Upcoming release questions
Igor
Let's sum up major concerns/problems and unify/create a plan of actions.
We already decided to wait with mainline H3-H5-A64 ... which means old stable/legacy kernels/a10-20-xu4 (what else?) mainline should be rebuilt and what remains goes under nightly? Images can be made one board at the time, they can be made in exactly 4 days or not. Perhaps I should emphasize "approximately" more? Or remove this date since it only creates an extra pressure? Or is it ok?
This should be fun. For me, most of the time is even sometimes days are wasted and frustration or stress builds up to insane levels.
We know which kernels are not done and there is nothing we can do in a week(s)/month, so let's focus now only on userspace and kernels which are labeled stable ...  and what shall be removed from /download and dl. ?
Since we don't go out with mainline H3-H5-A64 major testing is not that critical, but things are rolling in that direction. With a delay.
I am aware we are not organized perfectly. It's also WIP :)
It already has an obvious answer. Remove it and release when good and ready! I'm sure people would rather have a well tested and stable release!
Keep up the good work! :)
Thank you for cheer up. :) Well, it is perspective biased. We have many different kernels which are in various states, we have userspace (CLI and desktop), utilities, documentation, website.  To have them all in a perfect state at once is mission impossible no matter how hard and smart we work. If we wait for all this to be perfectly aligned, the release date will never come. We need another approach to this problem.
I am seeking consent/approval and sharing responsibility - shell I put a current sunxi-next to the main repository or not, shell I rebuild at least A10/A20/imx6/rk3288/mvebu/xu4 (more precisely which combination to skip?) boards and with Stretch and why not?
IMO we could use wording like "approximately in X months" and "within a month" without setting exact dates.
yes (4.13.x), though not right now - in a couple of days since there are some userspace/BSP cleanups pending.
Tinker Board legacy kernel now supports the 7" RPi display out of the box, just went through the first boot procedure using it on Stretch. :)  Strange behavior on Stretch, the board is locking up for up to a minute before loading an app.  It gets to it eventually, but is completely unresponsive in the meantime.  I will try on another SD in the morning and grab some logs.
Hmmm, network issues on wireless it would seem, stay tuned. http://sprunge.us/FVjY
Do you have a link to display hardware specs, just to tell which display this is? To mention that here: https://github.com/armbian/documentation/blob/master/docs/Release_Changelog.md
You mean this locking could be Stretch related? Huh. Will pay more attention - my testings are very quick these days ... click here and there and fixing things :)
https://www.raspberrypi.org/products/raspberry-pi-touch-display/
The board stops accepting input from keyboard/mouse/touchscreen, the circle keeps spinning on the mouse cursor, and no SD activity for several seconds to a minute or so. Then it acts normally.
Wireless is not accessing the network properly, I haven't even begun digging into that. It attaches to the wifi network no problem, just no internet (armbianmonitor -u threw a firewall error, I'll copy it later). Wired works.
These were not a problem on the Ubuntu I built a few days ago, with the same config down to the SD card.
Sent from my Pixel using Tapatalk
Besides this, what about MALI? Currently, its also broken for legacy builds?
Still something wrong with Clearfog:
Spoiler
BootROM - 1.73
Booting from MMC
General initialization - Version: 1.0.0
Detected Device ID 6828
High speed PHY - Version: 2.0
Init Customer board board SerDes lanes topology details:
 | Lane # | Speed|    Type     |
 |   0    |  3   |  SATA0      |
 |   1    |  0   |  SGMII1     |
 |   2    |  5   |  PCIe1      |
 |   3    |  5   |  USB3 HOST1 |
 |   4    |  5   |  PCIe2      |
 |   5    |  0   |  SGMII2     |
PCIe, Idx 1: detected no link
PCIe, Idx 2: detected no link
High speed PHY - Ended Successfully
DDR3 Training Sequence - Ver TIP-1.39.0
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
DDR3 Training Sequence - Ended Successfully
BootROM: Image checksum verification PASSED
 __   __                      _ _
|  \/  | __ _ _ ____   _____| | |
| |\/| |/ _` | '__\ \ / / _ \ | |
| |  | | (_| | |   \ V /  __/ | |
|_|  |_|\__,_|_|    \_/ \___|_|_|
         _   _     ____              _
        | | | |   | __ )  ___   ___ | |_
        | | | |___|  _ \ / _ \ / _ \| __|
        | |_| |___| |_) | (_) | (_) | |_
         \___/    |____/ \___/ \___/ \__|
 ** LOADER **
U-Boot 2013.01 (Nov 19 2017 - 12:30:43) Marvell version: 2015_T1.0p11
Board: A38x-Customer-Board-1
SoC:   MV88F6828 Rev A0
       running 2 CPUs
CPU:   ARM Cortex A9 MPCore (Rev 1) LE
       CPU 0
       CPU    @ 1600 [MHz]
       L2     @ 800 [MHz]
       TClock @ 250 [MHz]
       DDR3    @ 800 [MHz]
       DDR3 32 Bit Width,FastPath Memory Access, DLB Enabled, ECC Disabled
DRAM:  1 GiB
MMC:   mv_sdh: 0
*** Warning - bad CRC, using default environment
PCI-e 0: Detected No Link.
