NinjaKitty Posted November 21, 2017 Posted November 21, 2017 Whenever I've been booting up these potatoes, network never works right off the bat when you're using static IPs. /etc/network/interfaces source /etc/network/interfaces.d/* # Wired adapter #1 allow-hotplug eth0 no-auto-down eth0 iface eth0 inet static address 192.168.5.200 netmask 255.255.255.0 gateway 192.168.5.6 dns-nameservers 8.8.8.8 192.168.5.6 # Local loopback auto lo iface lo inet loopback I'm able to ping 8.8.8.8 but unable to ping google.com user@lepotato0:~$ ping google.com ping: unknown host google.com user@lepotato0:~$ nslookup google.com ;; connection timed out; no servers could be reached user@lepotato0:~$ ping 8.8.8.8 PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data. 64 bytes from 8.8.8.8: icmp_seq=1 ttl=57 time=13.5 ms 64 bytes from 8.8.8.8: icmp_seq=2 ttl=57 time=11.1 ms 64 bytes from 8.8.8.8: icmp_seq=3 ttl=57 time=16.6 ms 64 bytes from 8.8.8.8: icmp_seq=4 ttl=57 time=11.3 ms ♥ --- 8.8.8.8 ping statistics --- 4 packets transmitted, 4 received, 0% packet loss, time 3004ms rtt min/avg/max/mdev = 11.199/13.178/16.627/2.194 ms user@lepotato0:~$ I've been manually fixing this by executing sudo ifdown eth0; sudo ifup eth0; Then I tried this answer: https://unix.stackexchange.com/questions/275428/i-can-ping-ips-but-cant-resolve-domains And it works...BUT resolv.conf is overwritten on reboot, so I would have to write into this file every time I boot up. Shouldn't this be something that's automatic on boot?
tkaiser Posted November 21, 2017 Posted November 21, 2017 Can you provide output from 'sudo armbianmonitor -u' please after you manually adjusted DNS resolving and DNS works? And then for a static IP address assignment why don't you use auto instead? # Wired adapter #1 auto eth0 iface eth0 inet static address 192.168.5.200 netmask 255.255.255.0 gateway 192.168.5.6 dns-nameservers 8.8.8.8 192.168.5.6
guidol Posted November 21, 2017 Posted November 21, 2017 On 11/21/2017 at 1:44 AM, NinjaKitty said: And it works...BUT resolv.conf is overwritten on reboot, so I would have to write into this file every time I boot up. Shouldn't this be something that's automatic on boot? Expand you could try this one: https://askubuntu.com/questions/157154/how-do-i-include-lines-in-resolv-conf-that-wont-get-lost-on-reboot English translation: My solved. "only 12.4" I noticed that if you add the dns-nameserver in interfaces that do not take the name resolution server Thanks to the help found here have solved the problem. http://manpages.ubuntu.com/manpages/lucid/man8/resolvconf.8.html To make resolv.conf not change when we edit manually do this in the terminal: sudo resolvconf –disable-updates after: sudo resolvconf -a eth0 # or your network Interfas then manually edit /run/resolvconf/resolv.conf adding a maximum of two DNS servers. thanks P.S. not forget to restart: sudo /etc/init.d/networking restart
NinjaKitty Posted November 21, 2017 Author Posted November 21, 2017 Yeah, I tried the top answer on that site, and it worked. I don't know what people think of editing base files, but it's good enough for me.
tkaiser Posted November 21, 2017 Posted November 21, 2017 On 11/21/2017 at 5:49 PM, NinjaKitty said: I don't know what people think of editing base files Expand Why did you not provide output of 'sudo armbianmonitor -u' as requested?
