Posted (edited)
Hi all,
sorry for a kiddy queston but it the first time when I'm using Armbian.
I need to enter to u-boot menu/enviroment/shell and I can't
I try to press any button when I'm rebooting but nothing happened and i've just have a booted system
I have only UART to my system.
In other devices I have some time to press any key to enter to u-boot shell but there I don't have time.
U-boot exec bootcmd immediately
I need to enter to u-boot shell and reconfigure some env for my work.
I use Armbian 25.8.2 noble
Edited by BlackS
  • BlackS changed the title to How to enter to u-boot enviroment ?
If you have used RadxaOS before there might be an older U-Boot variant in SPI-flash and at least on ROCK3A SPI take preference over SD-cards, so the Armbian U-Boot from SD-card is not use. AFAIR Radxa OS ROCK5 U-Boot does not have the 1 sec autoboot timeout and also uses extlinux script and not bootcmd. But I might mix-up versions and platforms.
So rewrite SPI-flash from Armbian is option to fix it.