PCI-e 1: Detected No Link.
USB2.0 0: Host Mode
USB3.0 0: Host Mode
USB3.0 1: Host Mode
Map:   Code:                    0x3fed6000:0x3ff98098
       BSS:                     0x3ffefd54
       Stack:                   0x3f9c5f20
       Heap:                    0x3f9c6000:0x3fed6000
       U-Boot Environment:      0x000f0000:0x00100000 (MMC)
Board configuration detected:
Net:
|  port  | Interface | PHY address  |
| egiga0 |   RGMII   |     0x00     |
| egiga1 |   SGMII   |   In-Band    |
| egiga2 |   SGMII   |   In-Band    |
egiga0 [PRIME], egiga1, egiga2
Unknown command 'echo' - try 'help'
Unknown command 'run' - try 'help'
Unknown command 'tftpboot' - try 'help'
Unknown command 'setenv' - try 'help'
Unknown command 'bootz' - try 'help'
Marvell>> help
No idea, didn't keep track of all legacy stuff. Last time it was broken due to upstream repository problems.
Did you test for any patching or repository cleanup problems? Last time I tested Clearfog builds were working for me.
Spoiler
[ o.k. ] Building  1 / 144 [ Board: bananapi Kernel:default Desktop: no ]
[ o.k. ] Preparing [ host ]
[ o.k. ] Build host OS release [ xenial ]
[ o.k. ] Using user configuration override [ userpatches/lib.config ]
[ o.k. ] Downloading sources
[ o.k. ] Checking git sources [ u-boot v2017.09 ]
[ .... ] Up to date
[ o.k. ] Checking git sources [ linux-sunxi sunxi-3.4 ]
[ .... ] Up to date
[ o.k. ] Checking git sources [ sunxi-tools master ]
[ .... ] Up to date
[ o.k. ] Checking git sources [ rkbin-tools master ]
[ .... ] Up to date
[ o.k. ] Checking git sources [ marvell-tools A3700_utils-armada-17.10 ]
[ .... ] Up to date
[ o.k. ] Checking git sources [ odroidc2-blobs master ]
[ .... ] Up to date
[ o.k. ] Cleaning [ rootfs cache (old) ]
[ o.k. ] Starting package building process [ jessie/armhf ]
'/tmp/distcc/jessie-armhf/gcc' -> '/home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc'
'/tmp/distcc/jessie-armhf/arm-linux-gnueabihf-gcc' -> '/home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc'
'/tmp/distcc/jessie-armhf/cpp' -> '/home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-cpp'
'/tmp/distcc/jessie-armhf/arm-linux-gnueabihf-cpp' -> '/home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-cpp'
'/tmp/distcc/jessie-armhf/g++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++'
'/tmp/distcc/jessie-armhf/arm-linux-gnueabihf-g++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++'
'/tmp/distcc/jessie-armhf/c++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-c++'
'/tmp/distcc/jessie-armhf/arm-linux-gnueabihf-c++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-c++'
[ o.k. ] Packages are up to date [ libDRI2 jessie/armhf ]
[ o.k. ] Packages are up to date [ libvdpau jessie/armhf ]
[ o.k. ] Packages are up to date [ libUMP jessie/armhf ]
[ o.k. ] Packages are up to date [ libcedrus jessie/armhf ]
[ o.k. ] Packages are up to date [ xf86-video-fbturbo jessie/armhf ]
[ o.k. ] Packages are up to date [ xf86-video-armsoc jessie/armhf ]
[ o.k. ] Packages are up to date [ a10disp jessie/armhf ]
[ o.k. ] Packages are up to date [ hostapd jessie/armhf ]
[ o.k. ] Packages are up to date [ hostapd-realtek jessie/armhf ]
[ o.k. ] Packages are up to date [ libglshim jessie/armhf ]
[ o.k. ] Packages are up to date [ libmali-sunxi-r3p0 jessie/armhf ]
[ o.k. ] Packages are up to date [ libvdpau-sunxi jessie/armhf ]
[ o.k. ] Packages are up to date [ mmc-utils jessie/armhf ]
[ o.k. ] Packages are up to date [ sunxi-tools jessie/armhf ]
[ o.k. ] Packages are up to date [ swconfig jessie/armhf ]
[ o.k. ] Starting package building process [ jessie/arm64 ]
'/tmp/distcc/jessie-arm64/gcc' -> '/home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc'
'/tmp/distcc/jessie-arm64/aarch64-linux-gnu-gcc' -> '/home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc'
'/tmp/distcc/jessie-arm64/cpp' -> '/home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-cpp'
'/tmp/distcc/jessie-arm64/aarch64-linux-gnu-cpp' -> '/home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-cpp'
'/tmp/distcc/jessie-arm64/g++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-g++'
'/tmp/distcc/jessie-arm64/aarch64-linux-gnu-g++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-g++'
'/tmp/distcc/jessie-arm64/c++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-c++'
'/tmp/distcc/jessie-arm64/aarch64-linux-gnu-c++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-c++'
