humanus Posted April 22 Posted April 22 (edited) Of course, you can build an A7S image now as well. There's no display output yet. Edited April 22 by humanus Add detail 0 Quote
qq20739111 Posted April 23 Posted April 23 (edited) Thanks, I compiled one myself too, and it works fine. I actually thought Nick A said A7S support was only added in 6.18. I also built a desktop version for A7S, but the GUI doesn't seem to start or work properly. Edited April 23 by qq20739111 0 Quote
xuyitao Posted April 24 Posted April 24 https://github.com/alexcaoys/allwinner-bspThere are numerous issues with the NPU driver code in the repository, with almost all header files incorrectly set to "<>", resulting in compile time dependencies that cannot be found. I initially wanted to try modifying the makefile, but I found that the header file settings were very confusing, including mixing<>and "", incorrect header file paths, and a series of other problems. In the end, I gave up modifying the makefile and instead relied entirely on relative paths to locate header files, almost all of which needed to be modified. However, it is reassuring that the repository has no other issues except for the header file error of the NPU code. Of course, it may be necessary to add a ** sunxi-autogen. h ** file to the include directory The following is the NPU section that I have modified, completely by replacing and modifying the directory ../ npu.7z 0 Quote
qq20739111 Posted April 24 Posted April 24 @xuyitao Did your build pass? Can the NPU handle Ollama? 0 Quote
alexc Posted April 24 Posted April 24 Hi @xuyitao, My repository is focused on moving toward a usable mainline kernel. As of this week, there are no longer any dependencies on BSP NPU drivers. I plan to remove those, along with the BSP GPU drivers, to avoid any potential confusion. Could you take a look at the mainline etnaviv driver? Hopefully it meets your needs. 0 Quote
xuyitao Posted April 25 Posted April 25 @qq20739111 The compilation was successful, but ollama was unable to call NPU 0 Quote
alexc Posted April 26 Posted April 26 @eli I think I’ve got KVM enabled, but as they discussed previously, it's not a Linux kernel issue, there's some specific u-boot firmware needed. Since I don't think the open source firmware is ready yet, I guess KVM likely is not feasible on A733 for now. 1 Quote
Dalibor Pospíšil Posted April 26 Posted April 26 (edited) @alexc What about SATA support? The a7a board has m.2 pcie where the PentaHAT can be attached (I tested it with a custom sunxi kernel). Edited April 26 by Dalibor Pospíšil 0 Quote
alexc Posted April 26 Posted April 26 (edited) @Dalibor Pospíšil I haven't tested if the pcie works, maybe others did? But it's a bsp driver so it should. If that works, and if the SATA device has a driver in Linux 6.18, simply enable it in menuconfig and you should be good to go. EDIT: Right, I don't have A7A so I didn't really touch the dts for A7A, there might be a little works needed for it to boot. Edited April 26 by alexc 0 Quote
operator Posted April 27 Posted April 27 (edited) @210518-nick-a, please tell me about AIPU / Zhouyi driver RemoteProc enabled RPMsg support, are those existing in your kernel or should we add them ? Edited April 27 by operator 0 Quote
humanus Posted April 27 Posted April 27 I could not get PCIE to work properly on BSP 6.6 on the A7S, but maybe it was my mistake.For SATA over M.2 to work (in case on m.2 SATA drives), the device need to support this electrically, which I'm not sure if A7x boards do. Sent from my SM-S931B using Tapatalk 0 Quote
Nick A Posted May 1 Author Posted May 1 (edited) vkmark works on the Sway desktop. The mainline GPU driver still needs some work. I added A7A and A7S support; however, the A7S still needs to be tested. https://github.com/NickAlilovic/build/tree/Radxa-mainline-WIP I am using Debian Trixie with the XFCE desktop environment. A popup message should appear for the Sway installation. Please note that I haven't tested this configuration on other settings. Edited May 1 by Nick A 0 Quote
Nick A Posted May 3 Author Posted May 3 Support for DP Alt Mode is now functional for the A7S running kernel 6.6. https://github.com/NickAlilovic/build/releases/tag/Radxa-cubie-A7S-v0.6.4 1 Quote
Maberikku Posted Sunday at 02:32 PM Posted Sunday at 02:32 PM I made some patches so that the unified driver / TIM-VX for the NPU works on the A7Z. I am also building a MLIR pipeline that emit TIM-VX code, so hopefully we can get more flexibility running ML models on the SBC soon. https://github.com/MaverickLong/Radxa-A733-NPU-Unified-Driver-Support-Package 1 Quote
