Berat Uslu Posted November 29, 2017 Posted November 29, 2017 Hi, I am using orange pi lite. and loaded debian desktop.. it says it connected to wifi network. But I am trying to browse internet with chromium. It can't reach to the internet. it cant upload since there is no internet connection so I took pictures of reult of command armbianmonitor -U as much as I could. Here are the screen shots. https://ibb.co/jMyjKbhttps://ibb.co/kPK8ebhttps://ibb.co/hRndebhttps://ibb.co/cdsdebhttps://ibb.co/ihXiCwhttps://ibb.co/f6RRXw and I dont know how to fix. this Can someone help me? Thank you.
Igor Posted November 29, 2017 Posted November 29, 2017 How did you connect to the internet? https://docs.armbian.com/User-Guide_Getting-Started/#how-to-connect-to-wireless
Berat Uslu Posted November 29, 2017 Author Posted November 29, 2017 I connected using GUI? at top right corner...
guidol Posted November 29, 2017 Posted November 29, 2017 On 11/29/2017 at 4:15 PM, Berat Uslu said: I connected using GUI? at top right corner... Expand I got also problem with the GUI-Network-connection in Pixel Desktop on Raspberry. Please try to use nmtui-connect or nmtui in the Shell/Console Check if you got the right /etc/network/interfaces which is managed by the network-manager:https://docs.armbian.com/User-Guide_Fine-Tuning/#how-to-change-network-configuration
Berat Uslu Posted November 29, 2017 Author Posted November 29, 2017 Hi Guidol, I tried nmtui-connect command, problem still remains. I am in new in the linux area.. which things should I check if it is right?
guidol Posted November 29, 2017 Posted November 29, 2017 On 11/29/2017 at 5:14 PM, Berat Uslu said: Hi Guidol, I tried nmtui-connect command, problem still remains. I am in new in the linux area.. which things should I check if it is right? Expand check if you can "ping 8.8.8.8" this is the Google-DNS-Server and show us the content of your /etc/network/interfaces Do you use DHCP for the IP (from the router) or di you use a static IP?
Berat Uslu Posted November 29, 2017 Author Posted November 29, 2017 On 11/29/2017 at 5:21 PM, guidol said: check if you can "ping 8.8.8.8" this is the Google-DNS-Server and show us the content of your /etc/network/interfaces Do you use DHCP for the IP (from the router) or di you use a static IP? Expand my IP is not static from my internet provider... Here is results:http://ibb.co/eZh09bhttp://ibb.co/bEndvG thank you.
Berat Uslu Posted November 29, 2017 Author Posted November 29, 2017 On 11/29/2017 at 5:02 PM, guidol said: I got also problem with the GUI-Network-connection in Pixel Desktop on Raspberry. Please try to use nmtui-connect or nmtui in the Shell/Console Check if you got the right /etc/network/interfaces which is managed by the network-manager:https://docs.armbian.com/User-Guide_Fine-Tuning/#how-to-change-network-configuration Expand This answer solved my issue.. https://unix.stackexchange.com/questions/55881/debian-cannot-access-internet-despite-being-connected Thank you very much guys...
guidol Posted November 29, 2017 Posted November 29, 2017 On 11/29/2017 at 5:31 PM, Berat Uslu said: my IP is not static from my internet provider... Here is results:http://ibb.co/eZh09bhttp://ibb.co/bEndvG thank you. Expand the IP from the Internet provider hasnt to be static Your Orange Pi seems to get his IP via DHCP from the router/DSL-Modem, but is missing the DNS-Server entry, because you can ping to the internet (8.8.8.8) but the Orange Pi doesnt know the name of the Google-IP. Normally the router/DSL-Modem also submit the IP of the DNS-Server via DHCP to your computer/Orange PI. Do you have other computers working via DHCP while connected to your router/DSL-Modem? For a first test you could try to add a DNS-Server to your connection. First try to find the name of your connection with : nmcli con show -a then add dns-servers to the connection: nmcli con mod [the_name_of_your_connection] ipv4.dns “8.8.8.8 8.8.4.4” https://www.tecmint.com/configure-network-connections-using-nmcli-tool-in-linux/
