Mallikarjun Modi Posted October 1 Posted October 1 Hello, I am trying to enable Panfrost GPU acceleration on a new Armsom Sige5 board running the latest edge kernel (6.1.115), but glxinfo -B still shows llvmpipe. I have been troubleshooting this for some time and have discovered that the kernel module (panfrost.ko) loads correctly with modprobe, but it is not binding to the GPU hardware on boot. I believe I have found the reason why. A recent commit to the Armbian build system (https://github.com/armbian/build/commit/836def3d11699537e6289dedfbc766c2050d422d) changes the method for enabling Panfrost. It removes the panfrost overlay and adds KERNEL_TARGET_CONFIG="panfrost-all" instead. It appears that the current edge kernel available through armbian-config does not yet include this essential fix. Can you please advise when a kernel with this change will be available for download, or if there is a manual way I can apply this fix? Thank you. 0 Quote
laibsch Posted October 1 Posted October 1 @Igor is probably in the best position to answer when a new image for your board might be available. 2 hours ago, Mallikarjun Modi said: or if there is a manual way I can apply this fix This is actually fairly easy to do by building your own image: "git clone https://github.com/armbian/build.git;cd build;./compile.sh" https://docs.armbian.com/Developer-Guide_Building-with-Docker/ https://evilolaf.github.io/docupreview/Developer-Guide_Build-Preparation/ https://www.youtube.com/watch?v=kQcEFsXEJEE 0 Quote
Werner Posted October 1 Posted October 1 2 hours ago, laibsch said: https://evilolaf.github.io/docupreview/Developer-Guide_Build-Preparation/ This is severely outdated. Use this one instead: https://docs.armbian.com/Developer-Guide_Build-Preparation/ 1 Quote
Werner Posted October 1 Posted October 1 5 hours ago, Mallikarjun Modi said: edge kernel (6.1.115), edge = 6.16.y vendor = 6.1.115 Which kernel do you actually use? Also isn't panthor the backported gpu driver for rk35xx? 0 Quote
Igor Posted October 2 Posted October 2 On 10/1/2025 at 12:12 PM, laibsch said: is probably in the best position to answer when a new image for your board might be available. Sige5 is community supported and those boards receive automatic generated images only - once per week. Since GitHub introduced additional limitations few months ago, we can't (auto)produce desktop images anymore - only one Debian stable minimal per CSC build target. However, this might change in the future. 1 Quote
laibsch Posted October 2 Posted October 2 Thank you for that additional information, Igor. The lack of desktop images is only a minor inconvenience, I'd say. Easy enough to install the required packages after installation of the base image to the SBC itself. 0 Quote
