Today I was going through my cupboard and did find a original pcDuino (v1) with A10-CPU and 1GB of Ram.
In my mind I got the pcDuino v2 download-page of armbian.
As JohnGo did wrote May 2016 on this page is a picture of the pcDuino v1:
So I checked the specifications v1 <--> v2 and found ony that  v2 has only a WiFi-Board soldered where on the v1 is a additionally USB-Port.
Also the v1 is missing the Arduino-Headers, but has some other pin-rows for GPIO and so on.
CPU (single-Core 1Ghz) and Ram (whopping 1GB for 2012) is the same :)
I wrote the pcDuino v2 Image to a uSD and booted it without problems.
(and changed /etc/update-motd.d/10-header a little bit)
            ____        _          __     ___
 _ __   ___|  _ \ _   _(_)_ __   __\ \   / / |
| '_ \ / __| | | | | | | | '_ \ / _ \ \ / /| |
| |_) | (__| |_| | |_| | | | | | (_) \ V / | |
| .__/ \___|____/ \__,_|_|_| |_|\___/ \_/  |_|
|_|
Welcome to ARMBIAN 5.31 stable Debian GNU/Linux 8 (jessie) 4.11.6-sunxi
System load:   1.13 0.30 0.10   Up time:       0 min
Memory usage:  4 % of 996MB     IP:            192.168.6.119
CPU temp:      51°C
Usage of /:    33% of 3.5G
Only problem while updating was that the couldnt install/update bluez.
While the v1 hasnt any Bluetooth I only removed bluez via apt and all was fine :)
Now the pcDuino v1 is playing Internetradio fine via mpg123 and a USB-Soundcard.
I was wondering because more powered Sunvell R69 has hickups playing Internetradio via Ethernet/WiFi
I used the 2 green leds from the serial port as heartbeat & mmc0 notification via
echo "heartbeat" > /sys/class/leds/pcduino:green:tx/trigger
echo "mmc0" > /sys/class/leds/pcduino:green:rx/trigger
As attachment a picture of a pcDuino v1 and one of the v2
