sgei Posted November 17, 2017 Posted November 17, 2017 Hello, I've built a new and clean Image for "Armbian_5.34_Bananapipro_Debian_stretch_default_3.4.113_desktop". The network-manager is not running and can not be started. root@bananapipro:~# /etc/init.d/network-manager start [....] Starting network-manager (via systemctl): network-manager.serviceJob for NetworkManager.service failed because the control process exited with error code. See "systemctl status NetworkManager.service" and "journalctl -xe" for details. failed! root@bananapipro:~# root@bananapipro:~# systemctl status NetworkManager.service ● NetworkManager.service - Network Manager Loaded: loaded (/lib/systemd/system/NetworkManager.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Fri 2017-11-17 12:29:11 CET; 2min 36s ago Docs: man:NetworkManager(8) Process: 1590 ExecStart=/usr/sbin/NetworkManager --no-daemon (code=exited, status=226/NAMESPACE) Main PID: 1590 (code=exited, status=226/NAMESPACE) Nov 17 12:29:11 bananapipro systemd[1]: NetworkManager.service: Unit entered failed state. Nov 17 12:29:11 bananapipro systemd[1]: NetworkManager.service: Failed with result 'exit-code'. Nov 17 12:29:11 bananapipro systemd[1]: NetworkManager.service: Service hold-off time over, scheduling restart. Nov 17 12:29:11 bananapipro systemd[1]: Stopped Network Manager. Nov 17 12:29:11 bananapipro systemd[1]: NetworkManager.service: Start request repeated too quickly. Nov 17 12:29:11 bananapipro systemd[1]: Failed to start Network Manager. Nov 17 12:29:11 bananapipro systemd[1]: NetworkManager.service: Unit entered failed state. Nov 17 12:29:11 bananapipro systemd[1]: NetworkManager.service: Failed with result 'exit-code'. Steffen
Igor Posted November 17, 2017 Posted November 17, 2017 Kernel 3.4.y is not good enough for Debian Stretch. Most likely this is the core of the problem.
tkaiser Posted November 17, 2017 Posted November 17, 2017 On 11/17/2017 at 2:07 PM, sgei said: stretch_default_3.4.113 Expand Will never work: https://forum.armbian.com/topic/4635-network-manager-fails-on-upgrade-from-debian-jessie-to-stretch/?do=findComment&comment=35096
zador.blood.stained Posted November 17, 2017 Posted November 17, 2017 On 11/17/2017 at 2:26 PM, tkaiser said: Will never work Expand ... and will never be supported. It wasn't supposed to be buildable at all but the condition was implemented in wrong place. 1
sgei Posted November 18, 2017 Author Posted November 18, 2017 Thanks a lot. Than I will try to build my environment based on Debian Stretch and Mainline-Kernel. Steffen
