9 hours ago, 晓飞丁 said:
Is FEX or DXVK 1.7.1 is a must ?
Yeah, mb box64 issue or something. I can't boot this game with box64 + wine/proton, only hangover (FEX) is working for me.
Any Dxvk will work, I think!
Thank you so much!
I try FEX today and it is the same. I will try hangover tomorrow
Posted (edited)
Armbian 25.11.2 Noble XFCE (BSP Kernel: 6.1.115)
+ PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco)
+ box64 3.9 (https://ryanfortner.github.io/box64-debs/)
+ proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz)
+ DXVK-stripped v2.1
>=60fps@720p
NineSols
Edited by KhanhDTP
Posted (edited)
+ DXVK-stripped v1.7.1
~30fps@720p
Metal Gear Solid Ground Zeroes
Edited by KhanhDTP
Posted (edited)
+ wine-10.14-staging-tkg-ntsync-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.14)
+ DXVK-stripped v1.10.3
40~60fps@1080p
Persona 4 Golden
Edited by KhanhDTP
Posted (edited)
+ dgVoodoo2 (https://github.com/dege-diosg/dgVoodoo2/releases)
+ DXVK-stripped v1.6.1
~60fps@720p
Noted:
. The DX9 version of the game is black-screen.
. The DX10 version works. However, it will crash immediately after the tutorial stage because the PanVk driver still lacks the "Geometry Shaders" feature.
. By using dgVoodoo2, the DX9 black screen issue was fixed.
Devil May Cry 4 (DX9 + dgVoodoo2 + DXVK)
Devil May Cry 4 (DX10)
Edited by KhanhDTP
 + wine-9.22-staging-tkg-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/9.22)
~40fps@720p (Ultra High settings)
Oblivion
~60fps@720p
Need For Speed Most Wanted
NFS-Most-Wanted-Original--PanVk@720p(1).thumb.jpg.664c04ba5264c5526401bfee4cb06b9e.jpg
+ wine-10.20-staging-tkg-ntsync-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.20)
~60fps@720p (Medium settings)
box64 environment variables:
Quote
export BOX64_DYNAREC_BIGBLOCK=3
export BOX64_DYNAREC_FORWARD=512
export BOX64_DYNAREC_CALLRET=1
Prince of Persia - The Forgotten Sands
+ DXVK-stripped v2.6.2
30~60fps@720p
Quote
Need for Speed Hot Pursuit
Posted (edited)
~60fps@720p
Quote
Call of Duty 2
Edited by KhanhDTP
~60fps@720p
How did you apply dgVoodoo2 ? I download the archieve file it is a bunch of dll.
You can download dgVoodoo2 from here: https://community.pcgamingwiki.com/files/file/572-dgvoodoo-2/
(Unfortunately, newer versions of dgVoodoo2 won't work with Wine/Proton.)
Extract the archive, then copy dgVoodoo2_79_1/MS/x86/d3d9.dll to the game's folder (just like Dxvk).
Then, copy the Dxvk's d3d11.dll, dxgi.dll to the game's folder.
If done right, you will see that the Dxvk HUD shows the game uses D3D11 API.
Great! Thanks a lot! I will try it to se if Diablo II can run tonight!
+ box64 4.1 (https://ryanfortner.github.io/box64-debs/)
+ DXVK-stripped v2.1 (more likely to be crash-proof than other Dxvk versions)
~40fps@720p (Medium settings)
(There are small graphics are flickering. Locking the FPS at 30fps seems to fix it a bit)
Quote
# export BOX64_DYNAREC_SAFEFLAGS=2; export BOX64_DYNAREC_STRONGMEM=1 # Add these if you face random crashes
Prince of Persia 2008
~60fps@720p (Medium/High settings)
Quote
Need for Speed - Underground 2
