ChrisO Posted January 23 Posted January 23 Hi I installed Armbian_community_26.2.0-trunk.151_Odroidhc4_trixie_current_6.18.2_minimal.img Trying to build zfs-dkms I discovered that I was missing the linux-headers for this kernel version and there is no package containing it. At least apt-cache didn't find anything. Any idea where to find it? Thanks, Chris 0 Quote
Werner Posted January 24 Posted January 24 There are no header packages for each and every trunk version to save resources. Most simple solution is probably DIY an image with INSTALL_HEADERS=yes to have them shipped with the image. 0 Quote
Gaetano Posted January 24 Posted January 24 (edited) Thanks Werner. Meanwhile I have tried a minimal image and did not plug the ethernet cable it, the Armbian initial boot script installed the drivers and connected seamlessly to wifi. No need for the marrownr external driver, so the headers problem is no longer a problem. Now I am keeping my fingers crossed that the OTG will work (it didn't work with Johang's latest images. So I created my own using hte armbian compilation script. It doesn't have Trixie for pcduino3nano, but bookworm should work. Cheers, Gaetano. Edited January 24 by Gaetano 0 Quote
Gaetano Posted January 24 Posted January 24 Hi Chris, when I tried to install the headers on my pcduino3nano, there were two options: linux-headers-armmp (or equivalent for your board) and kernel-headers. This secong package name was incomplete, but apt suggested a list of possible matches for my system. Give that a try. Cheers, Gaetano. 0 Quote
ChrisO Posted January 26 Author Posted January 26 (edited) Thanks Werner and Gaetano I fear DIY an image exceeds my skils 😉 I tried linux-headers-arm64. Result: kernel downgraded to 6.12 and wrong links in /boot: lrwxrwxrwx 1 root root 30 Dec 29 22:28 Image -> vmlinuz-6.18.2-current-meson64 lrwxrwxrwx 1 root root 27 Jan 23 13:27 uInitrd -> uInitrd-6.12.63+deb13-arm64 Corrected, built ZFS but at the end USB not working. It's not worth the hassle. I ended up installing Armbian_25.8.1_Odroidhc4_bookworm_current_6.12.41_minimal.img Everything seams OK, especially ZFS. Anyway, the link to Armbian_community_26.2.0-trunk.151_Odroidhc4_trixie_current_6.18.2_minimal.img is not there anymore 🙂 Thanks for your time. Chris Edited January 26 by ChrisO 0 Quote
Igor Posted January 27 Posted January 27 On 1/26/2026 at 12:24 PM, ChrisO said: Anyway, the link to Armbian_community_26.2.0-trunk.151_Odroidhc4_trixie_current_6.18.2_minimal.img is not there anymore Old automated builds are not kept. Only last three releases https://github.com/armbian/community/releases Its 300Gb / week 0 Quote
Igor Posted January 28 Posted January 28 Ubuntu Noble variant already supports ZFS on 6.18.y while Trixie was added today: https://github.com/armbian/os/pull/425 Testing: Spoiler sudo apt install zfs-dkms zfsutils-linux ^Cading package lists... 98% igorp@odroidm1:~$ sudo apt update Hit:1 http://security.debian.org trixie-security InRelease Hit:2 http://deb.debian.org/debian trixie InRelease Hit:3 http://deb.debian.org/debian trixie-updates InRelease Hit:4 http://deb.debian.org/debian trixie-backports InRelease Hit:5 https://github.armbian.com/configng stable InRelease Get:6 https://repo.armbian.com/artifacts/425/zfs-trixie trixie InRelease [50.6 kB] Get:7 https://repo.armbian.com/artifacts/425/zfs-trixie trixie/trixie-utils all Packages [866 B] Get:8 https://repo.armbian.com/artifacts/425/zfs-trixie trixie/trixie-utils arm64 Packages [2,730 B] Fetched 54.2 kB in 8s (7,025 B/s) All packages are up to date. igorp@odroidm1:~$ sudo apt install zfs-dkms zfsutils-linux Installing: zfs-dkms zfsutils-linux Installing dependencies: dkms file libmagic-mgc libmagic1t64 libnvpair3linux libuutil3linux libzfs7linux libzpool7linux Suggested packages: menu debhelper nfs-kernel-server samba-common-bin zfs-initramfs | zfs-dracut Recommended packages: fakeroot zfs-zed Summary: Upgrading: 0, Installing: 10, Removing: 0, Not Upgrading: 0 Download size: 5,170 kB Space needed: 37.5 MB / 4,520 MB available