October 2, 20251 yr Recently, when I run `armbian-upgrade`, I was greeted with an update to raspi-firmware. However, this version of firmware doesn't seem to work with the corresponding intramfs with kernel 6.12.44. sudo armbian-upgrade Hit:1 https://mirrors.ustc.edu.cn/armbian trixie InRelease Hit:2 https://mirrors.ustc.edu.cn/debian trixie InRelease Hit:3 https://mirrors.ustc.edu.cn/debian trixie-updates InRelease Hit:4 https://mirrors.ustc.edu.cn/debian-security trixie-security InRelease Hit:5 https://github.armbian.com/configng stable InRelease Get:6 https://apt.syncthing.net syncthing InRelease [24.2 kB] Fetched 24.2 kB in 2s (14.8 kB/s) 2 packages can be upgraded. Run 'apt list --upgradable' to see them. The following packages will be upgraded: armbian-config raspi-firmware Summary: Upgraded: 2, Newly installed: 0, To remove: 0, Not upgraded: 0 Download size: 13.2 MB Space required/available: 272 kB / 553 GB Get:1 https://mirrors.ustc.edu.cn/armbian trixie/trixie-utils arm64 raspi-firmware all 1:1.20250915-1~bookworm [13.0 MB] Get:2 https://github.armbian.com/configng stable/main arm64 armbian-config all 25.11.0-trunk.234.0923.175957 [157 kB] Fetched 13.2 MB in 2s (5,967 kB/s) (Reading database ... 46602 files and directories currently installed.) Preparing to unpack .../raspi-firmware_1%3a1.20250915-1~bookworm_all.deb ... Unpacking raspi-firmware (1:1.20250915-1~bookworm) over (1:1.20250430-4~bookworm) ... Preparing to unpack .../armbian-config_25.11.0-trunk.234.0923.175957_all.deb ... Unpacking armbian-config (25.11.0-trunk.234.0923.175957) over (25.11.0-trunk.192.0915.191809) ... Setting up armbian-config (25.11.0-trunk.234.0923.175957) ... Setting up raspi-firmware (1:1.20250915-1~bookworm) ... Installing new version of config file /etc/initramfs/post-update.d/z50-raspi-firmware ... Installing new version of config file /etc/kernel/postinst.d/z50-raspi-firmware ... WARNING: Unsupported kernel version (6.12.44-current-bcm2711) - skipping setup NOTE: Manual boot configuration may be required Processing triggers for initramfs-tools (0.148.3) ... update-initramfs: Generating /boot/initrd.img-6.12.44-current-bcm2711 WARNING: Unsupported initramfs version (6.12.44-current-bcm2711) - skipping setup NOTE: Manual boot configuration may be required Summary: Upgraded: 0, Newly installed: 0, To remove: 0, Not upgraded: 0 How exactly should I do in this case? In the past, I normally invoke update-intramfs to perform the the intramfs update. Thanks,
October 3, 20251 yr may not help you (i'm running the pi4 build) but i find that putting holds on rpi-eeprom, raspi-firmware and raspberrypi-sys-mods from first boot solves this problem
October 3, 20251 yr I think this "unsupported version" thingy when doing initramfs update is just a cosmetical thing. The script comes from upstream and checks for version string included in upstream (directly from Raspberry to say) kernels. However I believe this has been worked around by our own bsp which is silently executed right after. Cannot tell for sure if that's the issue I remember it is since I don't have access to hw atm.
October 4, 20251 yr Author @0jay it should also happen for your build as well since I'm using generic Raspberry Pi build on RPi5. Or you never see it because of the "hold"? @Werner That's good to know. May I know if there's any way for me to check for certain? Thanks a lot!
October 4, 20251 yr I think there are some directories in /etc which contain initramfs pre/post scripts. I don't have hw on hand to check right now but I believe there was some script starting with z50- filename that contained this check and there should be a 2nd one from Armbian that actually does what the upstream script refuses to do.
October 4, 20251 yr 6 minutes ago, lovenemesis said: Or you never see it because of the "hold"? If I hold those packages I don't see any issues at all.
October 4, 20251 yr 1 minute ago, 0jay said: If I hold those packages I don't see any issues at all. IIRC until like half a year ago this also worked just fine. I assume then this check was introduced upstream which caused this - more or less cosmetical - error.
October 4, 20251 yr 57 minutes ago, Werner said: more or less cosmetical - error I was having some pretty substantial problems with several different builds before developing this hold pattern, Werner
October 24, 20251 yr Author Sorry for the late feedback. I was waiting for a new kernel update (6.12.54-bcm2711) to confirm it was all right. Just as what @Werner said, in the `/etc/initramfs/post-update.d/z50-raspi-firmware` contains snippets of the code that prints out the error. And it's indeed no actual harm. Also, without setting on-hold of the `raspi-firmware`, kernel updates works just fine. We are good. Thank you all! Edited October 24, 20251 yr by lovenemesis
