Meestor_X Posted February 12 Posted February 12 The Radxa bullseye image looks to boot fine, but Armbian forky does not boot at all. 0 Quote
Meestor_X Posted February 13 Author Posted February 13 (edited) Ya, I know, but I haven't figured out how to work with these devices that have "built in" serial->USB adapters. The USBC becomes a serial port when connected to my computer, but that also powers it on, and it's not actually a port until the e25 has power. It's a catch-22. It needs power for the port to appear, and by the time the port appears and you've already missed part of the log. The e20c is much better, it has a separate power and debug port. 🙂 https://www.dropbox.com/scl/fi/u27poqubrg4rywz1xfjo5/IMG_3840.jpeg?rlkey=1mbl58bl8cy0b9i1s3xxjuh6y&dl=0 Edited February 13 by Meestor_X 0 Quote
Meestor_X Posted February 13 Author Posted February 13 (edited) Update... I figured out how to do it. Oh, and the docs show the baud rate to be 115200 like normal devices, but no - it's actually 1500000 baud. ---- Reopened serial port /dev/tty.usbserial-3120 ---- DDR 2d653b3476 typ 24/01/20-15:04:19,fwver: v1.21 In LP4/4x derate en, other dram:1x trefi ddrconfig:7 LPDDR4X, 324MHz BW=32 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB tdqss: cs0 dqs0: 48ps, dqs1: -48ps, dqs2: 24ps, dqs3: -120ps, tdqss: cs1 dqs0: 48ps, dqs1: -48ps, dqs2: 24ps, dqs3: -96ps, change to: 324MHz PHY dr:clk:36,ca:36,DQ:29,odt:0 vrefinner:24%, vrefout:41% dram drv:40,odt:0 clk skew:0x61 rx vref: 30.4% tx vref: 40.0% change to: 528MHz PHY drv:clk:36,ca:36,DQ:29,odt:0 vrefinner:24%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 rx vref: 34.4% tx vref: 40.0% change to: 80MHz PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 rx vref: 15.6% tx vref: 40.0% change to: 1560MHz(final freq) PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:22% dram drv:40,odt:80 vref_ca:00000071 clk skew:0x17 rx vref: 16.6% tx vref: 22.8% cs 0: the read training result: DQS0:0x35, DQS1:0x36, DQS2:0x35, DQS3:0x2f, min : 0xf 0x11 0x12 0x10 0x2 0x6 0x8 0x6 , 0xe 0xb 0x1 0x3 0xe 0xe 0xe 0xa , 0x10 0x10 0xb 0xa 0x2 0x4 0x6 0x6 , 0xa 0x7 0x4 0x1 0xe 0x11 0xc 0xf , mid :0x29 0x2b 0x2c 0x2a 0x1d 0x20 0x22 0x21 ,0x26 0x26 0x1 0x1e 0x28 0x28 0x28 0x25 , 0x2b 0x2b 0x24 023 0x1b 0x1d 0x1e 0x1f ,0x24 0x20 0x1e 0x1a 0x27 02a 0x25 0x28 , max :0x43 0x45 0x47 0x44 0x38 0x3a 0x3c 0x3d ,0x3e 0x41 0x38 0x39 0x42 0x43 0x43 0x41 , 0x47 0x4 0x3e 0x3d 0x34 0x36 0x36 0x39 ,0x3e 0x3a 0x38 0x34 0x40 0x43 0x3e 0x41 , range:0x34 0x34 0x35 0x34 0x36 0x34 0x34 0x37 ,0x30 0x36 0x37 0x36 0x34 0x35 0x35 0x37 , 0x37 0x37 0x33 0x33 0x32 0x32 0x30 0x33 ,0x34 0x33 0x34 0x33 0x32 0x32 0x32 0x32 , the write training result: DQS0:0x20, DQS1:0xe, DQS2:0x1b, DQS3:0x4, min :0x6f 