Continue? [Y/n] Get:1 http://deb.debian.org/debian trixie/main arm64 libmagic-mgc arm64 1:5.46-5 [338 kB] Get:2 http://deb.debian.org/debian trixie/main arm64 libmagic1t64 arm64 1:5.46-5 [103 kB] Get:3 http://deb.debian.org/debian trixie/main arm64 file arm64 1:5.46-5 [43.7 kB] Get:4 http://deb.debian.org/debian trixie/main arm64 dkms all 3.2.2-1~deb13u1 [60.1 kB] Get:5 https://repo.armbian.com/artifacts/425/zfs-trixie trixie/trixie-utils arm64 libnvpair3linux arm64 2.4.0-1 [61.8 kB] Get:6 https://repo.armbian.com/artifacts/425/zfs-trixie trixie/trixie-utils arm64 libuutil3linux arm64 2.4.0-1 [54.7 kB] Get:7 https://repo.armbian.com/artifacts/425/zfs-trixie trixie/trixie-utils arm64 libzfs7linux arm64 2.4.0-1 [222 kB] Get:8 https://repo.armbian.com/artifacts/425/zfs-trixie trixie/trixie-utils arm64 libzpool7linux arm64 2.4.0-1 [1,211 kB] Get:9 https://repo.armbian.com/artifacts/425/zfs-trixie trixie/trixie-utils arm64 zfsutils-linux arm64 2.4.0-1 [587 kB] Get:10 https://repo.armbian.com/artifacts/425/zfs-trixie trixie/trixie-utils arm64 zfs-dkms all 2.4.0-1 [2,488 kB] Fetched 5,170 kB in 4s (1,268 kB/s) Preconfiguring packages ... Selecting previously unselected package libnvpair3linux:arm64. (Reading database ... 61282 files and directories currently installed.) Preparing to unpack .../0-libnvpair3linux_2.4.0-1_arm64.deb ... Unpacking libnvpair3linux:arm64 (2.4.0-1) ... Selecting previously unselected package libuutil3linux:arm64. Preparing to unpack .../1-libuutil3linux_2.4.0-1_arm64.deb ... Unpacking libuutil3linux:arm64 (2.4.0-1) ... Selecting previously unselected package libzfs7linux:arm64. Preparing to unpack .../2-libzfs7linux_2.4.0-1_arm64.deb ... Unpacking libzfs7linux:arm64 (2.4.0-1) ... Selecting previously unselected package libzpool7linux:arm64. Preparing to unpack .../3-libzpool7linux_2.4.0-1_arm64.deb ... Unpacking libzpool7linux:arm64 (2.4.0-1) ... Selecting previously unselected package zfsutils-linux. Preparing to unpack .../4-zfsutils-linux_2.4.0-1_arm64.deb ... Unpacking zfsutils-linux (2.4.0-1) ... Selecting previously unselected package libmagic-mgc. Preparing to unpack .../5-libmagic-mgc_1%3a5.46-5_arm64.deb ... Unpacking libmagic-mgc (1:5.46-5) ... Selecting previously unselected package libmagic1t64:arm64. Preparing to unpack .../6-libmagic1t64_1%3a5.46-5_arm64.deb ... Unpacking libmagic1t64:arm64 (1:5.46-5) ... Selecting previously unselected package file. Preparing to unpack .../7-file_1%3a5.46-5_arm64.deb ... Unpacking file (1:5.46-5) ... Selecting previously unselected package dkms. Preparing to unpack .../8-dkms_3.2.2-1~deb13u1_all.deb ... Unpacking dkms (3.2.2-1~deb13u1) ... Selecting previously unselected package zfs-dkms. Preparing to unpack .../9-zfs-dkms_2.4.0-1_all.deb ... Unpacking zfs-dkms (2.4.0-1) ... Setting up libnvpair3linux:arm64 (2.4.0-1) ... Setting up libmagic-mgc (1:5.46-5) ... Setting up libmagic1t64:arm64 (1:5.46-5) ... Setting up file (1:5.46-5) ... Setting up dkms (3.2.2-1~deb13u1) ... Setting up zfs-dkms (2.4.0-1) ... Loading new zfs/2.4.0 DKMS files... Building for 6.18.7-current-rockchip64 Building initial module zfs/2.4.0 for 6.18.7-current-rockchip64 The kernel is built without module signing facility, modules won't be signed Running the pre_build script................................................................................................................................................... done. Building module(s)................................................................................................................................................... Once automation completes, it will be provided via normal apt update. 0 Quote
ChrisO Posted January 30 Author Posted January 30 (edited) Thanks Igor. Just for reference, I also tried Armbian_community_26.2.0-trunk.332_Odroidhc4_forky_current_6.18.7_minimal.img apt update apt upgrade apt install linux-headers-current-meson64 apt install zfsutils-linux zfs-initramfs zfs-dkms zfs-zed Everything went fine and seams to working OK. Chris Edited January 30 by ChrisO 1 Quote
