kostprof21 Posted 23 hours ago Posted 23 hours ago I am using kernel 6.12.45 with rk3568 , everything is displayed on my monitor. A colleague's computer does not work on 3 of the 4 monitors. the error is the same as in the theme / kernel: rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes , since it seems that no one is watching that topic, I decided to raise this issue. Has anyone encountered such a problem? 0 Quote
Werner Posted 23 hours ago Posted 23 hours ago Radxa Zero has a different soc: https://radxa.com/products/zeros/zero/ Double-check what hw you actually have 0 Quote
Werner Posted 23 hours ago Posted 23 hours ago Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
kostprof21 Posted 17 hours ago Author Posted 17 hours ago Hi Werner I apologize for radxa zero, as I do not know which tag to choose. I have a board based on OK3568 from Forlinx. Logs https://paste.armbian.com/ohokuhozab 0 Quote
The Tall Man Posted 5 hours ago Posted 5 hours ago The board I have has a different Rockchip SoC (rk3588-orangepi-5-plus), but it's been my experience that the edge kernel (6.16) is the only one that's of any real use to me. I get no video with the "current" (6.12) kernel, and no GPU acceleration with the vendor (6.1) kernel. So I would suggest just switching to the edge kernel. 0 Quote
Werner Posted 2 hours ago Posted 2 hours ago 3 hours ago, The Tall Man said: I get no video with the "current" (6.12) kernel, Expected. current had a bare minimum of hdmi support before it became recent LTS kernel. Therefore no fixes will hit there until rollover to next LTS. 3 hours ago, The Tall Man said: and no GPU acceleration with the vendor (6.1) kernel. Needs to be enabled. Either enable panthor overlay (the mainline panthor driver was backported to vendor kernel but is disabled by default) and install more recent mesa packages (depends on userspace). Or install proprietary mali blobs. Having or building an image with mesa-vpu extension enabled handles that for you. There is no automatic method of installing afterwards yet. https://github.com/armbian/apa/issues/20 0 Quote