0x73 0x74 0x71 0x63 0x68 x6a 0x6a 0x68 ,0x5c 0x59 0x52 0x52 0x5d 0x5d 0x5d 0x5b 0x58 , 0x6c 0x6d 0x68 0x68 0x5f 0x5e 0x5d 0x61 0x64 ,0x55 0x51 0x4e 0x4a 0x57 0x59 0x51 0x59 0x4e , mid :0x8b 0x8e 0x8f 0x8b 0x7c 0x82 0x84 0x82 0x81 ,0x76 0x75 0x6d 0x6c 0x78 0x76 0x76 0x75 0x71 , 0x88 0x89 0x81 0x81 0x79 0x76 0x77 0x7a 0x7d ,0x6f 0x6b 0x68 0x62 0x71 0x72 0x6c 0x73 0x68 , max :0xa7 0xa9 0xaa 0xa6 0x96 0x9c 0x9e 0x9a 0x9a ,0x910x91 0x89 0x86 0x93 0x90 0x90 0x8f 0x8b , 0xa5 0xa5 0x9b 0x9a 0x93 0x8f 0x92 0x93 0x97 ,0x89 0x86 0x83 0x7b 0x8c 0x8c 0x87 0x8d 0x83 , range:0x38 0x36 0x36 0x35 0x33 0x34 0x34 0x30 0x32 ,0x35 0x38 0x37 0x34 0x36 0x33 0x33 0x34 0x33 , 0x39 0x38 0x33 0x32 0x34 0x31 0x35 0x32 0x33 ,0x34 0x35 0x35 0x31 0x35 0x33 0x36 0x34 0x35 , cs 1: the read training result: DQS0:0x35, DQS1:0x36, DQS2:0x35, DQS3:0x2f, min : 0xf 0x11 0x12 0x10 0x2 0x6 0x8 0x6 , 0xe 0xb 0x1 0x3 0xe 0xe 0xe 0xa , 0x10 0x10 0b 0xa 0x2 0x4 0x6 0x6 , 0xa 0x7 0x4 0x1 0xe 0x11 0xc 0xf , mid :029 0x2b 0x2c 0x2a 0x1d 0x20 0x22 0x21 ,0x26 0x26 0x1c 0x1e 0x28 0x28 0x28 0x25 , 0x2b 0x2b 0x24 0x23 0x1b 0x1d 0x1e 0x1f ,0x24 0x20 0x1e 0x1a 0x27 0x2a 0x25 0x28 , max :0x43 0x45 0x47 0x44 0x38 0x3a 0x3c 0x3d ,0x3e 0x41 0x38 0x39 0x42 0x43 0x43 0x41 , 0x47 0x47 0x3e 0x3d 0x34 0x36 0x36 0x39 ,0x3e 0x3a 0x38 0x34 0x40 0x43 0x3e 0x41 , range:0x34 0x34 0x35 0x34 0x36 0x34 0x34 0x37 ,0x30 0x36 0x37 0x36 0x34 0x35 0x35 0x37 , 0x37 0x37 0x33 0x33 0x32 0x32 0x30 0x33 ,0x34 0x33 0x34 0x33 0x32 0x32 0x32 0x32 , the write training result: DQS0:0x20, DQS1:0xe, DQS2:0x1b, DQS3:0x4, min :0x6f 0x73 0x74 0x71 0x63 0x68 0x6a 0x6a 0x68 ,0x5c 0x59 0x52 0x52 0x5d 0x5d 0x5d 0x5b 0x58 , 0x6c 0x6d 0x68 0x68 0x5f 0x5e 0x5d 0x61 0x64 ,0x55 0x51 0x4e0x4a 0x57 0x59 0x51 0x59 0x4e , mid :0x8b 0x8e 0x8f 0x8b 0x7c 0x82 0x84 0x82 0x81 ,0x76 0x75 0x6d 0x6c 0x78 0x76 0x76 0x75 0x7 , 0x88 0x89 0x81 0x81 0x79 0x76 0x77 0x7a 0x7d ,0x6f 0x6b 0x68 0x62 0x71 0x72 0x6c 0x73 0x68 , max :0xa7 0xa9 0xaa 0xa6 0x96 0x9c 0x9e 0x9a 0x9a ,0x91 0x91 0x89 0x86 0x93 0x90 0x90 0x8f 0x8b , 0xa5 0xa5 0x9b 0x9a 0x93 0x8f 0x92 0x93 0x97 ,0x89 0x86 0x83 0x7b 0x8c 0x8c 0x87 0x8d 0x83 , range:0x38 0x36 0x36 0x35 0x33 0x34 0x34 0x30 0x32 ,0x35 0x38 0x37 0x34 0x36 0x33 0x33 0x34 0x33 , 0x39 0x38 0x33 0x32 0x34 0x31 0x35 0x32 0x33 ,0x34 0x35 0x35 0x31 0x35 0x33 0x36 0x34 0x35 , CA Training result: cs:0 min :0x55 0x50 0x47 0x42 0x48 0x3f 0x4a ,0x53 0x4a 0x49 0x3f 0x47 0x3e 0x4c , cs0 mid :0x92 0x91 0x84 0x82 0x85 x80 0x78 ,0x8f 0x8c 0x84 0x80 0x83 0x7f 0x7a , cs:0 max :0xcf 0xd2 0xc1 0xc3 0xc2 0xc1 0xa7 ,0xcb 0xce 0xc0 0xc2 0xbf 0xc1 0xa9 , cs:0 range:0x7 0x82 0x7a 0x81 0x7a 0x82 x5d ,0x78 0x84 0x77 0x83 0x78 0x3 0x5d , cs:1 min :0x52 0x54 0x47 0x47 0x47 0x44 0x4e ,0x54 0x4f 0x48 0x47 0x45 0x45 