tkaiser Posted November 21, 2017 Posted November 21, 2017 For everyome else stumbling accross this thread: 1) if someone asks you for 'armbianmonitor -u' output then simply provide it. Armbian devs spent a lot of time and efforts on a tool to provide necessary debug info so we can help you more easily. Not providing this information is also a great way to prevent us from fixing issues 2) Since for Le Potato currently only Xenial images are available I simply gave it a try with correctly defined /etc/network/interfaces settings. It just works as expected, no need to follow outdated tutorials for outdated Ubuntu versions that introduce just another bunch of different problems: root@odroidxu4:~# head /etc/network/interfaces source /etc/network/interfaces.d/* # Wired adapter #1 auto enx001e06330005 iface enx001e06330005 inet static address 192.168.83.254 netmask 255.255.255.0 gateway 192.168.83.1 dns-nameservers 192.168.83.1 9.9.9.9 # hwaddress ether # if you want to set MAC manually root@odroidxu4:~# ping -c 2 google.com PING google.com (172.217.22.238) 56(84) bytes of data. 64 bytes from muc11s02-in-f14.1e100.net (172.217.22.238): icmp_seq=1 ttl=57 time=13.4 ms 64 bytes from muc11s02-in-f14.1e100.net (172.217.22.238): icmp_seq=2 ttl=57 time=12.6 ms --- google.com ping statistics --- 2 packets transmitted, 2 received, 0% packet loss, time 1001ms rtt min/avg/max/mdev = 12.650/13.038/13.426/0.388 ms root@odroidxu4:~# nslookup google.com Server: 192.168.83.1 Address: 192.168.83.1#53 Non-authoritative answer: Name: google.com Address: 172.217.22.238 root@odroidxu4:~# armbianmonitor -u /var/log/armhwinfo.log has been uploaded to http://sprunge.us/LCKf Please post the URL in the Armbian forum where you've been asked for.
NinjaKitty Posted November 21, 2017 Author Posted November 21, 2017 On 11/21/2017 at 6:13 PM, tkaiser said: Why did you not provide output of 'sudo armbianmonitor -u' as requested? Expand I was not referring to your answer, and I didn't see your answer since I was skimming by really quick, so I apologize for that. I will try switching to auto. It was on these settings because they were the defaults given to me when I installed Armbian (I didn't change any of the keywords) I've already resolved it one way, so I don't think armbianmonitor will be necessary. I am aware of this since I've already been providing armbianmonitor in my previous thread. Thanks for all the help.
NinjaKitty Posted November 21, 2017 Author Posted November 21, 2017 If I remember correctly, allow-hotplug eth0 pretty much does a similar thing as auto eth0, So, as I expected on reboot, changing to auto eth0; didn't do anything. root@lepotato2:~# head /etc/network/interfaces source /etc/network/interfaces.d/* # Wired adapter #1 auto eth0 iface eth0 inet static address 192.168.5.202 netmask 255.255.255.0 gateway 192.168.5.6 dns-nameservers 8.8.8.8 8.8.4.4 # hwaddress ether # if you want to set MAC manually root@lepotato2:~# ping -c 2 google.com ping: unknown host google.com root@lepotato2:~# ping 8.8.8.8 PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data. 64 bytes from 8.8.8.8: icmp_seq=1 ttl=54 time=12.6 ms 64 bytes from 8.8.8.8: icmp_seq=2 ttl=54 time=11.8 ms 64 bytes from 8.8.8.8: icmp_seq=3 ttl=54 time=12.0 ms ♥ --- 8.8.8.8 ping statistics --- 3 packets transmitted, 3 received, 0% packet loss, time 2003ms rtt min/avg/max/mdev = 11.865/12.203/12.668/0.351 ms root@lepotato2:~# ifdown eth0; ifup eth0; root@lepotato2:~# armbianmonitor -u System diagnosis information will now be uploaded to gzip: /var/log/armhwinfo.log.1.gz: unexpected end of file http://sprunge.us/dfHP Please post the URL in the forum where you've been asked for. root@lepotato2:~#
tkaiser Posted November 21, 2017 Posted November 21, 2017 On 11/21/2017 at 10:36 PM, NinjaKitty said: gzip: /var/log/armhwinfo.log.1.gz: unexpected end of file Expand Unfortunatenly there's most of the information missing. Anyway, would be interesting to get the output of the following 3 commands 20 seconds after a reboot and then 3 seconds after you did the 'ifdown eth0; ifup eth0' again. ip addr netstat -rn nslookup google.com And then please output from 'armbianmonitor -u' again afterwards. Thank you.
