.armbian.com/User-Guide_Networking/ If you wanna look how Armbian deals with networking in the backstage: https://github.com/armbian/build/tree/main/extensions/network In case of desktop images (original, not self constructed), XFCE will have Network manager. 0 Quote
gene1934 Posted Friday at 11:57 AM Author Posted Friday at 11:57 AM up all night, finally got it working. list of stuff I did: download latest 2505 bookworm-xfce and reburn the u-us card 3 times. copied 40 entry /etc/hosts file from working machine. edit /etc/hostname to change it to unique name amanda, then make it immutable as that did not survive a reboot. rm 10-* in etc/netplan, rename armbian.yaml to 10-armbian.yam editing it as needed, and edit /etc/nsswitch.conf to make network setup start as "hostname files dns" rebooting after each stage. So hostname now stays at amanda, and nsswitch.conf works as ordered. I can ping yahoo.com in addition to my other local machines and have now updated 208 pkgs. rebooted looks ok. Now I can get back to making a 20T lvm out of 5 4T SSD's, But first some breakfast and a shot of insulin, and a nap while the local weather settles, its poured piss out of a cowbarn boot most of the night. Thank you for the links, they were educational. 1 Quote
Igor Posted Friday at 03:05 PM Posted Friday at 03:05 PM 2 hours ago, gene1934 said: up all night 🧟♂️🌙☕🛌 2 hours ago, gene1934 said: edit /etc/hostname to change it to unique name amanda Since introducing of systemd (by default in most Linux assemblies in past 10-15 years), its the systemd way: https://www.freedesktop.org/software/systemd/man/latest/hostnamectl.html This way is also handled if armbian-config is used. Also for other things, consider looking into systemd* how-to. Netplan - i understand you might dislike it - is just a wrapper - for systemd-networkd or Network Manager. 0 Quote
gene1934 Posted Friday at 08:21 PM Author Posted Friday at 08:21 PM fussing about duplicate post, yes, same problem, different but identical machine. I have several of these bpi-m5's in service here, And its happened several times while I have reached the age of 90 where short term memory is only weeks. This then. with your link to systemd stuff, is bad code you inherited, blindly. My solution to that was/is to make hostname immutable after editing it. Much simpler than reading thru half a gigabyte of purposely opaque docs looking for clues. With the advent of led backlighting for monitor screens, CRT screens no longer get burnt in. So one thing badly needed is a bright red, much bigger mouse pointer that moves at about 1/10 th of its present speed, and an easy way to totally disable screen and mouse blanking. On a 3d printer, they are both a hindrance, adding 10 to 30 seconds to taking action when a printer malfunctions. And because I use this OS heavily, I also donate a smallish bit of my SS income to your cause on a monthly basis. Thank you Igor. 1 Quote