[ o.k. ] Packages are up to date [ libDRI2 jessie/arm64 ]
[ o.k. ] Packages are up to date [ libvdpau jessie/arm64 ]
[ .... ] Skipping building libUMP for [ jessie/arm64 ]
[ o.k. ] Packages are up to date [ libcedrus jessie/arm64 ]
[ o.k. ] Packages are up to date [ xf86-video-fbturbo jessie/arm64 ]
[ .... ] Skipping building xf86-video-armsoc for [ jessie/arm64 ]
[ .... ] Skipping building a10disp for [ jessie/arm64 ]
[ o.k. ] Packages are up to date [ hostapd jessie/arm64 ]
[ o.k. ] Packages are up to date [ hostapd-realtek jessie/arm64 ]
[ .... ] Skipping building libglshim for [ jessie/arm64 ]
[ .... ] Skipping building libmali-sunxi-r3p0 for [ jessie/arm64 ]
[ o.k. ] Packages are up to date [ libvdpau-sunxi jessie/arm64 ]
[ o.k. ] Packages are up to date [ mmc-utils jessie/arm64 ]
[ o.k. ] Packages are up to date [ sunxi-tools jessie/arm64 ]
[ .... ] Skipping building swconfig for [ jessie/arm64 ]
[ o.k. ] Starting package building process [ xenial/armhf ]
'/tmp/distcc/xenial-armhf/gcc' -> '/home/igorp/build/cache/toolchains/gcc-linaro-5.4.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc'
'/tmp/distcc/xenial-armhf/arm-linux-gnueabihf-gcc' -> '/home/igorp/build/cache/toolchains/gcc-linaro-5.4.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc'
'/tmp/distcc/xenial-armhf/cpp' -> '/home/igorp/build/cache/toolchains/gcc-linaro-5.4.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-cpp'
'/tmp/distcc/xenial-armhf/arm-linux-gnueabihf-cpp' -> '/home/igorp/build/cache/toolchains/gcc-linaro-5.4.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-cpp'
'/tmp/distcc/xenial-armhf/g++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-5.4.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++'
'/tmp/distcc/xenial-armhf/arm-linux-gnueabihf-g++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-5.4.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++'
'/tmp/distcc/xenial-armhf/c++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-5.4.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-c++'
'/tmp/distcc/xenial-armhf/arm-linux-gnueabihf-c++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-5.4.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-c++'
[ .... ] Skipping building libDRI2 for [ xenial/armhf ]
[ o.k. ] Packages are up to date [ libvdpau xenial/armhf ]
[ o.k. ] Packages are up to date [ libUMP xenial/armhf ]
[ o.k. ] Packages are up to date [ libcedrus xenial/armhf ]
[ o.k. ] Packages are up to date [ xf86-video-fbturbo xenial/armhf ]
[ o.k. ] Packages are up to date [ xf86-video-armsoc xenial/armhf ]
[ .... ] Skipping building a10disp for [ xenial/armhf ]
[ o.k. ] Packages are up to date [ hostapd xenial/armhf ]
[ o.k. ] Packages are up to date [ hostapd-realtek xenial/armhf ]
[ o.k. ] Packages are up to date [ libglshim xenial/armhf ]
[ o.k. ] Building packages [ libmali-sunxi-r3p0 xenial/armhf ]
[ o.k. ] Checking git sources [ extra/libmali-sunxi-r3p0 master ]
[ .... ] Up to date
[ o.k. ] Updating submodules
[ o.k. ] Checking git sources [ extra/libmali-sunxi-r3p0/lib/mali HEAD ]
[ .... ] Up to date
Failed to create directory /home/igorp/build/cache/buildpkg/xenial-armhf-v6/sys/fs/selinux: Read-only file system
[ .... ] Installing build dependencies
Hit:1 http://ports.ubuntu.com xenial InRelease
Get:2 http://ports.ubuntu.com xenial-security InRelease [102 kB]
Get:3 http://ports.ubuntu.com xenial-updates InRelease [102 kB]
Get:4 http://ports.ubuntu.com xenial-backports InRelease [102 kB]
Fetched 306 kB in 10s (28.6 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 libgles1-mesa-dev : Depends: libgles1-mesa (= 12.0.6-0ubuntu0.16.04.1) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
[ .... ] Copying sources
[ .... ] Building package
dpkg-buildpackage: source package libmali-sunxi-r3p0
dpkg-buildpackage: source version 1.0-1~armbian5.34.171120+1
dpkg-buildpackage: source distribution UNRELEASED
dpkg-buildpackage: source changed by Igor Pecovnik <igor.pecovnik@****l.com>
dpkg-buildpackage: host architecture armhf
dpkg-buildpackage: warning: debian/rules is not executable; fixing that
 dpkg-source --before-build libmali-sunxi-r3p0
dpkg-source: info: applying fix-makefiles.patch
dpkg-source: info: applying fix-makefiles-submodule.patch
dpkg-checkbuilddeps: error: Unmet build dependencies: libegl1-mesa-dev libgles2-mesa-dev
dpkg-buildpackage: warning: build dependencies/conflicts unsatisfied; aborting
dpkg-buildpackage: warning: (Use -d flag to override.)
