za-songguo Posted August 11, 2025 Posted August 11, 2025 Build logs: https://paste.armbian.com/dafiverowa Regardless of whether I use the main or v25.08 branch, set REGIONAL_IMAGE to china or not, or switch between noble and trixie base images, I consistently encounter a 403 Forbidden error right after the customization step. I've tried various configurations, but the issue persists. Any help?🤔 0 Quote
Werner Posted August 11, 2025 Posted August 11, 2025 Depending on your location this might not be anything that can be fixed on Armbian side. If this happens on any mirror, the issue is either your setup or ISP blocking access. 1 Quote
za-songguo Posted August 16, 2025 Author Posted August 16, 2025 It was a network problem. Problem fixed after global activation of a clash proxy. Thanks a lot! 0 Quote
