sanlu Posted Sunday at 08:10 PM Posted Sunday at 08:10 PM Hello since kernel 6.12 led (heartbeat and mmc activity) on board rock64 don't work. I've created issue in dietPI github: https://github.com/MichaIng/DietPi/issues/7618 but DietPI is using armbian kernel. Now I'm using recent armbian with kernel 6.11.0-edge-rockchip64. Any idea how to restore led activity on recent kernels? 0 Quote
Werner Posted yesterday at 04:42 AM Posted yesterday at 04:42 AM 8 hours ago, sanlu said: Now I'm using recent armbian with kernel 6.11.0-edge-rockchip64. Any idea how to restore led activity on recent kernels? I'd start by comparing the device tree on a working and non-working image. 0 Quote
Solution Torte Posted 22 hours ago Solution Posted 22 hours ago Did you try loading the "pinctrl-rk805" module? This was once directly compiled into the kernel and later externalized into a module. And IIRC that happened when switching to 6.12. If loading that module helps, then adding it to the MODULES line of the board's config like this should fix it. 0 Quote
sanlu Posted 1 hour ago Author Posted 1 hour ago Excelent! That works. I didn't, notice that pinctrl-rk805 was externalized and can't be loaded automatically. For now I've just add pinctrl-rk805 to /etc/initramfs-tools/modules and update-initramfs. Werner: device tree has no changes for a long time. Thanks! 0 Quote