0x4b , cs:1 mid :0x92 0x91 0x86 0x84 0x85 0x81 0x7d ,0x94 0x8d 0x87 0x84 0x84 0x82 0x7b , cs:1 max :0xd3 0xce 0xc6 0xc2 0xc4 0xbe 0xad ,0xd5 0xcc 0xc6 0xc1 0xc3 0xc0 0xab , cs:1 range:0x81 0x7a 0x7f 0x7b 0x7d 0x7a 0x5f ,0x81 0x7d 0x7e 0x7a 0x7e 0x7b 0x60 , out U-Boot SPL board init U-Boot SPL 2017.09_armbian-2017.09-S93fe-P9666-Hbdb5-Vec91-Bbf55-R448a (Nov 06 2025 - 03:5:10) sfc cmd=0fH(6BH-x4) unknown raw ID 0 0 0 unrecognized JEDEC id bytes: 00, 00, 00 Trying to boot from MMC2 No misc partition spl: partition error Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(b5946ac63d...) + OK ## Checking uboot 0x00a00000 ... sha256(2ba66b66df...) + OK ## Checking fdt 0x00b53a98 ... sha256(e3b0c44298...) + OK fdt_record_loadable: FDT_ERR_BADMAGIC ## Checking atf-2 0xfdcc1000 ... sha256(b8dca786b4...) + OK fdt_record_loadable: FDT_ERR_BADMAGIC ## Checking atf-3 0x0006b000 ... sha256(2f91089eb7...) + OK fdt_record_loadable: FDT_ERR_BADMAGIC ## Checking atf-4 0xfdcce000 ... sha256(86ef885748..) + OK fdt_record_loadable: FDT_ERR_BADMAGIC ## Checing atf-5 0xfdcd0000 ... sha256(0b2b146c60..) + OK fdt_record_loadable FDT_ERR_BADMAGIC ## Checking atf-6 0x00069000 ... sha256(a9a1e63bef...) + OK fdt_record_loadable: FDT_ERR_BADMAGIC Jumping to UBoot(0x00a00000) via ARM Trusted Firmware(0x00040000) Total: 282.455/439.40 ms INFO: reloader serial: 2 NOTICE: BL31: v2.3():v2.3-645-g8cea6ab0b:cl, fwver: v1.44 NOTICE: BL31: Built : 16:36:43, Sep 19 2023 INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: pmu v1 is valid 220114 INFO: l3 cache partition cfg-0 INF: dfs DDR fsp_param[0].freq_mhz= 1560MHz INFO: dfs DDR fsp_param[1].freq_mhz= 324MHz INFO: dfs DDR fsp_param[2].freq_mhz= 528MHz INFO: dfs DDR fsp_param[3].freq_mhz= 780MHz INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: BL31: Initializing runtime ervices WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0xa00000 INFO: SPSR = 0x3c9 No valid device tree binary found - please append one to U-Boot binary, use u-boot-dtb.bin or define CONFIG_OF_EMBED. For sandbox, use -d <file.dtb> initcall sequence 0000000000ad26c0 failed at call 0000000000ac4528 (err=-1) ### ERROR ### Please RESET the board ### Edited February 13 by Meestor_X 0 Quote
Meestor_X Posted February 13 Author Posted February 13 (edited) Normal boot with Bookworm for reference: [ 320.992063] watchdog: watchdog0: watchdog did not stop! [ 321.102430] reboot: Restarting system DDR 2d653b3476 typ 24/01/20-15:04:19,fwver: v1.21 In LP4/4x derate en, other dram:1x trefi ddrconfig:7 LPDDR4X, 324MHz BW=32 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB tdqss: cs0 dqs0: 48ps, dqs1: -48ps, dqs2: 24ps, dqs3: -120ps, tdqss: cs1 dqs0: 48ps, dqs1: -48ps, dqs2: 24ps, dqs3: -96ps, change to: 324MHz