qq20739111 Posted Sunday at 10:23 PM Posted Sunday at 10:23 PM (edited) @Nick A Great! and Good job! I've tested both the server and desktop versions of v0.6.4 on the A7S, and the DP output works perfectly on both. I've attached a screenshot for your reference. I’m using a USB‑C to HDMI docking station to test it. When I repeatedly plug and unplug it, the display works fine. The dock also has a keyboard receiver plugged in, which works normally. However, if I then plug a USB flash drive into the dock, the display output stops working (probably due to power supply issues). If I unplug the USB drive and plug it back in, the display works normally again. Additionally, I tested the Mainline v0.1. It seems to have issues on the A7S: the blue LED flashes after boot, but neither the Ethernet nor WiFi connects, and there is no output on the DP port. It appears the system cannot be login (I haven't tested via UART). However, the A7Z handles dual screens fine over HDMI and DP. Edited Tuesday at 07:30 PM by qq20739111 0 Quote
Marvin-03 Posted Tuesday at 09:47 AM Posted Tuesday at 09:47 AM A733 User Manual: GitLab Link https://gitlab.com/tina5.0_aiot/product/docs/-/blob/product-aiot-stable/A733/Hardware硬件类文档/芯片手册/A733_User Manual_V0.92.pdf?ref_type=heads Decompiled boot0: https://paste.armbian.eu/akajigufep.kotlin My ATF Fork: https://github.com/rvdr/arm-trusted-firmware/tree/sun60i-a733 My Armbian Build Tree (containing the U-Boot/Kernel patches): https://github.com/rvdr/build/tree/cubie-a7a-7.0 Can somebody look into the u-boot patches (in the v2026.01 directory). I cant even get UART output and I would be grateful if somebody could look into it to check for errors or if something is missing entirely. 1 Quote
humanus Posted Tuesday at 01:03 PM Posted Tuesday at 01:03 PM In my case, WiFi connects correctly on mainline on A7S. Haven't gotten any DP output yet, only on 6.6. There is some spam about DP in UART. 0 Quote
qq20739111 Posted Tuesday at 07:15 PM Posted Tuesday at 07:15 PM @humanus Did you build it yourself, or did you just download Nick's version? Also, doesn't the WiFi connection need to be set up first? I downloaded Nick's A7S Mineline v0.1 directly, but I can't connect even with a wired NIC, so I can't get the WiFi working either. 0 Quote
qq20739111 Posted Tuesday at 08:46 PM Posted Tuesday at 08:46 PM (edited) @Nick A I re-tested v0.6.4 on the A7S several times. It turns out that if you unplug and replug the DP cable before the GUI loads, you won't get a signal back. The only fix is to restart the device. Additionally, the restart button on the A7S is not functional with this image. Edited Tuesday at 10:19 PM by qq20739111 0 Quote
humanus Posted Tuesday at 09:49 PM Posted Tuesday at 09:49 PM I downloaded the image. And yes, of course, I needed to set up the wifi connection when armbian asked me to. 0 Quote
Daniel - Ni Qinghai Posted Wednesday at 09:06 AM Posted Wednesday at 09:06 AM Thank you so much for the Armbian version for A7Z , Armbian is My most love system in all kinds of systems fro SBC - Arm based 0 Quote
Maberikku Posted Thursday at 02:41 AM Posted Thursday at 02:41 AM The MLIR pipeline, lowering from TOSA to TIM-VX C++, is now available here: https://github.com/MaverickLong/MLIR-TIM-VX It's *kinda* working, currently only supports conv2d (image processing) CNN models or simple MLPs, and it's far from mature, so expect a lot of errors. With this (plus the unified driver) we are heading towards running any ML model on the NPU... 0 Quote
qq20739111 Posted Thursday at 04:10 PM Posted Thursday at 04:10 PM (edited) @Maberikku Great! @humanus Nick said you hit a kernel error on 6.6. Can you paste the details here. Edited Thursday at 04:12 PM by qq20739111 0 Quote
humanus Posted yesterday at 08:11 AM Posted yesterday at 08:11 AM (edited) @qq20739111 No, this was on 6.18. I already purged this image and the dtbs were updated since then, but the boot log is here: https://paste.armbian.eu/ewudaciluc.pl Edited yesterday at 08:11 AM by humanus add tag 0 Quote
qq20739111 Posted 1 hour ago Posted 1 hour ago @humanus I thought Nick was referring to version 6.6, but I must have misunderstood. Since I knew 6.18 was still in development, I assumed he meant 6.6. Turns out he was actually talking about 6.18. 0 Quote
