Hi
rtl8189FS was added on august and the version at include/rtw_version.h is v4.3.18.1_15373.20151005
At http://linux-sunxi.org/Wifi#RTL8189FTV I see that the recommended repository is https://github.com/jwrdegoede/rtl8189ES_linux/tree/rtl8189fs
That repository use v4.3.24_15589.20151023
There is also newer versions, now I'm patching v4.3.24.6_20019.20161107
https://github.com/CGarces/rtl8189FS
Any one has tested this newer versions? maybe @martinayotte ?
That's strange,  jwrdegoede has newer versions than that one.
@Igor I see that you have starred CGarces/rtl8189FS at GitHub. Is just  fork from khadas/android_hardware_wifi_realtek_drivers_8189ftv but patched to works on x86 and newer kernels.
I'm looking for a "upstream" repository to send my changes, I'm not planing to made other fork of the very fragmented RTL drivers ecosystem.
My first option is jwrdegoede repository, please check this repository instead of CGarces/rtl8189FS
https://github.com/CGarces/rtl8189ES_linux/commits/update_version
Is the jwrdegoede repository + two new versions from the code of khadas (but keeping the jwrdegoede modifications).
You can see the current status of the builds there
https://travis-ci.org/CGarces/rtl8189ES_linux/builds/307639831?utm_source=github_status&utm_medium=notification
Don't worry about the compilation errors, all have a patch ready to be applied.
I'm planing to send a PR with the new versions to jwrdegoede + and additional PR with the fixes for specific kernels.
Any feedback are welcome.
Hans is a trusted person/source so try to work out there. I'll check when possible.
Hi have send all my changes to the jwrdegoede repository.
I haven't merge the last PR just in case someone add some feedback
https://github.com/jwrdegoede/rtl8189ES_linux/pull/10
Compilation logs
https://travis-ci.org/CGarces/rtl8189ES_linux/builds/308135114
I'll merge the PR tonight if I not receive negative comments.
Feel free to use that new version on Armbian kernel. Unfortunately I can't provide a change log.