PHY drv:clk:36,ca:36,DQ:29,odt:0 vrefinner:24%, vrefout:41% dram drv:40,odt:0 clk skew:0x61 rx vref: 30.4% tx vref: 42.0% change to: 528MHz PHY drv:clk:36,ca:36,DQ:29,odt:0 vrefinner:24%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 rx vref: 34.4% tx vref: 42.0% change to: 780MHz PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 rx vref: 15.6% tx vref: 40.0% change to: 1560MHz(final freq) PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:22% dram drv:40,odt:80 vref_ca:00000071 clk skew:0x17 rx vref: 16.6% tx vref: 22.8% cs 0: the read training result: DQS0:0x36, DQS1:0x37, DQS2:0x36, DQS:0x30, min : 0xe 0x11 0x12 0x10 0x2 0x6 0x9 0x5 , 0xd 0xa 0x1 0x3 0xe 0xe 0xe 0xa , 0x10 0x11 0xb 0xa 0x3 0x5 0x5 0x6 , 0xa 0x8 0x4 0x2 0xe 0x12 0xd 0xf , mid :0x29 0x2b 0x2d 0x2a 0x1d 0x20 0x23 0x21 ,0x26 0x26 0x1d 0x1e 0x28 0x29 0x29 0x26 , 0x2c 0x2d 0x25 0x24 0x1c 0x1d 0x1e 0x1f ,0x24 0x21 0x1f 0x1b 0x28 0x2b 0x27 0x29 , max :0x44 0x45 0x48 0x45 0x39 0x3b 0x3d 0x3e ,0x3f 0x42 0x39 0x39 0x43 0x45 0x44 0x43 , 0x49 0x49 0x3f 0x3e 0x35 0x36 0x37 0x39 ,0x3f 0x3b 0x3a 0x35 0x43 0x45 0x41 0x43 , range:0x36 0x34 0x36 0x35 0x37 0x35 0x34 0x39 ,0x32 0x38 0x38 0x36 0x35 0x37 0x36 0x39 , 0x39 0x38 0x34 0x34 0x32 0x31 0x32 0x33 ,0x35 0x33 0x36 0x33 0x35 0x33 0x34 0x34 , the write training result: DQS0:0x20, DQS1:0xe, DQS2:0x1b, DQS3:0x4, min :0x70 0x74 0x74 0x72 0x64 0x68 0x6b 0x6a 0x68 ,0x5d 0x5a 0x53 0x53 0x5e 0x5e 0x5e 0x5b 0x58 , 0x6c 0x6d 0x68 0x68 0x5f 0x5e 0x5e 0x61 0x64 ,0x56 0x52 0x4e 0x4a 0x57 0x5a 0x52 0x5a 0x4e , mid :0x8b 0x8f 0x8f 0x8c 0x7d 0x81 0x84 0x82 0x81 ,0x78 0x76 0x6e 0x6c 0x79 0x77 0x78 0x75 0x72 , 0x88 0x89 0x81 0x81 0x79 0x77 0x78 0x7a 0x7d ,0x70 0x6c 0x69 0x62 0x72 0x73 0x6c 0x73 0x69 , max :0xa7 0xaa 0xab 0xa6 0x97 0x9b 0x9e 0x9b 0x9b ,0x93 0x93 0x89 0x86 0x94 0x91 0x92 0x8f 0x8c , 0xa5 0xa5 0x9b 0x9b 0x93 0x90 0x92 0x93 0x97 ,0x8a 0x86 0x84 0x7b 0x8d 0x8d 0x87 0x8d 0x84 , range0x37 0x36 0x37 0x34 0x33 0x33 0x33 0x31 0x33 ,0x36 0x39 0x36 0x33 0x36 0x33 0x34 0x34 0x34 , 0x39 0x38 0x33 0x33 0x34 0x32 0x34 0x32 0x3 ,0x34 0x34 0x36 0x31 0x36 0x33 0x35 0x33 0x36 , cs 1: the read training result: DQS0:0x36, DQS1:0x37, DQS2:0x36, DQS3:0x30, min : 0xe 0x11 0x12 0x10 0x2 0x6 0x9 0x5 , 0xd 0xa 0x1 0x3 0xe 0xe 0xe 0xa , 0x10 0x11 0xb 0xa 0x3 0x5 0x5 0x6 , 0a 0x8 0x4 0x2 0xe 0x12 0xd 0xf , mid :0x29 0x2b 0x2d 0x2a 0x1d 0x20 0x23 0x21 ,0x26 0x26 0x1d 0x1e 0x28 0x29 0x29 0x26 , 0x2c 0x2d 0x25 0x24 0x1c 0x1d 0x1e 0x1f ,0x24 0x21 0x1f 0x1b 0x28 0x2b 0x27 0x29 , max :0x44 0x45 0x48 0x45 0x39 0x3b 0x3d 0x3e ,0x3f 0x42 0x39 0x39 0x43 0x45 0x44 0x43 , 0x49 0x49 0x3f 0x3e 0x350x36 0x37 0x39 ,0x3f 0x3b 0x3a 0x35 0x43 0x45 0x41 0x43 , range:0x36 0x34 0x36 0x5 0x37 0x35 0x34 0x39 ,0x32 0x38 0x38 0x36 