Posted (edited)
Thanks, I compiled one myself too, and it works fine. I actually thought Nick A said A7S support was only added in 6.18.
I also built a desktop version for A7S, but the GUI doesn't seem to start or work properly.
Edited by qq20739111
https://github.com/alexcaoys/allwinner-bspThere are numerous issues with the NPU driver code in the repository, with almost all header files incorrectly set to "<>", resulting in compile time dependencies that cannot be found. I initially wanted to try modifying the makefile, but I found that the header file settings were very confusing, including mixing<>and "", incorrect header file paths, and a series of other problems. In the end, I gave up modifying the makefile and instead relied entirely on relative paths to locate header files, almost all of which needed to be modified.
However, it is reassuring that the repository has no other issues except for the header file error of the NPU code. Of course, it may be necessary to add a ** sunxi-autogen. h ** file to the include directory
The following is the NPU section that I have modified, completely by replacing and modifying the directory ../
npu.7z
Hi @xuyitao,
My repository is focused on moving toward a usable mainline kernel.
As of this week, there are no longer any dependencies on BSP NPU drivers. I plan to remove those, along with the BSP GPU drivers, to avoid any potential confusion.
Could you take a look at the mainline etnaviv driver? Hopefully it meets your needs.
@eli
I think I’ve got KVM enabled, but as they discussed previously, it's not a Linux kernel issue, there's some specific u-boot firmware needed. Since I don't think the open source firmware is ready yet, I guess KVM likely is not feasible on A733 for now.
Posted (edited)
@Dalibor Pospíšil
I haven't tested if the pcie works, maybe others did? But it's a bsp driver so it should.
If that works, and if the SATA device has a driver in Linux 6.18, simply enable it in menuconfig and you should be good to go.
EDIT: Right, I don't have A7A so I didn't really touch the dts for A7A, there might be a little works needed for it to boot.
Edited by alexc
Posted (edited)
@210518-nick-a, please tell me about
AIPU / Zhouyi driver
RemoteProc enabled
RPMsg support,
are those existing in your kernel or should we add them ?
Edited by operator
I could not get PCIE to work properly on BSP 6.6 on the A7S, but maybe it was my mistake.
For SATA over M.2 to work (in case on m.2 SATA drives), the device need to support this electrically, which I'm not sure if A7x boards do.
Sent from my SM-S931B using Tapatalk