[ error ] Failed building [ libmali-sunxi-r3p0 xenial/armhf ]
[ o.k. ] Packages are up to date [ libvdpau-sunxi xenial/armhf ]
[ o.k. ] Packages are up to date [ mmc-utils xenial/armhf ]
[ o.k. ] Packages are up to date [ sunxi-tools xenial/armhf ]
[ .... ] Skipping building swconfig for [ xenial/armhf ]
[ o.k. ] Starting package building process [ xenial/arm64 ]
'/tmp/distcc/xenial-arm64/gcc' -> '/home/igorp/build/cache/toolchains/gcc-linaro-5.4.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc'
'/tmp/distcc/xenial-arm64/aarch64-linux-gnu-gcc' -> '/home/igorp/build/cache/toolchains/gcc-linaro-5.4.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc'
'/tmp/distcc/xenial-arm64/cpp' -> '/home/igorp/build/cache/toolchains/gcc-linaro-5.4.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-cpp'
'/tmp/distcc/xenial-arm64/aarch64-linux-gnu-cpp' -> '/home/igorp/build/cache/toolchains/gcc-linaro-5.4.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-cpp'
'/tmp/distcc/xenial-arm64/g++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-5.4.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-g++'
'/tmp/distcc/xenial-arm64/aarch64-linux-gnu-g++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-5.4.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-g++'
'/tmp/distcc/xenial-arm64/c++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-5.4.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-c++'
'/tmp/distcc/xenial-arm64/aarch64-linux-gnu-c++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-5.4.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-c++'
[ .... ] Skipping building libDRI2 for [ xenial/arm64 ]
[ o.k. ] Packages are up to date [ libvdpau xenial/arm64 ]
[ .... ] Skipping building libUMP for [ xenial/arm64 ]
[ o.k. ] Packages are up to date [ libcedrus xenial/arm64 ]
[ o.k. ] Packages are up to date [ xf86-video-fbturbo xenial/arm64 ]
[ .... ] Skipping building xf86-video-armsoc for [ xenial/arm64 ]
[ .... ] Skipping building a10disp for [ xenial/arm64 ]
[ o.k. ] Packages are up to date [ hostapd xenial/arm64 ]
[ o.k. ] Packages are up to date [ hostapd-realtek xenial/arm64 ]
[ .... ] Skipping building libglshim for [ xenial/arm64 ]
[ .... ] Skipping building libmali-sunxi-r3p0 for [ xenial/arm64 ]
[ o.k. ] Packages are up to date [ libvdpau-sunxi xenial/arm64 ]
[ o.k. ] Packages are up to date [ mmc-utils xenial/arm64 ]
[ o.k. ] Packages are up to date [ sunxi-tools xenial/arm64 ]
[ .... ] Skipping building swconfig for [ xenial/arm64 ]
[ o.k. ] Starting package building process [ stretch/armhf ]
'/tmp/distcc/stretch-armhf/gcc' -> '/home/igorp/build/cache/toolchains/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc'
'/tmp/distcc/stretch-armhf/arm-linux-gnueabihf-gcc' -> '/home/igorp/build/cache/toolchains/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc'
'/tmp/distcc/stretch-armhf/cpp' -> '/home/igorp/build/cache/toolchains/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-cpp'
'/tmp/distcc/stretch-armhf/arm-linux-gnueabihf-cpp' -> '/home/igorp/build/cache/toolchains/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-cpp'
'/tmp/distcc/stretch-armhf/g++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++'
'/tmp/distcc/stretch-armhf/arm-linux-gnueabihf-g++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++'
'/tmp/distcc/stretch-armhf/c++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-c++'
'/tmp/distcc/stretch-armhf/arm-linux-gnueabihf-c++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-c++'
[ .... ] Skipping building libDRI2 for [ stretch/armhf ]
