Hi,
I am using orange pi lite. and loaded debian desktop..
it says it connected to wifi network. But I am trying to browse internet with chromium. It can't reach to the internet. it cant upload since there is no internet connection so I took pictures of reult of command armbianmonitor -U as much as I could.
Here are the screen shots.
https://ibb.co/jMyjKb
https://ibb.co/kPK8eb
https://ibb.co/hRndeb
https://ibb.co/cdsdeb
https://ibb.co/ihXiCw
https://ibb.co/f6RRXw
and I dont know how to fix. this Can someone help me?
Thank you.
Hi Guidol,
I tried nmtui-connect command, problem still remains. I am in new in the linux area.. which things should I check if it is right?
5 minutes ago, Berat Uslu said:
Hi Guidol,
check if you can "ping 8.8.8.8" this is the Google-DNS-Server
and
show us the content of your /etc/network/interfaces :)
Do you use DHCP for the IP (from the router) or di you use a static IP?
43 minutes ago, guidol said:
I got also problem with the GUI-Network-connection in Pixel Desktop on Raspberry.
Please try to use nmtui-connect or nmtui in the Shell/Console
Check if you got the right /etc/network/interfaces which is managed by the network-manager:
https://docs.armbian.com/User-Guide_Fine-Tuning/#how-to-change-network-configuration
This answer solved my issue..
https://unix.stackexchange.com/questions/55881/debian-cannot-access-internet-despite-being-connected
Thank you very much guys...
7 minutes ago, Berat Uslu said:
my IP is not static from my internet provider...
Here is results:
http://ibb.co/eZh09b
http://ibb.co/bEndvG
thank you.
the IP from the Internet provider hasnt to be static :)
Your Orange Pi seems to get his IP via DHCP from the router/DSL-Modem, but is missing the DNS-Server entry, because you can ping to the internet (8.8.8.8) but the Orange Pi doesnt know the name of the Google-IP.
Normally the router/DSL-Modem also submit the IP of the DNS-Server via DHCP to your computer/Orange PI.
Do you have other computers working via DHCP while connected to your router/DSL-Modem?
For a first test you could try to add a DNS-Server to your connection.
First try to find the name of your connection with : nmcli con show -a
then add dns-servers to the connection:
nmcli con mod [the_name_of_your_connection] ipv4.dns “8.8.8.8 8.8.4.4”
https://www.tecmint.com/configure-network-connections-using-nmcli-tool-in-linux/