0x35 0x37 0x36 0x39 , 0x39 0x38 0x34 0x34 0x32 0x31 0x32 0x33 ,0x35 0x33 0x36 033 0x35 0x33 0x34 0x34 , the write training result: DQS0:0x20, DQS1:0xe, DQS2:0x1b, DQS3:0x4, min :0x70 0x74 0x74 0x72 0x64 0x68 0x6b 0x6a 0x68 ,0x5d 0x5a 0x53 0x53 0x5e 0x5e 0x5e 0x5b 0x58 , 0x6c 0x6d 0x68 0x68 0x5f 0x5e 0x5e 0x61 0x64 ,0x56 0x52 0x4e 0x4a 0x57 0x5a 0x52 0x5a 0x4e , mid :0x8b 0x8f 0x8f 0x8c 0x7d 0x81 0x84 0x82 0x81 ,0x78 0x76 0x6e 0x6c 0x79 0x77 0x78 0x75 0x72 , 0x88 0x89 0x81 0x81 0x79 0x77 0x78 0x7a 0x7d ,0x70 0x6c 0x69 0x62 0x72 0x73 0x6c 0x73 0x69 , max :0xa7 0xaa 0xab 0xa6 0x97 0x9b 0x9e 0x9b 0x9b ,0x93 0x93 0x89 0x86 0x94 0x91 0x92 0x8f 0x8c , 0xa5 0xa5 0x9b 0x9b 0x93 0x90 0x92 0x93 0x97 ,0x8a 0x86 0x84 0x7b 0x8d 0x8d 0x87 0x8d 0x84 , range:0x37 0x36 0x37 0x34 0x33 0x33 0x33 0x31 0x33 ,0x36 0x39 0x36 0x33 0x36 0x33 0x34 0x34 0x34 , 0x39 0x38 0x33 0x33 0x34 0x32 0x34 0x32 0x33 ,0x3 0x34 0x36 0x31 0x36 0x33 0x35 0x33 0x36 , CA Training result: cs:0 min :0x55 0x50 0x47 0x42 0x48 0x3e 0x4a ,0x53 0x4a 0x49 0x3f 0x47 0x3d 0x4c , cs:0 mid :0x92 0x91 0x84 0x82 0x85 0x7f 0x78 ,0x8f 0x8c 0x84 0x80 0x83 0x7f 0x7a , cs:0 max :0xcf 0xd2 0xc1 0xc3 0xc2 0xc1 0xa7 ,0xcb 0xce 0xc0 0xc2 0xbf 0xc1 0xa9 , cs:0 range:0x7a 0x82 0x7a 0x81 0x7a 0x83 0x5d ,0x78 0x84 0x77 0x83 0x78 0x84 0x5d , cs:1 min :0x51 0x54 0x46 0x47 0x47 0x44 0x4d ,0x53 0x4f 0x48 0x47 0x45 0x44 0x4c , cs:1 mid :0x91 0x90 0x86 0x84 0x85 0x80 0x7d ,0x93 0x8d 0x86 0x84 0x84 0x82 0x7a , cs:1 max :0xd2 0xcd 0xc6 0xc1 0xc4 0xbd 0xad ,0xd3 0xcc 0xc5 0xc1 0xc3 0xc0 0xa9 , cs:1 range:0x81 0x79 0x80 0x7a 0x7d 0x79 0x60 ,0x80 0x7d 0x7d 0x7a 0x7e 0x7c 0x5d , U-Boot PL board init U-Boot SPL 2017.09_armbian-2017.09-S93fe-P9666-Hbdb5-Vec91-Bbf55-R448a (Nov 06 2025 - 03:51:10) sfc cmd=0fH(6BH-x4) unknown raw ID 0 0 0 unrecognized JEDEC id bytes: 00, 00, 00 Trying to boot from MMC2 No misc partition spl: partition error Trying fit image at 0x400 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(b5946ac63d...) + OK ## Checking uboot 0x00a00000 ... sha256(f0e5ac3d0c...) + OK ## Checking fdt 0x00b55970 ... sha256(544a71302c...) + OK ## Checking atf-2 0xfdcc1000 ... sha256(b8dca786b4...) + OK ## Checking atf-3 0x0006b000 ... sha256(2f91089eb7...) + OK ## Checking atf-4 0xfdcce000 ... sha256(86ef885748...) + OK ## Checking atf-5 0xfdcd0000 ... sha256(0b2b146c60...) + OK ## Checking atf-6 0x00069000 ... sha256(a9a1e63bef...) + OK Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000) Total: 272.770/429.344 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-645-g8cea6ab0b:cl, fwver: v1.44 NOTICE: BL31: Built : 16:36:43, Sep 19 2023 INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in L3 INFO: pmu v1 is valid 220114 INFO: l3 cache partition cfg-0 INFO: dfs