[ .... ] Skipping building libvdpau for [ stretch/armhf ]
[ .... ] Skipping building libUMP for [ stretch/armhf ]
[ .... ] Skipping building libcedrus for [ stretch/armhf ]
[ .... ] Skipping building xf86-video-fbturbo for [ stretch/armhf ]
[ o.k. ] Packages are up to date [ xf86-video-armsoc stretch/armhf ]
[ .... ] Skipping building a10disp for [ stretch/armhf ]
[ o.k. ] Packages are up to date [ hostapd stretch/armhf ]
[ o.k. ] Packages are up to date [ hostapd-realtek stretch/armhf ]
[ .... ] Skipping building libglshim for [ stretch/armhf ]
[ .... ] Skipping building libmali-sunxi-r3p0 for [ stretch/armhf ]
[ .... ] Skipping building libvdpau-sunxi for [ stretch/armhf ]
[ o.k. ] Packages are up to date [ mmc-utils stretch/armhf ]
[ o.k. ] Packages are up to date [ sunxi-tools stretch/armhf ]
[ .... ] Skipping building swconfig for [ stretch/armhf ]
[ o.k. ] Starting package building process [ stretch/arm64 ]
'/tmp/distcc/stretch-arm64/gcc' -> '/home/igorp/build/cache/toolchains/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc'
'/tmp/distcc/stretch-arm64/aarch64-linux-gnu-gcc' -> '/home/igorp/build/cache/toolchains/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc'
'/tmp/distcc/stretch-arm64/cpp' -> '/home/igorp/build/cache/toolchains/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-cpp'
'/tmp/distcc/stretch-arm64/aarch64-linux-gnu-cpp' -> '/home/igorp/build/cache/toolchains/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-cpp'
'/tmp/distcc/stretch-arm64/g++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-g++'
'/tmp/distcc/stretch-arm64/aarch64-linux-gnu-g++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-g++'
'/tmp/distcc/stretch-arm64/c++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-c++'
'/tmp/distcc/stretch-arm64/aarch64-linux-gnu-c++' -> '/home/igorp/build/cache/toolchains/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-c++'
[ .... ] Skipping building libDRI2 for [ stretch/arm64 ]
[ .... ] Skipping building libvdpau for [ stretch/arm64 ]
[ .... ] Skipping building libUMP for [ stretch/arm64 ]
[ .... ] Skipping building libcedrus for [ stretch/arm64 ]
[ .... ] Skipping building xf86-video-fbturbo for [ stretch/arm64 ]
[ .... ] Skipping building xf86-video-armsoc for [ stretch/arm64 ]
[ .... ] Skipping building a10disp for [ stretch/arm64 ]
[ o.k. ] Packages are up to date [ hostapd stretch/arm64 ]
[ o.k. ] Packages are up to date [ hostapd-realtek stretch/arm64 ]
[ .... ] Skipping building libglshim for [ stretch/arm64 ]
[ .... ] Skipping building libmali-sunxi-r3p0 for [ stretch/arm64 ]
[ .... ] Skipping building libvdpau-sunxi for [ stretch/arm64 ]
[ o.k. ] Packages are up to date [ mmc-utils stretch/arm64 ]
[ o.k. ] Packages are up to date [ sunxi-tools stretch/arm64 ]
[ .... ] Skipping building swconfig for [ stretch/arm64 ]
[ warn ] Following packages failed to build
[ .... ] libmali-sunxi-r3p0:xenial/armhf
[ o.k. ] Kernel build done [ @host ]
[ o.k. ] Target directory [ /home/igorp/build/output/debs/ ]
[ o.k. ] File name [ linux-image-sun7i_5.34.171120_armhf.deb ]
[ o.k. ] Runtime [ 0 min ]
Any quick fix for this?
This?
Spoiler
[ o.k. ] Checking git sources [ u-boot-armada u-boot-2013.01-15t1-clearfog ]
[ .... ] Creating local copy
[ .... ] Fetching updates
remote: Counting objects: 9710, done.
remote: Compressing objects: 100% (6934/6934), done.
remote: Total 9710 (delta 2795), reused 9250 (delta 2612), pack-reused 0
Receiving objects: 100% (9710/9710), 19.95 MiB | 7.70 MiB/s, done.
Resolving deltas: 100% (2795/2795), done.
