I'm using the command ./compile.sh build BOARD=rpi4b BRANCH=current KERNELBRANCH=current SKIP_ARMBIAN_REPO=yes SKIP_ARMBIAN_CONFIG=yes SKIP_EXTERNAL_TOOLCHAINS=yes BUILD_DESKTOP=no BUILD_MINIMAL=yes CLEAN_LEVEL=make-kernel,alldebs,images,cache EXPERT=yes KERNEL_CONFIGURE=no NEWPKG=true OFFLINE_WORK=no KERNEL_BTF=no RELEASE=noble
5 hours ago, Werner said:
outdated tag, unsupported
What @Werner means by this comment is that you need to update your code to current github code base.  You can't use old code to build.  The dependencies that get pulled in during the build process change over time.  So you always need to be on current (or near current) github source for armbian build to reliably build images.
