Samixa Posted September 29 Posted September 29 (edited) Radxa-cubie-a5e second Ethernet port not work after update Armbian 25.11.0-trunk.259. Quote [ 22.495764] sun55i-gmac200 4510000.ethernet: deferred probe timeout, ignoring dependency [ 22.495788] sun55i-gmac200 4510000.ethernet: probe with driver sun55i-gmac200 failed with error -110 Edited September 29 by Samixa 0 Quote
Werner Posted September 29 Posted September 29 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
Samixa Posted September 30 Author Posted September 30 Hi, I tested with the version 25.11.0-trunk.129 and the second network port worked with this. https://paste.armbian.com/hasewoloti 0 Quote
Nob0dy Posted October 7 Posted October 7 (edited) same problem, and 25.11.0-trunk.129 img dont work Edited October 7 by Nob0dy 0 Quote
Samixa Posted October 8 Author Posted October 8 On 10/7/2025 at 7:40 PM, Nob0dy said: same problem, and 25.11.0-trunk.129 img dont work Hello Nob0dy , If you use 25.11.0-trunk.129 after cold reboot you must make soft reboot then second Ethernet port work. 0 Quote
Nob0dy Posted October 9 Posted October 9 Ok, it works, but is there a solution to this problem? 0 Quote
Samixa Posted October 9 Author Posted October 9 4 hours ago, Nob0dy said: Ok, it works, but is there a solution to this problem? Maybe this -> https://github.com/torvalds/linux/commit/a15f095b590bcc1968fbf2ced8fe87fbd8d012e0 0 Quote
Luca Gerber Posted October 31 Posted October 31 Hi, if you compile your kernel with "CONFIG_SUN55I_PCK600" set, you'll have the second ethernet port. But you'll loose the wifi adapter, just like in the trunk.129. 0 Quote