From https://github.com/SolidRun/u-boot-armada38x
 * branch            u-boot-2013.01-15t1-clearfog -> FETCH_HEAD
 * [new branch]      u-boot-2013.01-15t1-clearfog -> origin/u-boot-2013.01-15t1-clearfog
[ .... ] Checking out
[ o.k. ] Checking git sources [ linux-armada-lts linux-4.4.y-marvell ]
[ .... ] Up to date
[ .... ] Up to date
[ .... ] Up to date
[ .... ] Up to date
[ o.k. ] Cleaning output/debs for [ clearfogpro default ]
[ o.k. ] Cleaning [ u-boot-armada/u-boot-2013.01-15t1-clearfog ]
[ o.k. ] Compiling u-boot [ 2013.01 ]
[ o.k. ] Compiler version [ arm-linux-gnueabi-gcc 4.9.4 ]
[ .... ] Checking out sources
[ o.k. ] Started patching process for [ u-boot mvebu-clearfogpro-default ]
[ o.k. ] Looking for user patches in [ userpatches/u-boot/u-boot-mvebu ]
[ o.k. ] * [l][b] add-fdtfile-env-clearfog-pro.patch
[ o.k. ] * [l][c] add-spinor-and-sata-targets.patch
[ o.k. ] * [l][c] disable-jffs-support.patch
[ o.k. ] * [l][c] loading-boot-scr.patch
[ o.k. ] * [l][c] make-build-more-silent.patch
[ o.k. ] * [l][c] tools-bin_hdr-compiler-fixes.patch
Configuring for armada_38x_clearfog - Board: armada_38x, Options: CUSTOMER_BOARD_1,ARMADA_38X,MV_MMC_BOOT,MV_INCLUDE_SPI,DDR3
Generating include/autoconf.mk
Generating include/autoconf.mk.dep
ccache arm-linux-gnueabi-gcc -DDO_DEPS_ONLY \
        -g  -Os   -fno-common -ffixed-r8 -msoft-float  -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0x00000000 -I/home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -fno-builtin -ffreestanding -nostdinc -isystem /home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabi/4.9.4/include -pipe  -DCONFIG_ARM -D__ARM__ -marm -mno-thumb-interwork -mabi=aapcs-linux -march=armv7-a -march=armv7-a  -Wall -Wstrict-prototypes -fno-stack-protector -Wno-format-nonliteral -Wno-format-security -fstack-usage   \
        -o lib/asm-offsets.s lib/asm-offsets.c -c -S
if [ -f arch/arm/cpu/armv7/mvca9/asm-offsets.c ];then \
                -o arch/arm/cpu/armv7/mvca9/asm-offsets.s arch/arm/cpu/armv7/mvca9/asm-offsets.c -c -S; \
else \
        touch arch/arm/cpu/armv7/mvca9/asm-offsets.s; \
fi
Generating include/generated/generic-asm-offsets.h
tools/scripts/make-asm-offsets lib/asm-offsets.s include/generated/generic-asm-offsets.h
Generating include/generated/asm-offsets.h
tools/scripts/make-asm-offsets arch/arm/cpu/armv7/mvca9/asm-offsets.s include/generated/asm-offsets.h
for dir in tools examples/standalone examples/api  arch/arm/cpu/armv7  ; do \
                make -C $dir _depend ; done
cat /dev/null  >.depend
make[1]: Nothing to be done for '_depend'.
ccache arm-linux-gnueabi-gcc -M -g  -Os   -fno-common -ffixed-r8 -msoft-float  -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0x00000000 -I/home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -fno-builtin -ffreestanding -nostdinc -isystem /home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabi/4.9.4/include -pipe  -DCONFIG_ARM -D__ARM__ -marm -mno-thumb-interwork -mabi=aapcs-linux -march=armv7-a -march=armv7-a  -I..   -MQ hello_world.o hello_world.c >.depend.hello_world
ccache arm-linux-gnueabi-gcc -M -g  -Os   -fno-common -ffixed-r8 -msoft-float  -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0x00000000 -I/home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -fno-builtin -ffreestanding -nostdinc -isystem /home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabi/4.9.4/include -pipe  -DCONFIG_ARM -D__ARM__ -marm -mno-thumb-interwork -mabi=aapcs-linux -march=armv7-a -march=armv7-a  -I..   -MQ stubs.o stubs.c >.depend.stubs
cat /dev/null .depend.hello_world .depend.stubs >.depend
ccache arm-linux-gnueabi-gcc -M -g  -Os   -fno-common -ffixed-r8 -msoft-float  -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0x00000000 -I/home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -fno-builtin -ffreestanding -nostdinc -isystem /home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabi/4.9.4/include -pipe  -DCONFIG_ARM -D__ARM__ -marm -mno-thumb-interwork -mabi=aapcs-linux -march=armv7-a -march=armv7-a    -MQ start.o start.S >.depend.start
ccache arm-linux-gnueabi-gcc -M -g  -Os   -fno-common -ffixed-r8 -msoft-float  -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0x00000000 -I/home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -fno-builtin -ffreestanding -nostdinc -isystem /home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabi/4.9.4/include -pipe  -DCONFIG_ARM -D__ARM__ -marm -mno-thumb-interwork -mabi=aapcs-linux -march=armv7-a -march=armv7-a    -MQ cache_v7.o cache_v7.c >.depend.cache_v7
ccache arm-linux-gnueabi-gcc -M -g  -Os   -fno-common -ffixed-r8 -msoft-float  -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0x00000000 -I/home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -fno-builtin -ffreestanding -nostdinc -isystem /home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabi/4.9.4/include -pipe  -DCONFIG_ARM -D__ARM__ -marm -mno-thumb-interwork -mabi=aapcs-linux -march=armv7-a -march=armv7-a    -MQ cpu.o cpu.c >.depend.cpu
ccache arm-linux-gnueabi-gcc -M -g  -Os   -fno-common -ffixed-r8 -msoft-float  -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0x00000000 -I/home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -fno-builtin -ffreestanding -nostdinc -isystem /home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabi/4.9.4/include -pipe  -DCONFIG_ARM -D__ARM__ -marm -mno-thumb-interwork -mabi=aapcs-linux -march=armv7-a -march=armv7-a    -MQ syslib.o syslib.c >.depend.syslib