DDR fsp_param[0].freq_mhz= 1560MHz INFO: dfs DDR fsp_param[1].freq_mhz= 324MHz INFO: dfs DDR fsp_param[2].freq_mhz= 528MHz INFO: dfs DDR fsp_param[3].freq_mhz= 780MHz INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO Entry point address = 0xa00000 INFO: SPSR = 0x3c9 U-Boot 2017.09-armbian-2017.09-S2284-P8c48-Hfac6-V02d4-Bda0a-R448a (Nov 20 2024 - 17:01:23 +0000) Model: Radxa E25 Carrier Board MPIDR: 0x81000000 PreSerial: 2, raw, 0xfe660000 DRAM: 4 GiB Sysmem: init Relocation Offset: ed20a000 Relocation fdt: eb9f6638 - eb9fecc8 CR: M/C/I Using default environment DM: v1 dwmmc@fe2b0000: 1, dwmmc@fe2c0000: 2, sdhci@fe310000: 0 switch to partitions #0, OK mmc1 is current device Boot from SDcard Bootdev(scan): mmc 1 MMC1: Legacy, 52Mhz PartType: EFI No misc partition boot mode: one FIT: No boot partition Failed to load DTB, ret=-19 No vali DTB, ret=-22 Failed to get kernel dtb, ret=-22 I2c0 speed: 100000Hz vsel-gpios- not found! Error: -2 FAN53555Opton[12] Rev[15] Detected! vdd_cpu init 900000 uV PMIC: RK8090 (on=0x02, off=0x00) vdd_logic init 900000 uV vdd_gpu init 900000 uV vdd_npu init 900000 uV io-domain: OK Failed to get scmi clk dev dmc_fsp failed, ret=-19 Model: Radxa E25 Carrier Board MPIDR: 081000000 ## Error: Can't overwrite "ethaddr" ## Error inserting "ethaddr" variable, errno=1 ## Error: Can't overwrite "eth1addr" ## Error inserting "eth1addr" variable, errno=1 CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A) apll 816000 KHz dpll 780000 KHz gpll 1188000 KHz cpll 1000000 KHz npll 1200000 KHz vpll 24000 KHz hpll 24000 KHz ppll 200000 KHz armclk 816000 KHz aclk_bus 150000 KHz pclk_bus 100000 KHz aclk_top_high 300000 KHz aclk_top_low 200000 KHz hclk_top 150000 KHz pclk_top 100000 KHz aclk_perimid 300000 KHz hclk_perimid 150000 KHz pclk_pmu 100000 KHz No msc partition Net: No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 starting USB... Bus dwc3@fcc00000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus dwc3@fd000000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus dwc3@fcc00000 for devices... 1 USB Device(s) found scanning bus dwc3@fd000000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot.scr reading /boot.scr 4149 bytes read in 2 ms (2 MiB/s) ## Executin script at 00c00000 Boot script loaded from mmc 1:1 reading /armbianEnv.txt 234 bytes read in 1 ms (228.5 KiB/s) reading /uInitrd 14321257 bytes read in 1191 ms (11.5 MiB/s) reading Image 30097920 bytes read in 2500 ms (11.5 MiB/s) reading /dtb/rockchip/rk356-radxa-e25.dtb 117127 bytes read in 16 ms (7 MiB/s) Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Fdt Ramdisk skip relocation No misc partition ## Loading init Ramdisk from Legacy Image at 0a200000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 14321193 Bytes = 13.