NinjaKitty Posted November 21, 2017 Author Posted November 21, 2017 (edited) Different potato, but should be the same exact configuration other than the local IP being 1 off. root@lepotato1:~# ip addr 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether 76:35:c0:b2:fc:be brd ff:ff:ff:ff:ff:ff 3: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether 82:0b:e2:7c:90:19 brd ff:ff:ff:ff:ff:ff inet 192.168.5.201/24 brd 192.168.5.255 scope global eth0 valid_lft forever preferred_lft forever inet6 fe80::800b:e2ff:fe7c:9019/64 scope link valid_lft forever preferred_lft forever root@lepotato1:~# head /etc/network/interfaces source /etc/network/interfaces.d/* # Wired adapter #1 auto eth0 iface eth0 inet static address 192.168.5.201 netmask 255.255.255.0 gateway 192.168.5.6 dns-nameservers 8.8.8.8 8.8.4.4 # hwaddress ether # if you want to set MAC manually root@lepotato1:~# netstat -rn Kernel IP routing table Destination Gateway Genmask Flags MSS Window irtt Iface 0.0.0.0 192.168.5.6 0.0.0.0 UG 0 0 0 eth0 169.254.0.0 0.0.0.0 255.255.0.0 U 0 0 0 eth0 192.168.5.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0 root@lepotato1:~# nslookup google.com ;; connection timed out; no servers could be reached root@lepotato1:~# ifdown eth0; ifup eth0; root@lepotato1:~# ip addr 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether 76:35:c0:b2:fc:be brd ff:ff:ff:ff:ff:ff 3: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether 82:0b:e2:7c:90:19 brd ff:ff:ff:ff:ff:ff inet 192.168.5.201/24 brd 192.168.5.255 scope global eth0 valid_lft forever preferred_lft forever inet6 fe80::800b:e2ff:fe7c:9019/64 scope link valid_lft forever preferred_lft forever root@lepotato1:~# netstat -rn Kernel IP routing table Destination Gateway Genmask Flags MSS Window irtt Iface 0.0.0.0 192.168.5.6 0.0.0.0 UG 0 0 0 eth0 169.254.0.0 0.0.0.0 255.255.0.0 U 0 0 0 eth0 192.168.5.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0 root@lepotato1:~# nslookup google.com Server: 8.8.8.8 Address: 8.8.8.8#53 Non-authoritative answer: Name: google.com Address: 172.217.5.110 root@lepotato1:~# armbianmonitor -u System diagnosis information will now be uploaded to http://sprunge.us/CBgd Please post the URL in the forum where you've been asked for. Edited December 8, 2017 by Tido link outside code box
tkaiser Posted November 21, 2017 Posted November 21, 2017 On 11/21/2017 at 11:11 PM, NinjaKitty said: Different potato, but should be the same exact configuration other than the local IP being 1 off Expand Well, here in dmesg output docker0 is missing (I was interested in this) but doesn't matter since on this other Potato the problem is the same and I've to admit that I've no clue what's going on (other than reading quickly through your other thread and realizing that this might be really a hardware/driver related problem). Thank you for the provided information, now I've at least something to look into (wrong armbianmonitor output that needs fixes)
TonyMac32 Posted November 22, 2017 Posted November 22, 2017 On 11/21/2017 at 11:29 PM, tkaiser said: hardware/driver related problem Expand The current image is a "testing" release for that reason. Also, 4.13 is an "in progress" support situation for the meson-gxl, I'm running 4.14 with the current patchset through some testing to move NEXT to it. 1
NinjaKitty Posted December 8, 2017 Author Posted December 8, 2017 Is there any action at the moment to take care of this issue? From what I'm hearing, this is a valid issue, so has this been added to the "todo" list? if so, what's the current status?