cat /dev/null .depend.start .depend.cache_v7 .depend.cpu .depend.syslib >.depend
make -C tools all
make -C arch/arm/cpu/armv7 start.o
make -C /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/arch/arm/cpu/ u-boot.lds
make[1]: Nothing to be done for 'u-boot.lds'.
ccache arm-linux-gnueabi-gcc   -D__ASSEMBLY__ -g  -Os   -fno-common -ffixed-r8 -msoft-float  -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0x00000000 -I/home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -fno-builtin -ffreestanding -nostdinc -isystem /home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabi/4.9.4/include -pipe  -DCONFIG_ARM -D__ARM__ -marm -mno-thumb-interwork -mabi=aapcs-linux -march=armv7-a -march=armv7-a    -o start.o start.S -c
gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -pedantic   -o gen_eth_addr.o gen_eth_addr.c -c
gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -pedantic   -o img2srec.o img2srec.c -c
gcc -g -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -pedantic -c -o crc32.o /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/crc32.c
gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES   -o mkenvimage.o mkenvimage.c -c
gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES   -o os_support.o os_support.c -c
gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES   -o aisimage.o aisimage.c -c
gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES   -o default_image.o default_image.c -c
gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES   -o fit_image.o fit_image.c -c
gcc -g -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -c -o image.o /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/common/image.c
gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES   -o imximage.o imximage.c -c
gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES   -o kwbimage.o kwbimage.c -c
gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES   -o pblimage.o pblimage.c -c
gcc -g -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -pedantic -c -o md5.o /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/md5.c
gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES   -o mkimage.o mkimage.c -c
gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES   -o omapimage.o omapimage.c -c
gcc -g -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -pedantic -c -o sha1.o /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/sha1.c
gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES   -o ublimage.o ublimage.c -c
gcc -g -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -c -o fdt.o /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt/fdt.c
gcc -g -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -c -o fdt_ro.o /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt/fdt_ro.c
gcc -g -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -c -o fdt_rw.o /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt/fdt_rw.c
gcc -g -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -c -o fdt_strerror.o /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt/fdt_strerror.c
gcc -g -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include2 -idirafter /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/include -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt -I /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/tools -DCONFIG_SYS_TEXT_BASE=0x00000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -c -o fdt_wip.o /home/igorp/development/cache/sources/u-boot-armada/u-boot-2013.01-15t1-clearfog/lib/libfdt/fdt_wip.c
  CC    aes.c
  CC    arc4.c
  CC    base64.c
  CC    bignum.c
  CC    des.c
  CC    certs.c
  CC    dhm.c
  CC    debug.c
  CC    havege.c
  CC    md4.c
  CC    md5.c
  CC    net.c
  CC    padlock.c
  CC    md2.c
  CC    rsa.c
  CC    sha1.c
  CC    sha2.c
  CC    sha4.c
  CC    ssl_cli.c
  CC    timing.c
  CC    x509parse.c
  CC    ssl_srv.c
  CC    xtea.c
  CC    ssl_tls.c
  CC    camellia.c
  CC    mvMemPool.c
  AR    libpolarssl.a
ar: creating libpolarssl.a
  RL    libpolarssl.a
  CC    aes/aescrypt2.c
  CC    hash/hello.c
  CC    hash/md5sum.c
  CC    hash/sha1sum.c
  CC    hash/sha2sum.c
  CC    pkey/dh_client.c
  CC    pkey/dh_genprime.c
  CC    pkey/dh_server.c
  CC    pkey/mpi_demo.c
  CC    pkey/rsa_genkey.c
  CC    pkey/rsa_sign.c
  CC    pkey/rsa_verify.c
  CC    ssl/ssl_client1.c
  CC    ssl/ssl_client2.c
  CC    ssl/ssl_server.c
  CC    test/benchmark.c
  CC    test/selftest.c
  CC    test/ssl_test.c
pkey/rsa_sign.c: In function ‘main’:
pkey/rsa_sign.c:104:17: warning: implicit declaration of function ‘sha4_file’ [-Wimplicit-function-declaration]
     if( ( ret = sha4_file( argv[1], hash, 0 ) ) != 0 )
test/selftest.c: In function ‘main’:
test/selftest.c:143:17: warning: implicit declaration of function ‘camellia_self_test’ [-Wimplicit-function-declaration]
     if( ( ret = camellia_self_test( v ) ) != 0 )
pkey/rsa_verify.c: In function ‘main’:
pkey/rsa_verify.c:129:17: warning: implicit declaration of function ‘sha4_file’ [-Wimplicit-function-declaration]
/home/igorp/build/cache/toolchains/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabi/4.9.4/../../../../arm-linux-gnueabi/bin/ld: cannot open linker script file linker.scr: No such file or directory
collect2: error: ld returned 1 exit status
Makefile:176: recipe for target 'bin_hdr.uart.elf' failed
make[2]: *** [bin_hdr.uart.elf] Error 1
make[2]: *** Waiting for unfinished jobs....