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 0x08300000 Booting using the fdt blob at 0x08300000 reserving fdt memory region: addr=8300000 size=82000 Using Device Tree in place at 0000000008300000, end 0000000008384fff can't found rockchip,drm-logo, use rockchip,fb-logo WARNING: could not set reg FDT_ERR_BADOFFSET. failed to reserve fb-loader-logo memory WARNING: could not set reg FDT_ERR_BADOFFSET. Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000) Adding bank: 0x1f0000000 - 0x200000000 (size: 0x10000000) Totl: 7590.510/7597.227 ms Starting kernel ... Armbian 24.11.1 Bookworm ttyS2 radxa-e25 login: Edited February 13 by Meestor_X 0 Quote
Igor Posted February 13 Posted February 13 Are those ok? https://fi.mirror.armbian.de/incoming/igorpecovnik/radxa-e25/archive/ One current, one vendor. 0 Quote
Meestor_X Posted February 13 Author Posted February 13 (edited) I'll try them. What do the terms "current" and "vendor" mean wrt these images? Edited February 13 by Meestor_X 0 Quote
Werner Posted February 13 Posted February 13 51 minutes ago, Meestor_X said: What do the terms "current" and "vendor" mean https://docs.armbian.com/User-Guide_Getting-Started/#vendor-current-edge-or-legacy 0 Quote
Meestor_X Posted February 13 Author Posted February 13 (edited) Ty. Trixie Current and Vendor both boot properly, thank you! (The one difference is that Vendor keeps the LED ring on, Current starts with it on and then goes to green flashing like the other builds) EDIT - with the Vendor build, the USB-A port doesn't recognize any devices. I'll stick with current. Trixie (minimal) isn't available in Armbian Imager, btw, just bookworm and forky. I don't suppose there's a vendor version of trixie for the Radxa Cubie a5e? Current build has a power issue that the Radxa build doesn't. Edited February 13 by Meestor_X 0 Quote
Solution Igor Posted February 13 Solution Posted February 13 1 hour ago, Meestor_X said: Current and Vendor both boot properly Thank you. Basic functionality, few non critical bugs = release ready. Moving to main download location. 1 hour ago, Meestor_X said: Trixie (minimal) isn't available in Armbian Imager, btw, just bookworm and forky. Imager will have them after they are moved to primary download location. Test images are not there. 1 hour ago, Meestor_X said: I don't suppose there's a vendor version of trixie for the Radxa Cubie a5e? Current build has a power issue that the Radxa build doesn't. We don't provide that. We will only provide images with mainline derived kernel which is hard to compare - its a very different SW stack - with Radxa vendor kernel. Basic (!) functions for headless usage are already working. The rest in next 6-12-> month. 0 Quote
