lagerschaden Posted November 24, 2017 Posted November 24, 2017 Today i compiled for my Orange Pi One the kernel 4.11.12-sun8i from the sources. The kernel works with only 1 (one) core. / _ \ _ __ __ _ _ __ __ _ ___ | _ \(_) / _ \ _ __ ___ | | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | | | | | '_ \ / _ \ | |_| | | | (_| | | | | (_| | __/ | __/| | | |_| | | | | __/ \___/|_| \__,_|_| |_|\__, |\___| |_| |_| \___/|_| |_|\___| |___/ Welcome to ARMBIAN 5.31 stable Debian GNU/Linux 8 (jessie) 4.11.12-sun8i System load: 1.11 0.26 0.09 Up time: 0 min Memory usage: 10 % of 464MB IP: 192.168.3.156 CPU temp: 43°C Usage of /: 5% of 29G [ General system configuration: armbian-config ] Last login: Fri Nov 24 22:47:42 2017 from xxxxs-ubuntu.fritz.box pi@pi-gf:~$ uname -a Linux pi-gf 4.11.12-sun8i #1 SMP Fri Nov 24 20:16:44 CET 2017 armv7l GNU/Linux pi@pi-gf:~$ cat /proc/cpuinfo processor : 0 model name : ARMv7 Processor rev 5 (v7l) BogoMIPS : 5.71 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x0 CPU part : 0xc07 CPU revision : 5 Hardware : Allwinner sun8i Family Revision : 0000 Serial : 02c0008193c47201 pi@pi-gf:~$ Also htop show only one core.
lagerschaden Posted November 25, 2017 Author Posted November 25, 2017 I compiled Kernel and U-Boot linux-u-boot-dev-orangepione_5.35_armhf.deb I choosed "U-boot and kernel packages" -> "show a kernel configuration ..." -> "orangepione" -> "dev" Now I will try "next" (mainline)
ChrisGCode Posted November 25, 2017 Posted November 25, 2017 I got kernel 4.11.12-sun8i via apt-get update && apt-get dist-upgrade. Previous kernel was 4.11.5-sun8i. Boot hangs now because "script.bin" is missing -- It is dead link to "bin/orangepiplus.bin" which was not installed during the upgrade. Installation is on internal eMMC Board: OrangePi plus 2
lagerschaden Posted November 25, 2017 Author Posted November 25, 2017 also Kernel 4.13.16 uses only one (1) core on the Orangepi-One ___ ____ _ ___ / _ \ _ __ __ _ _ __ __ _ ___ | _ \(_) / _ \ _ __ ___ | | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | | | | | '_ \ / _ \ | |_| | | | (_| | | | | (_| | __/ | __/| | | |_| | | | | __/ \___/|_| \__,_|_| |_|\__, |\___| |_| |_| \___/|_| |_|\___| |___/ Welcome to ARMBIAN 5.31 stable Debian GNU/Linux 8 (jessie) 4.13.16-sunxi System load: 0.96 0.36 0.13 Up time: 1 min Memory usage: 11 % of 493MB IP: 192.168.3.156 CPU temp: 40°C Usage of /: 6% of 29G [ General system configuration: armbian-config ] Last login: Sat Nov 25 14:42:16 2017 from xxxxs-ubuntu.fritz.box pi@pi-gf:~$ uname -a Linux pi-gf 4.13.16-sunxi #1 SMP Sat Nov 25 14:21:44 CET 2017 armv7l GNU/Linux pi@pi-gf:~$ cat /proc/cpuinfo processor : 0 model name : ARMv7 Processor rev 5 (v7l) BogoMIPS : 11.42 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x0 CPU part : 0xc07 CPU revision : 5 Hardware : Allwinner sun8i Family Revision : 0000 Serial : 02c0008193c47201 pi@pi-gf:~$ when installing the new kernel i used sudo dpkg --force-all -i linux-dtb-next-sunxi_5.35_armhf.deb linux-headers-next-sunxi_5.35_armhf.deb linux-image-next-sunxi_5.35_armhf.deb linux-u-boot-next-orangepione_5.35_armhf.deb because there is a conflict linux-u-boot-orangepione-next conflicts with armbian-u-boot linux-u-boot-orangepione-default provides armbian-u-boot and is present and installed. is it a bug or a feature ? L.
tkaiser Posted November 25, 2017 Posted November 25, 2017 58 minutes ago, lagerschaden said: is it a bug or a feature ? Neither/nor, it's you trying to combine legacy u-boot with next or dev kernel. Expected result: Only one CPU core active. Use -f with dpkg to get linux-u-boot-orangepione-default out of your way and you're done (or better start from scratch with a fresh next image -- it always feels strange reading threads popping up discussing issues that are solved since ages)
lagerschaden Posted November 25, 2017 Author Posted November 25, 2017 50 minutes ago, tkaiser said: ... trying to combine legacy u-boot with next or dev kernel... As you can see I installed also the linux-u-boot-next (same line as above): sudo dpkg --force-all -i linux-dtb-next-sunxi_5.35_armhf.deb linux-headers-next-sunxi_5.35_armhf.deb linux-image-next-sunxi_5.35_armhf.deb linux-u-boot-next-orangepione_5.35_armhf.deb first I got the conflict and then I used --force-all to override the conflict ...
tkaiser Posted November 25, 2017 Posted November 25, 2017 Does this image boot with 1 or 4 CPU cores?
lagerschaden Posted November 25, 2017 Author Posted November 25, 2017 I had Armbian_5.30_Orangepione_Debian_jessie_default_3.4.113.img installed before and it boots with 4 cores.
