I've downloaded Ubuntu-mainline image at https://www.armbian.com/tinkerboard/
and written to SD as below but Hang while booting.
# dd if=Armbian_5.35_Tinkerboard_Ubuntu_xenial_next_4.13.16_desktop.img of=/dev/mmcblk0
5742592+0 records in
5742592+0 records out
2940207104 bytes (2.9 GB, 2.7 GiB) copied, 481.509 s, 6.1 MB/s
Log:
U-Boot SPL 2017.09-armbian (Nov 22 2017 - 17:12:11)
Returning to boot ROM...
U-Boot 2017.09-armbian (Nov 22 2017 - 17:12:11 +0100)
Model: Tinker-RK3288
DRAM:  2 GiB
MMC:   dwmmc@ff0c0000: 1
In:    serial
Out:   serial
Err:   serial
Net:   eth0: ethernet@ff290000
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
1485 bytes read in 26 ms (55.7 KiB/s)
## Executing script at 00000000
U-boot loaded from eMMC
106 bytes read in 21 ms (4.9 KiB/s)
42451 bytes read in 48 ms (863.3 KiB/s)
4616543 bytes read in 241 ms (18.3 MiB/s)
8384056 bytes read in 410 ms (19.5 MiB/s)
## Loading init Ramdisk from Legacy Image at 21000000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    4616479 Bytes = 4.4 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to 0fb98000, end 0ffff11f ... OK
   Loading Device Tree to 0fb8a000, end 0fb975d2 ... OK
Starting kernel ...
No need to format anything. Check is crucial that's why we suggest Etcher and if you can, try some other SD card.  I am not sure exactly for image which you are trying, but this one: https://dl.armbian.com/tinkerboard/nightly/Armbian_5.35.171130_Tinkerboard_Ubuntu_xenial_next_4.14.2_desktop.7z was tested personally and it works this way:
4.14.y is recommended since we are ditching 4.13.y ASAP.
Sorry I've seen same issue with different SD card, I see /boot/boot.cmd has setenv fdt_file "rk3288-miqi.dtb" which I've changed to rk3288-tinker.dtb but issue still there.
if you change the dtb it will be to "rk3288-miniarm.dtb" as that was the original name of the board.  I've stuck with it because of consistency to the 4.4 kernel.
But to be clear, I'm not sure how that would be the issue, I admit I haven't built an image in a couple days, but...
Is the CPU becoming burning hot during when it hangs ? Your issue sounds like @Tido's issue in the GPU Driver? thread.
What kind of display do you use ? And also what is its resolution ?
@Myy, the combination of your Kernel with Armbian caused a hot CPU
I ran the latest fresh install with: Armbian_5.34._Tinkerboard_Ubuntu_xenial_dev_4.14.0-rc6_desktop.img   and this worked flawlessly.
