Димитър Мазнеков Posted November 30, 2017 Posted November 30, 2017 Good time of day fellows. How can I mount SD card to transfer data into when Armbian 3.35 Ubuntu 16.04 started from flash? Cant see SD card nor mount it. Installed USBmount and it works with USB flashes on OTG port but no with SD card. Thanks to anyone for advice. Additional info: NanoPi Air 32Gb eMMC http://sprunge.us/OLNS
Igor Posted December 4, 2017 Posted December 4, 2017 Did you upgrade to latest and reboot? I am not sure this is solved in some older builds.
Димитър Мазнеков Posted December 5, 2017 Author Posted December 5, 2017 No it's not even in 3.36. Must be fixed manual in .fex For the resolution: #fex2bin /boot/script.bin ~/script.fex #nano ~/script.fex ..... [mmc1_para] sdc_used = 1 sdc_detmode = 4 ..... #bin2fex ~/script.fex /boot/script.bin #reboot Thanks for the red line in: @tkaiser and his post additional info and experience at: http://lists.phcomp.co.uk/pipermail/arm-netbook/2013-October/009162.html http://linux-sunxi.org/Fex_Guide#sdmmc_configuration
Per-Mattias Nordkvist Posted January 17, 2019 Posted January 17, 2019 Great info, thanks. If if you do this fix, will the SD-card be mountable after boot on eMMC?