tkaiser Posted November 25, 2017 Posted November 25, 2017 5 minutes ago, lagerschaden said: I had Armbian_5.30_Orangepione_Debian_jessie_default_3.4.113.img installed before and it boots with 4 cores. I know since that's what's to be expected and tested. But I was asking for something else: whether the 5.35 next image for Orange Pi One from last night boots correctly or not. That's all I'm interested in and I thought I could save some time asking users for help instead of searching for the board, downloading the image...
lagerschaden Posted November 25, 2017 Author Posted November 25, 2017 sorry did'nt see the 5.35 ... cu later
zador.blood.stained Posted November 25, 2017 Posted November 25, 2017 17 minutes ago, lagerschaden said: I had Armbian_5.30_Orangepione_Debian_jessie_default_3.4.113.img installed before and it boots with 4 cores. And if you simply installed the mainline kernel packages on top of that image (or other legacy kernel based image) without cleaning up old packages and without adjusting the boot script and environment it's not surprising that you had issues.
lagerschaden Posted November 25, 2017 Author Posted November 25, 2017 35 minutes ago, tkaiser said: Does this image boot with 1 or 4 CPU cores? 4 cores: ___ ____ _ ___ / _ \ _ __ __ _ _ __ __ _ ___ | _ \(_) / _ \ _ __ ___ | | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | | | | | '_ \ / _ \ | |_| | | | (_| | | | | (_| | __/ | __/| | | |_| | | | | __/ \___/|_| \__,_|_| |_|\__, |\___| |_| |_| \___/|_| |_|\___| |___/ Welcome to ARMBIAN 5.35 user-built Debian GNU/Linux 8 (jessie) 3.4.113-sun8i System load: 0.37 0.24 0.10 Up time: 2 min Memory usage: 10 % of 494MB IP: 192.168.3.157 CPU temp: 41°C Usage of /: 82% of 1.1G Last login: Sat Nov 25 16:49:11 2017 from xxxxs-ubuntu.fritz.box pi@orangepione:~$ uname -a Linux orangepione 3.4.113-sun8i #4 SMP PREEMPT Wed Nov 22 13:45:28 CET 2017 armv7l GNU/Linux pi@orangepione:~$ cat /proc/cpuinfo Processor : ARMv7 Processor rev 5 (v7l) processor : 0 BogoMIPS : 1942.85 processor : 1 BogoMIPS : 1942.85 processor : 2 BogoMIPS : 1942.85 processor : 3 BogoMIPS : 1942.85 Features : swp half thumb fastmult vfp edsp thumbee neon vfpv3 tls vfpv4 idiva idivt CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x0 CPU part : 0xc07 CPU revision : 5 Hardware : sun8i Revision : 0000 Serial : 540078678620542709ce pi@orangepione:~$ 1
tkaiser Posted November 25, 2017 Posted November 25, 2017 6 minutes ago, lagerschaden said: 4 cores Thanks for confirming. As @zador.blood.stained already explained without taking a lot of care it's not possible to 'crossgrade' from a legacy to a next (and especially a dev) image. We tried to support this in the past but stopped since we're not able to support this level of complexity. The 'google site search' when fed with 'only one cpu core' will answer the question why different boot stuff is needed...
ChrisGCode Posted November 25, 2017 Posted November 25, 2017 Thank you! I purged linux-image-sun8i and run the upgrade again. Kernel 4.11.12-sun8i is running now -- with 4 cores. 1 hour ago, tkaiser said: it always feels strange reading threads popping up discussing issues that are solved since ages Isn't it an issue with the package dependencies/conflicts? You answered this question while I was typing
tkaiser Posted November 25, 2017 Posted November 25, 2017 11 minutes ago, ChrisGCode said: Kernel 4.11.12-sun8i is running now Just why? Our next branch is at 4.13 already and the old dev branch has been trashed few hours ago: https://github.com/armbian/build/commit/376fcd218689186ae23ba7baa2db0ce0d65308e5 And when you tomorrow update your installation from beta repo it will break anyway. There exist not that many reasons to choose dev branch (unless you want to improve Armbian of course and provide constructive feedback)
ChrisGCode Posted November 25, 2017 Posted November 25, 2017 12 minutes ago, tkaiser said: Just why? Our next branch is at 4.13 already I executed: apt-get update && apt-get dist-upgrade and then 4.11.12-sun8i was installed. When I run: apt-get update && apt-cache search linux-image-dev-sun8i I get the following output: Quote # apt-get update Hit:3 http://apt.armbian.com jessie InRelease Hit:5 http://apt.armbian.com stretch InRelease Ign:1 http://cdn-fastly.deb.debian.org/debian stretch InRelease Hit:2 http://cdn-fastly.deb.debian.org/debian stretch-updates InRelease Hit:4 http://cdn-fastly.deb.debian.org/debian stretch-backports InRelease Hit:6 http://cdn-fastly.deb.debian.org/debian stretch Release Hit:7 http://security.debian.org stretch/updates InRelease Reading package lists... Done # apt-cache search linux-image-dev-sun8i linux-image-dev-sun8i - Linux kernel, version 4.11.12-sun8i # apt-cache search linux-image-sun8i linux-image-sun8i - Linux kernel, version 3.4.113-sun8i
tkaiser Posted November 25, 2017 Posted November 25, 2017 30 minutes ago, ChrisGCode said: dev Is not supported and as already said it makes absolutely no sense at all to use the dev branch if you do not want to contribute to Armbian in a reasonable way
