byron Posted January 2, 2019 Posted January 2, 2019 If you run the Terminal Emulator once the desktop is showing you can punch in sudo armbian-config You can go into system settings and change the display resolution. This is provided you have the display showing well enough to be able to navigate. In case it helps someone else
leofuscaldi Posted May 8, 2019 Posted May 8, 2019 On 1/1/2019 at 10:52 PM, byron said: If you run the Terminal Emulator once the desktop is showing you can punch in sudo armbian-config You can go into system settings and change the display resolution. This is provided you have the display showing well enough to be able to navigate. In case it helps someone else Can't see this option...
Igor Posted May 8, 2019 Posted May 8, 2019 32 minutes ago, leofuscaldi said: Can't see this option... Where did you download the image?
leofuscaldi Posted May 22, 2019 Posted May 22, 2019 On 5/8/2019 at 8:55 AM, Igor said: Where did you download the image? Hi Igor, downloaded from main downloads page. But, anyway, after apt update / apt upgrade / reboot, I was able to change resolution without problems. 1
Aldolo Posted November 8, 2020 Posted November 8, 2020 On 11/22/2017 at 8:07 PM, hanni76 said: Thank you! It worked with the following line in /boot/armbianEnv.txt : extraargs=drm_kms_helper.edid_firmware=HDMI-A-1:edid/640x480.bin video=HDMI-A-1:640x480-24@60 hi. it seems this setup is still the only available to set the resolution. i'm using it successfully. is there a way to select the overscan?
Aldolo Posted November 8, 2020 Posted November 8, 2020 unfortunatly the extraargs parameter disables sound...