Makefile:273: recipe for target 'subdirs' failed
make[1]: *** [subdirs] Error 1
Makefile:619: recipe for target 'tools' failed
make: *** [tools] Error 2
[ error ] ERROR in function compile_uboot [ compilation.sh:162 ]
[ error ] U-boot compilation failed
[ o.k. ] Process terminated
will proceed with the investigation in the evening.
7 minutes ago, zador.blood.stained said:
clearfogpro default configuration builds without issues for me.
I forced compiler re-download, cleared sources again. It builds o.k. but the result is the same :(
2 hours ago, zador.blood.stained said:
Mali building should be fixed, please check
Building yes, working untested.
Regarding Clearfog - do you have a different clean build environment (Docker or Virtualbox) to make a test image?
Working now on a cleanly installed host. http://sprunge.us/DQJV It looks like mine is corrupted somehow. Will rebuild.
Another (minor?) issue. Booting Cubietruck: "EHCI failed"
Spoiler
U-Boot 2017.09-armbian (Nov 22 2017 - 14:18:37 +0100) Allwinner Technology
CPU:   Allwinner A20 (SUN7I)
Model: Cubietech Cubietruck
I2C:   ready
DRAM:  2 GiB
MMC:   SUNXI SD/MMC: 0, SUNXI SD/MMC: 1
HDMI connected: Setting up a 1280x1024 dvi console (overscan 0x0)
In:    serial
Out:   vga
Err:   vga
SCSI:  Target spinup took 0 ms.
AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: ncq stag pm led clo only pmp pio slum part ccc apst
Net:   eth0: ethernet@01c50000
230454 bytes read in 191 ms (1.2 MiB/s)
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 7 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3708 bytes read in 194 ms (18.6 KiB/s)
## Executing script at 43100000
U-boot loaded from SD
Boot script loaded from mmc
241 bytes read in 148 ms (1000 Bytes/s)
5073668 bytes read in 542 ms (8.9 MiB/s)
5594808 bytes read in 587 ms (9.1 MiB/s)
Found legacy kernel configuration
46412 bytes read in 315 ms (143.6 KiB/s)
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    5073604 Bytes = 4.8 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
EHCI failed: timeout when disabling periodic list
EHCI failed to shut down host controller.
   Loading Ramdisk to 49b29000, end 49fffac4 ... OK
Starting kernel ...
Just now, zador.blood.stained said:
Does it prevent the boot completely? AFAIK USB in u-boot for A10/A20 is mostly useless anyway.
Also there are several u-boot issues that are fixed in v2017.11, but I would prefer to upgrade after this stable release.
It boots fine, USB also works ...
Is there anything specific that needs testing or fixing for this stable release?
I am running out of specifics - basic tests are done, problems fixed ... I have .debs ready up to latest sources and can rebuild repository. Images can be made during the night. I think current stable images have more (tiny) bugs than those waiting in the line .... since we have mainline H3/H5/A64 out of this picture. And it's also perfect timing 4.13.y is EOL ... and we push an update when 4.14.y comes into the decent state.
1 minute ago, tkaiser said:
Fine with me. Just thought about this one here but this can also be fixed later...
I don't think there is anything to fix there. Observed issue is the old bug (either disp2, arch timer or a combination of both) which is disappearing and reappearing again randomly due to its nature. But I didn't test this yet and we can always update pine64-default branch later using a newer ayufan's branch once any of those branches in considered "stable".
