Tantalum Posted 21 hours ago Posted 21 hours ago Hello I have burned bookworm onto a sd card,booted on it with a Rock 5B+ and installed the bootloader on the SPI flash of the board and transferred the OS to the nvme drive. Now I I'm trying to install the new trixie image, but I can't burn it on my nvme drive. With USBImage it does not work. It doesn't detect my nvme drive installed on my USB adapter. With belena Etcher it throws an error during the validation of the image. Win32Imager doesn't load at all on Windows 11. I don't know which other tool (Windows) I could use. I'm stuck. How can I boot again from my SD card on a Rock 5b+? 0 Quote
Werner Posted 20 hours ago Posted 20 hours ago Just boot from microsd and then use armbian-install to move image to spi/nvme directly attached? 0 Quote
Tantalum Posted 20 hours ago Author Posted 20 hours ago But it doesn't boot from the SD card anymore 😕 The bootloader is expecting the OS on the NVME drive. 0 Quote
Tantalum Posted 20 hours ago Author Posted 20 hours ago Logs from what? It doesn't boot from SD, I have a blank screen. Should I erase the SPI ROM to make it boot from the SD again? https://docs.radxa.com/en/rock5/rock5b/low-level-dev/install-os/rkdevtool_spi 0 Quote
Werner Posted 20 hours ago Posted 20 hours ago 7 minutes ago, Tantalum said: Should I erase the SPI ROM to make it boot from the SD again? This should work too. Debug boot issues: https://debug.armbian.de Related perhaps: https://github.com/armbian/build/pull/8994 0 Quote
Tantalum Posted 18 hours ago Author Posted 18 hours ago (edited) I have erased the SPI ROM. It boots from the SD Card now, thanks :-) But now I have another problem 😕 It boots, it start to load Trixie, but after 30s it get stuck here: Edited 18 hours ago by Tantalum 0 Quote
Werner Posted 18 hours ago Posted 18 hours ago edit /boot/armbianEnv.txt and set verbosity to 7 to get an idea about what happens inside. 0 Quote
Tantalum Posted 17 hours ago Author Posted 17 hours ago (edited) I can't mount the SD card to do the modification... It says the GPT table is corrupt. Well that may explains why belenaEtcher throws an error. I used USBImage instead, it doesn't throw an error but the main GPT table is still corrupt. I have tested with 2 different SD cards. I believe there is a problem with these Trixie (Desktop) images for Rock 5b+. (Yes I have checked the checksum after the download) I'm currently downloading the older bookworm image to check if it works, and that there is no hardware issue. Edited 17 hours ago by Tantalum 0 Quote
Igor Posted 17 hours ago Posted 17 hours ago Try from here: https://fi.mirror.armbian.de/dl/rock-5b-plus/archive/ 0 Quote
Tantalum Posted 16 hours ago Author Posted 16 hours ago Still not. Debian starts to load but then gets stuck (see photo above). I have tested again with a bookworm image and it worked. So there may be something wrong with the trixie image unfortunately 😕 0 Quote
Tantalum Posted 2 hours ago Author Posted 2 hours ago As suggested by Werner, I have connected my computer to the board over UART. I have got this as output. Not sure if it helps. Quote U-Boot SPL 2025.10_armbian-2025.10-Se50b-P0eb7-Hdbe0-Vfd58-Bbf55-R448a (Nov 24 2025 - 08:35:51 +0000) Trying to boot from MMC2 ## Checking hash(es) for config config-1 ... OK ## Checking hash(es) for Image atf-1 ... sha256+ OK ## Checking hash(es) for Image u-boot ... sha256+ OK ## Checking hash(es) for Image fdt-1 ... sha256+ OK ## Checking hash(es) for Image atf-2 ... sha256+ OK ## Checking hash(es) for Image atf-3 ... sha256+ OK INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-868-g040d2de11:derrick.huang, fwver: v1.48 NOTICE: BL31: Built : 15:02:44, Dec 19 2024 INFO: spec: 0x1 INFO: code: 0x88 INFO: ext 32k is not valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: bypass memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2400MHz INFO: dfs DDR fsp_params[1].freq_mhz= 534MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1320MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1968MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0xa00000 