frogx Posted January 2, 2016 Posted January 2, 2016 Is there any documentation related to patch integration in building process ? i see a folder userpatches but no doc associated with it. I need to build the aufs kernel module for docker on my olimex A20 lime2 and have no idea of the process. What i curently do is: > force 4.2.6 kernel version in next (same as my curent armbian image for my lime2) > start the building process > checkout aufs standalone for 4.2 in kernel sources folder > patch the kernel with aufs support > manualy reconfigure kernel with the arm toolchain to enable aufs integration as module > manualy build module with the arm toolchain > put the module on my lime2 and configure all the stuff This process is boring and i realy apreciate some indications about patch integration :-)
frogx Posted January 2, 2016 Author Posted January 2, 2016 sorry found partial information in https://github.com/igorpecovnik/lib/blob/master/documentation/geek-faq.md
Igor Posted January 2, 2016 Posted January 2, 2016 Manuals were updated just few days ago. I hope it's clear enough.
zador.blood.stained Posted January 2, 2016 Posted January 2, 2016 There is no documentation yet, and adding new modules is not fully supported, but you can try following: Skip first 3 steps if you already have aufs patches in form of .patch file(s)) Check out fresh copy of kernel sources into new directory Apply all needed aufs patches (except for reconfiguring kernel part) Create patch file by executing "git add ." and "git diff --staged > aufs.patch" in kernel sources root. Double check that patch file doesn't have non-needed stuff like backup files Put all .patch files in subdirectory in userpatches/kernel (look for hint at the beginning of the build process) [ o.k. ] Started patching process for [ kernel sunxi-next 4.3.3 ] [ o.k. ] Looking for user patches in [ userpatches/kernel/sunxi-next ] Set build script option "KERNEL_CONFIGURE=yes" (and KERNELTAG="v4.2.6" if aufs patches are specific to exact kernel version) and enable aufs module in kernel configuration menu After building is done, set build script option "KERNEL_KEEP_CONFIG=yes" to prevent replacing your kernel config with standart version Note: if later you decide to compile another kernel version, you will need to enable AUFS in kernel configuration menu again. This is why I said that adding new modules is not fully supported - you can easily apply patches to kernel sources, but patching kernel .config file is tricky.