INFO: SPSR = 0x3c9 U-Boot 2025.10_armbian-2025.10-Se50b-P0eb7-Hdbe0-Vfd58-Bbf55-R448a (Nov 24 2025 - 08:35:51 +0000) Model: Radxa ROCK 5B SoC: RK3588 DRAM: 16 GiB Core: 380 devices, 34 uclasses, devicetree: separate MMC: mmc@fe2c0000: 1, mmc@fe2d0000: 2, mmc@fe2e0000: 0 Loading Environment from SPIFlash... SF: Detected xt25f128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB *** Warning - bad CRC, using default environment In: serial@feb50000 Out: serial@feb50000 Err: serial@feb50000 Model: Radxa ROCK 5B SoC: RK3588 rockchip_dnl_key_pressed: no saradc device found Net: No ethernet found. Hit any key to stop autoboot: 0 Scanning for bootflows in all bootdevs Seq Method State Uclass Part Name Filename --- ----------- ------ -------- ---- ------------------------ ---------------- Scanning global bootmeth 'efi_mgr': Card did not respond to voltage select! : -110 Card did not respond to voltage select! : -110 Cannot persist EFI variables without system partition 0 efi_mgr ready (none) 0 <NULL> ** Booting bootflow '<NULL>' with efi_mgr Loading Boot0000 'mmc 1' failed EFI boot manager: Cannot load any image Boot failed (err=-14) Scanning bootdev 'mmc@fe2c0000.bootdev': 1 script ready mmc 1 mmc@fe2c0000.bootdev.part /boot/boot.scr ** Booting bootflow 'mmc@fe2c0000.bootdev.part_1' with script Boot script loaded from mmc 1:1 217 bytes read in 4 ms (52.7 KiB/s) 22006951 bytes read in 1834 ms (11.4 MiB/s) 49017344 bytes read in 4080 ms (11.5 MiB/s) 272910 bytes read in 34 ms (7.7 MiB/s) Working FDT set to 12000000 441 bytes read in 46 ms (8.8 KiB/s) Applying kernel provided DT overlay rockchip-rk3588-panthor-gpu.dtbo Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' ## Loading init Ramdisk from Legacy Image at 12180000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 22006887 Bytes = 21 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 12000000 Booting using the fdt blob at 0x12000000 Working FDT set to 12000000 Loading Ramdisk to eb303000, end ec7ffc67 ... OK Loading Device Tree to 00000000ecb05000, end 00000000ecbaffff ... OK Working FDT set to ecb05000 Starting kernel ... 0 Quote
eselarm Posted 1 hour ago Posted 1 hour ago From the log I see: Model: Radxa ROCK 5B 272910 bytes read in 34 ms (7.7 MiB/s) I would expect Radxa ROCK 5B+ Or is it 1 DTB nowadays? The bytes read should represent the DTB file that is loaded, I use extlinux so can see what files are loaded, seems this 2025.10 build does not show this. Also be aware it first tries EFI booting, it fails as one can see, so no issue here, but I got confused on my ROCK5B (not the newer upgraded + board) because I had an NVME connectod with a working bootaa64.efi grub.cfg etc as well, so it booted something else than the image from SD-card. I was my own tuned rootfs, so was rather easy to see, but other occasion I did not notice and wasted a lot of time. For this case, what does the kernel spit out ? set loglevel to 7 in armbianEnv.txt 0 Quote
Tantalum Posted 1 hour ago Author Posted 1 hour ago I don't know how to set loglevel to 7 in armbianEnv.txt 😕 On Windows after flashing the SD card, I don't have access to the files (ext4 partition probably). And on my Linux VM I'm not able to mount the SD card 😕 0 Quote
eselarm Posted 1 hour ago Posted 1 hour ago 2 minutes ago, Tantalum said: And on my Linux VM I'm not able to mount the SD card 😕 It gets problematic if it is only Windows that is available. In the past I advised people to download Knoppix and boot the PC with that so you have full control. But nowadays SecureBoot might already be a showstopper, unless you know how to deal with it. So your best Linux is probably the ROCK5 with Armbian Bookworm. You can use that to edit the Trixie SD-card. Or upgrade bookworm in-place to Trixie, I have done it more than 10 times in 2025H2, still 1 or 2 computers to go. 0 Quote
Tantalum Posted 12 minutes ago Author Posted 12 minutes ago (edited) Got it to mount the SD card. Edited 11 minutes ago by Tantalum 0 Quote
